Jimi IoT (Concox) JV200
Concox JV200 a vehicle tracker relying on GSM+GPRS+GPS+AGPS wireless communication technology for fast positioning. The device features remote fuel/power cutoff, ignition status detection, speeding notifications, configurable tracking modes, multiple alarms.
Parameters (353)
Flespi parses telemetry data from your Jimi IoT (Concox) JV200 into a standardized JSON and lets you send commands to Jimi IoT (Concox) JV200 via API.
    "device.type.id": "Jimi IoT (Concox) JV200",
How to send commands to Jimi IoT (Concox) JV200?
can.brake.pedal.status
Protocol Number 0x39
Protocol Number 0x15
Configure APN parameters
Server Setup
comm: Communication Mode
mode: Host Mode
