Jimi IoT (Concox) JM-VL103
Concox JM-VL103 is a compact multifunctional 4G LTE vehicle GPS tracker. The device features GPS & BDS & LBS positioning, low voltage alert, remote listen-in, external buzzer, multiple alerts, 270 mAh battery, IP66 casing, and more.
Parameters (355)
Settings (11)
Flespi parses telemetry data from your Jimi IoT (Concox) JM-VL103 into a standardized JSON and lets you send commands to Jimi IoT (Concox) JM-VL103 via API.
    "device.type.id": "Jimi IoT (Concox) JM-VL103",
How to send commands to Jimi IoT (Concox) JM-VL103?
Protocol Number 0x39
Protocol Number 0x15
Configure APN parameters
auto: Auto APN
Center Number
center_number3
phone: Center Number
Defense Timeout
defense3
Defense timeout configuration
timeout: Defense Timeout
dvr_info
imsi: IMSI
iccid: ICCID
Displacement Alarm
move_alarm_vl103
Displacement Alarm Setup
move: Enable Alarm
Petrol/Electricity Control
relay
Petrol/electricity Control
Restart
Restart Scooter IoT module. Restart delay is 20 seconds.
Status
status
Update status of the device
GPS Tracking Interval
timer3
GPS Data Upload Time Interval
time_on: ACC On Upload Interval
time_off: ACC Off Upload Interval
Vibration Alarm
vibr_alarm_vl103
Vibration Alarm Setup
vibr: Enable Alarm
Where
where
Obtain real-time position
