Digital Matter Oyster3 Global
Oyster3 Global is a long-life, ultra-rugged battery-powered GPS device designed for global asset tracking applications. It offers cellular 4G LTE Cat 1bis with 2G fallback for seamless global connectivity, adaptive tracking technology for energy conservation, waterproof and rugged IP68 housing, user-replaceable batteries ensuring 8+ years of life, impact and theft recovery alerts, and flexible configurations for various tracking applications.
Parameters (133)
Settings (10)
Commands (3)
Flespi parses telemetry data from your Digital Matter Oyster3 Global into a standardized JSON and lets you send commands to Digital Matter Oyster3 Global via API.
    "device.type.id": "Digital Matter Oyster3 Global",
How to send commands to Digital Matter Oyster3 Global?
accelerometer.wakeup.number
avg.acceleration
Average accelerometer value
battery.capacity.used
Battery Capacity Used
battery.capacity.used.initial
Battery Capacity Used Initial
battery.critical.alert
Percentage used on GNSS
Percentage used on LoRaWAN
Percentage used on sleeping
Percentage used on WiFi
battery.voltage.initial
beacon.uptime
Beacon uptime
ble.failures.count
BLE failures counter
ble.scans.count
BLE scans counter
ble.uptime
BLE uptime counter
charger.connections.count
Charger connections count
counter.rx.range
counter.tx.power
counter.uploads
counter.uploads.failed
counter.uploads.failed.time
counter.uploads.time
debug.level
Debug event level
debug.module.id
Debug event module id
device.run.time
Device run time
device.state.bitmask
Device state bitmask
device.temperature.max
ess.failed.exchanges
ess.successful.exchanges
Average Failed GPS Fix Time
gnss.average.fix.duration
gnss.average.refresh.time
Average GPS Freshen Time
gnss.position.fixes
gnss.position.fixes.failed
gnss.position.fixes.time
gnss.refresh.attempts
gnss.refresh.duration
gnss.sniffing.data.hex
gsm.arfcn
gsm.cellid.physical
gsm.cell.type
gsm.earfcn
gsm.network.type.enum
gsm.pcid
gsm.timing.difference
GSM timing difference
jostle.position.fixes
jostle.position.fixes.uploads
last.release.time
Last release time
loaded.battery.voltage
Loaded battery voltage
max.acceleration.duration
Peak G force
network.signal.rspq
pin.4.digit
4 digit PIN
pin.5.digit
5 digit PIN
position.fix.type
radar.failures.count
Radar failured count
radar.scans.count
Radar scans count
reboot.count
Message type 0x04
recovery.mode.status
Recovery Mode On/Off
Message type 0x04
resets.brownout.count
resets.count
Message type 0x04
sensor.sample.count
Sensor sample count
Message type 0x04
Message type 0x04
total.battery.consumption
cycles
Total battery consumption
total.release.attempts
Total release attempts
trip.average.wakeup.number
Average Wakeups Per Trip
trip.movement.trim.duration
Movement trip trimming amount
vehicle.odometer
wifi.channel
WiFi channel number
wifi.failed.scans
Count of failed Wi-Fi scans
wifi.scan.fail.time
Wi-Fi scan fail time
wifi.scan.success.time
Wi-Fi scan success time
wifi.successful.scans
accident_data
partition: Partition control
config_oem
Delete all System Parameters
delete_all_system_parameters
Modem Reset
modem_reset
Set Odometer
value: Odometer value
Set Operational Mode
operational_mode
Remote Reset
remote_reset
Set Run Hours
run_hours
value: Run hours value
Send message
send_message
Send a message to the device
message: Message text
Set and enable SIM PIN
sim_pin
pin: SIM PIN
Custom async command
cmd_body: Async Message Body
cmd_type: Async Message Type
Delete a System Parameter
delete_system_parameter
param_id: Parameter ID
Set a System Parameter
set_system_parameter
