Digital-matter protocol
Protocol used by GPS tracking devices manufactured by Digital Matter headquartered in Australia.
flespi parses the Digital-matter protocol messages into a JSON object with the fields listed below in the Parameters tab.
To connect your tracker using the Digital Matter protocol, you need to have a digital-matter channel created first. Point your tracker to the channel's domain name:port via SMS or configuration tool provided by the vendor to allow the device to send binary data to the server.
Devices that use this protocol determine their position using the built-in GPS module; accordingly, ready-to-use data is already transmitted to the server. This is important because the Edge series device does not have this capability. Edge devices determine their position using the location engine, which is located on the OEM server.
Device configuration
This protocol allows you to configure the device remotely using the async command "Set a System Parameter". The command will allow you to configure any system device parameter that is described in its XML configuration. For example:
<params size="3" id="1500" name="Speeding settings">
<binary>
<param name=...
The ID parameter must be entered in decimal form, as this is written in the XML configuration.
Parameter size will be taken into account automatically by the platform depending on the size of the data that the user entered in the “command data” field. The parameter data, if it consists of several bytes, must have little-endinbyte order. It is not possible to use the input in a more convenient form for the convenience of the user, since the server does not know in advance about the length of the parameter and its data.
For example, the parameter to set the value "Speeding Threshold" should be in HEX: DA0A (The speeding threshold is being set to 100km/h. Calculation is: 100/0.036 = 2778). The following parameter has a size of one byte "Speeding Delta" and must be written as is, also in the form HEX: 53.
As a result, the data will be wrapped by the server in accordance with the protocol, adding all the necessary parameters, including data size, type, version number and CRC.
Delete system parameter.
  • To delete a system parameter using the "Delete a system parameter" command. To do this, you only need to enter the parameter ID in decimal form.
  • To delete all parameters, you must use the "Delete all System Parameters" command.
accelerometer.wakeup.number
avg.acceleration
Average accelerometer value
battery.capacity.used
Battery Capacity Used
battery.capacity.used.initial
Battery Capacity Used Initial
battery.critical.alert
Percentage used on GNSS
Percentage used on LoRaWAN
Percentage used on sleeping
Percentage used on WiFi
battery.voltage.initial
beacon.uptime
Beacon uptime
ble.failures.count
BLE failures counter
ble.scans.count
BLE scans counter
ble.uptime
BLE uptime counter
charger.connections.count
Charger connections count
counter.rx.range
counter.tx.power
counter.uploads
counter.uploads.failed
counter.uploads.failed.time
counter.uploads.time
debug.level
Debug event level
debug.module.id
Debug event module id
device.run.time
Device run time
device.state.bitmask
Device state bitmask
device.temperature.max
ess.failed.exchanges
ess.successful.exchanges
Average Failed GPS Fix Time
gnss.average.fix.duration
gnss.average.refresh.time
Average GPS Freshen Time
gnss.position.fixes
gnss.position.fixes.failed
gnss.position.fixes.time
gnss.refresh.attempts
gnss.refresh.duration
gnss.sniffing.data.hex
gsm.arfcn
gsm.cellid.physical
gsm.cell.type
gsm.earfcn
gsm.network.type.enum
gsm.pcid
gsm.timing.difference
GSM timing difference
jostle.position.fixes
jostle.position.fixes.uploads
last.release.time
Last release time
loaded.battery.voltage
Loaded battery voltage
max.acceleration.duration
Peak G force
network.signal.rspq
pin.4.digit
4 digit PIN
pin.5.digit
5 digit PIN
position.fix.type
radar.failures.count
Radar failured count
radar.scans.count
Radar scans count
reboot.count
Message type 0x04
recovery.mode.status
Recovery Mode On/Off
Message type 0x04
resets.brownout.count
resets.count
Message type 0x04
sensor.sample.count
Sensor sample count
Message type 0x04
Message type 0x04
total.battery.consumption
cycles
Total battery consumption
total.release.attempts
Total release attempts
trip.average.wakeup.number
Average Wakeups Per Trip
trip.movement.trim.duration
Movement trip trimming amount
vehicle.odometer
wifi.channel
WiFi channel number
wifi.failed.scans
Count of failed Wi-Fi scans
wifi.scan.fail.time
Wi-Fi scan fail time
wifi.scan.success.time
Wi-Fi scan success time
wifi.successful.scans
Custom async command
cmd_body: Async Message Body
cmd_type: Async Message Type
Delete a System Parameter
delete_system_parameter
param_id: Parameter ID
set_system_parameter
