Eelink GPT47
Eelink GPT47 is an ultra-long standby LTE CAT-M1/NB-IoT GPS tracker designed for industrial asset monitoring. It features multi-constellation GNSS positioning (GPS, BDS, GLONASS) with WiFi and LBS assistance, delivering accurate location tracking. The device is powered by a built-in 12000mAh non-rechargeable lithium manganese battery offering up to 6 years of operation with one positioning point per day. It includes built-in temperature and humidity sensors, motion detection (vibration, drop, collision alarms), and light sensor for comprehensive asset monitoring. With its magnetic mounting, IP65 waterproof rating, and maintenance-free design, the GPT47 is ideal for tracking vehicles, pallets, containers, trailers, and cold chain logistics.
Parameters (79)
Settings (6)
Eelink GPT47
Flespi parses telemetry data from your Eelink GPT47 into a standardized JSON and lets you send commands to Eelink GPT47 via API.
    "device.type.id": "Eelink GPT47",
    "protocol.id": "eelink"
How to send commands to Eelink GPT47?
burnt.enery
calories
Accumulated burnt energy today
carbon.dioxide.alarm
CO2 concentration if out of predefined range
carbon.dioxide.ppm
Carbon dioxide concentration
gnss.antenna.open.circuit.status
GNSS antenna open-circuit status
illuminance.alarm
Illuminance if out of predefined range
message.content
Message content
pet.activity.duration
Duration of the pet activity state segment
pet.activity.state
Pet activity state (sleep, rest, walk, run)
pet.activity.state.enum
Pet activity state code
pet.rest.time
Pet resting time for the day
pet.run.time
Pet running time for the day
pet.sleep.time
Pet sleeping time for the day
pet.walk.time
Pet walking time for the day
report.timestamp
Report timestamp
sensor.temperature.alarm
Sensor temperature value is out of predefined ranges
total.burnt.enery
calories
Accumulated burnt energy in total
total.steps.count
Accumulated steps count in total
total.walk.distance
Accumulated walking distance in total
total.walk.time
Accumulated walking time in total
underspeed.event
Underspeed event
walk.distance
Accumulated walking distance today
walk.time
Accumulated walking time today
wifi.fence.mac.address
MAC address (BSSID) of the Wi-Fi fence access point
wifi.fence.signal.strength
Signal strength (RSSI) of the Wi-Fi fence access point
wifi.fence.ssid
SSID of the Wi-Fi fence access point
wifi.home.status
Home Wi-Fi location flag
Network Setup
apn_password: APN Password
apn_username: APN Username
Location Collection
collect
Time, distance and turn triggers are independent; zero omits a trigger.
turn: Turn
active: Active Interval
distance: Distance
quantity: Batch Size
TCP Heartbeat (HBT)
heartbeat_interval
interval: Heartbeat Interval
Server Setup
uri: Server URI
Sleep Sampling (SLEEP)
sleep_sampling
Temperature and humidity sampling during sleep. Zero disables sampling; this setting does not put the device to sleep.
interval: Sampling Interval
UDP Polling (POLLING)
udp_polling
UDP polling interval and timeout for reading the server response.
timeout: Response Timeout
interval: Polling Interval
Set heartbeat timer to 5 minutes
{"payload":"HBT,5#"}
Change time zone of the device to UTC
{"payload":"GMT,E,0,0,0#"}
