Jimi IoT (Concox) JM-VL501
The VL501 is an easy-to-install vehicle tracker with GNSS, LTE, and Bluetooth for real-time monitoring and fleet management. It plugs into a cigarette lighter and features USB ports for device charging, built-in accelerometer and gyroscope, OTA updates, and multiple driving alerts.
Parameters (356)
Settings (4)
Flespi parses telemetry data from your Jimi IoT (Concox) JM-VL501 into a standardized JSON and lets you send commands to Jimi IoT (Concox) JM-VL501 via API.
    "device.type.id": "Jimi IoT (Concox) JM-VL501",
How to send commands to Jimi IoT (Concox) JM-VL501?
Protocol Number 0x39
Protocol Number 0x15
Harsh acceleration alarm setup
harsh_acc_alarm
detect: Enable Alarm
Harsh deceleration alarm setup
harsh_dec_alarm
Horisontal collision alarm setup
horisontal_collision
Power Alarm
power_alarm2
Power Alarm Setup
