Jimi IoT (Concox) JM-VL04
Concox JM-VL04 is a professional 4G OBD vehicle telematics device with INS-aided GPS tracking. The device features Driving Behavior Analysis, voice alarm, remote listen-in & voice recording, BLE 4.0 support, 50mA battery, and more.
Parameters (356)
Settings (28)
Flespi parses telemetry data from your Jimi IoT (Concox) JM-VL04 into a standardized JSON and lets you send commands to Jimi IoT (Concox) JM-VL04 via API.
    "device.type.id": "Jimi IoT (Concox) JM-VL04",
How to send commands to Jimi IoT (Concox) JM-VL04?
Protocol Number 0x39
Protocol Number 0x15
Automatic APN
auto_apn
Automatic APN detection
enable: Enable Automatic APN
External Battery Alarm
bat_alarm
External Battery Alarm Setup
battery: Enable Alarm
Battery Alarm
bat_alarm2
Battery Alarm Setup
GPS Blind Alarm
blind_alarm
GSP Blind Area Alarm Setup
blind: Enable Alarm
Center Number
center_number4
phone: Center Number
Factory reset
factory
Restore to factory settings (except domain name/APN/locked domain name)
Geofence Alarm
geofence_alarm
Geofence Alarm Setup
fence: Enable Alarm
Activate the positioning module
gps_on
Activate the positioning module during 5 min.
Harsh acceleration alarm setup
harsh_acc_alarm2
detect: Enable Alarm
Harsh deceleration alarm setup
harsh_dec_alarm2
Horisontal collision alarm setup
horisontal_collision2
Configure APN parameters
Mileage Statistics
Mileage Statistics Function
odometer: Mileage Statistics
Overspeeding Alarm
overspeed_alarm
Overspeeding Alarm Setup
overspeed: Enable Alarm
Power Alarm
power_alarm2
Power Alarm Setup
Query LBS
query_lbs
Query a LBS location point.
Restart Device
reboot_3
Sensitivity
sens_level
level: Level
Server Setup
comm: Communication Mode
mode: Host Mode
Server Setup
server3
mode: Host Mode
SOS Numbers
sos_numbers
SOS Phone Numbers Setup
delete: Delete Numbers
phone1: First Number
phone2: Second Number
phone3: Third Number
Speaker volume
speker_volume
Adjust the volume of speaker
volume: Volume
Status
status
Update status of the device
GPS Tracking Interval
timer
GPS Data Upload Time Interval
time_on: ACC On Upload Interval
time_off: ACC Off Upload Interval
timezone
Time Zone Setup
UBI Alert upload
ubi_alert
UBI Alert upload
Vibration Alarm
vibr_alarm
Vibration Alarm Setup
vibr: Enable Alarm
Where
where
Obtain real-time position
