Jimi IoT (Concox) JS40
Concox JS40 is an electric scooter equipped with a 4G IoT module for easy sharing. The scooter features a powerful 350W motor suitable for riding up to 40km at the speed up to 30km/h, automatic charging termination, LED display to view battery life, speed and fault code, anti-vandal alarm, lightweight aluminum frame, and solid tires.
Concox JS40 configuration possibilities overview available on top of flespi.
Parameters (353)
Settings (36)
Flespi parses telemetry data from your Jimi IoT (Concox) JS40 into a standardized JSON and lets you send commands to Jimi IoT (Concox) JS40 via API.
    "device.type.id": "Jimi IoT (Concox) JS40",
How to send commands to Jimi IoT (Concox) JS40?
can.brake.pedal.status
Protocol Number 0x39
Protocol Number 0x15
Add Fence
add_fence
Add fence. It is possible to add up to 5 fences. To delete fence use corresponding setting. New fence will have the smallest vacant ID. New fence is created active by default. Use corresponding setting to inactivate fence.
lat: Latitude
lon: Longitude
radius: Radius
apn2
Configure APN parameters
auto: Auto APN
Brake Lights
bled
Brake lights settings. To change scooter settings, the scooter should be first switched to "Enabled" mode with corresponding setting.
Delete Fence
delete_fence
Delete fence by number.
num: Fence
imsi: IMSI
iccid: ICCID
chip_id: Chip ID
secret_key: Secret Key
software_ver: Software Version
bluetooth_mac: Bluetooth MAC
Additional Information
device_info2
Additional Device Information
user_id: User ID
motor_sn: Motor SN
device_sn: Device SN
battery_sn: Battery SN
Disable Scooter
disable
Disassemble Alarm
disassemble_alarm
Disassemble Alarm
Reset to Factory Defaults
ecu_reset
Reset scooter control unit to factory default settings
Scooter Parameters
ecuset
Scooter working parameters setup. To change scooter settings it should be first switched to "Enabled" mode with corresponding setting.
led: LED Mode
accel: Acceleration Mode
cruise: Automatic Cruise
zero_speed: Zero-Speed Startup
Information Packet Upload
ecutimer
Readtime information packet upload settings for different working modes
enabled: Enabled Mode
charging: Charging Mode
disabled: Disabled Mode
Enable Scooter
enable
Activate Fence
enable_fence
Activate or deactivate (open/close) fence by number.
num: Fence
enable: Activate
Fences
fences
This setting only displays fences that are configured for the device. Use corresponding settings to add, delete or activate/deactivate geofence.
fence1: Fence 1
fence2: Fence 2
fence3: Fence 3
fence4: Fence 4
fence5: Fence 5
Head Lights
fled
Head lights settings. To change scooter settings, the scooter should be first switched to "Enabled" mode with corresponding setting.
GPS ON
gpson
Temporarily enable GPS positioning
ival: Upload Interval
period: GPS ON Period
GPS Tracking Intervals
gtimer
GPS position detection intervals for various working modes
release: Release Mode
Heartbeat Interval
hbt
Set heartbeat interval.
hbt: Interval
Horn
horn
Horn output control
mode: Horn Output
Low Battery Alarm
iot_low_bat_alarm
Terminal low battery alarm
Shutdown Alarm
iot_shutdown_alarm
Terminal low power shutdown alarm
Lock Scooter
lock
Reset Mileage
mileage_reset
Clear the total mileage of the scooter. To reset mileage, the scooter should be first switched to "Enabled" mode with corresponding setting.
Restart
Restart Scooter IoT module. Restart delay is 20 seconds.
Scooter Low Power Alarm
scooter_low_power
Scooter battery low power alarm
Secondary Server Setup
secondary_server2
Configure secondary backend server parameters
mode: Host Mode
Server Connection Switch
secondary_server_attempts
Secondary server connection settings
switch: Enable
Sensitivity
sens_level
level: Level
Server Setup
server2
mode: Host Mode
Speed Limit
speedlimit
Scooter speed limit. To change scooter speed limit, the scooter should be first switched to "Enabled" mode with corresponding setting.
limit: Limit
Static Filter
static_filter
Static dright filtering mechanism settings
radius: Radius
Static Mode
staticrep
Static mode parameters
ival: Time Range
count: Detections Count
speed: Speed Level
last_pos: Last Position
Status
status
Update status of the device
Status
status_info
Scooter status. To update scooter status use corresponding command on Actions tab.
gps: GPS
gsm: GSM Signal Level
gprs: GPRS
battery: Battery
scooter: Scooter
Vibration Alarm
vibr_alarm2
Vibration alarm
Where
where
Obtain real-time position
