Jimi IoT (Concox) JM-VL502
Concox JM-VL502 is a 4G Cat 1 OBDII vehicle GPS tracker with UBI-based algorithm for driving behavior analysis. The device features GPS & BDS positioning, fault, overspeeding, ignition detection, collision, geo-fence entry/exit, and other alerts, 4 kinds of dangerous driving behavior detection, 50 mAh battery, and more.
Parameters (376)
Settings (5)
Flespi parses telemetry data from your Jimi IoT (Concox) JM-VL502 into a standardized JSON and lets you send commands to Jimi IoT (Concox) JM-VL502 via API.
    "device.type.id": "Jimi IoT (Concox) JM-VL502",
How to send commands to Jimi IoT (Concox) JM-VL502?
Message ID 0x0010
Message ID 0x0010
Message ID 0x0010
Message ID 0x0010,
Message ID 0x0010
Message ID 0x0010,
Message ID 0x0010
Message ID 0x0010
Message ID 0x0010,
Message ID 0x0010,
Message ID 0x0010
Message ID 0x0010
Message ID 0x0010,
Message ID 0x0010,
Message ID 0x0010
Message ID 0x0010,
Message ID 0x0010,
Message ID 0x0010,
Message ID 0x0010
Message ID 0x0010,
Message ID 0x0010,
Message ID 0x0010,
Protocol Number 0x39
Protocol Number 0x15
Message ID 0x0010
Message ID 0x0010,
Message ID 0x0010,
Impact detection
impact_detection
Impact detection
detect: Enable
Harsh acceleration/deceleration alarm setup
speed_check
Harsh acceleration alarm setup
detect: Enable Alarm
Status
status
Update status of the device
version_vl502
Query FW version info
Where
where
Obtain real-time position
