Jimi IoT (Concox) Q2
Concox Q2 is a miniature personal GPS tracker featuring geo-fencing, low battery, SIM card change alert and other reporting features. The device has a 900mAh Li-polymer battery allowing it to work up to 6 days.
Parameters (372)
Flespi parses telemetry data from your Jimi IoT (Concox) Q2 into a standardized JSON and lets you send commands to Jimi IoT (Concox) Q2 via API.
    "device.type.id": "Jimi IoT (Concox) Q2",
How to send commands to Jimi IoT (Concox) Q2?
Message ID 0x0010
Message ID 0x0010
Message ID 0x0010
Message ID 0x0010,
Message ID 0x0010
Message ID 0x0010,
Message ID 0x0010
Message ID 0x0010
Message ID 0x0010,
Message ID 0x0010,
Message ID 0x0010
Message ID 0x0010
Message ID 0x0010,
Message ID 0x0010,
Message ID 0x0010
Message ID 0x0010,
Message ID 0x0010,
Message ID 0x0010,
Message ID 0x0010
Message ID 0x0010,
Message ID 0x0010,
Message ID 0x0010,
Protocol Number 0x39
Protocol Number 0x15
Message ID 0x0010
Message ID 0x0010,
Message ID 0x0010,
Configure APN parameters
Server Setup
comm: Communication Mode
mode: Host Mode
