Jimi IoT (Concox) Qbit
Concox Qbit personal GPS Tracker is a compact, lightweight monitoring solution for design for kids, the elderly, and people with special needs. the device features an SOS call & speed dial, geo-fencing, two-way audio and IPx5 waterproof casing.
Parameters (353)
Settings (3)
Flespi parses telemetry data from your Jimi IoT (Concox) Qbit into a standardized JSON and lets you send commands to Jimi IoT (Concox) Qbit via API.
    "device.type.id": "Jimi IoT (Concox) Qbit",
How to send commands to Jimi IoT (Concox) Qbit?
can.brake.pedal.status
Protocol Number 0x39
Protocol Number 0x15
Configure APN parameters
Server Setup
comm: Communication Mode
mode: Host Mode
Where
where
Obtain real-time position
