Jimi IoT (Concox) JM-VL802
Concox JM-VL802 is an advanced 4G vehicle GPS tracker with two-way communication. The device features remote listen-in, ignition detection, Bluetooth configuration, panic button, remote cut-off, multiple alerts, 1,000 mAh battery, IP65 casing, and more.
Parameters (355)
Flespi parses telemetry data from your Jimi IoT (Concox) JM-VL802 into a standardized JSON and lets you send commands to Jimi IoT (Concox) JM-VL802 via API.
    "device.type.id": "Jimi IoT (Concox) JM-VL802",
How to send commands to Jimi IoT (Concox) JM-VL802?
Protocol Number 0x39
Protocol Number 0x15
Configure APN parameters
auto: Auto APN
Center Number
center_number3
phone: Center Number
Defense Timeout
defense3
Defense timeout configuration
timeout: Defense Timeout
dvr_info
imsi: IMSI
iccid: ICCID
Status
status
Update status of the device
GPS Tracking Interval
timer3
GPS Data Upload Time Interval
time_on: ACC On Upload Interval
time_off: ACC Off Upload Interval
Where
where
Obtain real-time position
