Eelink GPT48-X
Eelink GPT48-X is a magnetic LTE-M/NB-IoT asset tracker built on the Nordic nRF9160, designed for unpowered assets requiring long-term custody records. Features an 8000 mAh non-rechargeable lithium-manganese battery providing up to 4 years standby at one report per day. Supports 17 LTE-M bands and 15 NB-IoT bands with GPS L1 positioning. Magnetic mount enables tool-free 60-second installation on steel surfaces including containers, trailers, chassis, and site equipment. IP65-rated housing withstands dust and water jets. Four operating modes (Long Standby, Trip, Activity, Emergency) switch remotely over-the-air. Built-in accelerometer for motion detection and wake-on-movement. Temperature range -20°C to +65°C, weighs 130g.
Parameters (79)
Settings (6)
Eelink GPT48-X
Flespi parses telemetry data from your Eelink GPT48-X into a standardized JSON and lets you send commands to Eelink GPT48-X via API.
    "device.type.id": "Eelink GPT48-X",
    "protocol.id": "eelink"
How to send commands to Eelink GPT48-X?
burnt.enery
calories
Accumulated burnt energy today
carbon.dioxide.alarm
CO2 concentration if out of predefined range
carbon.dioxide.ppm
Carbon dioxide concentration
gnss.antenna.open.circuit.status
GNSS antenna open-circuit status
illuminance.alarm
Illuminance if out of predefined range
message.content
Message content
pet.activity.duration
Duration of the pet activity state segment
pet.activity.state
Pet activity state (sleep, rest, walk, run)
pet.activity.state.enum
Pet activity state code
pet.rest.time
Pet resting time for the day
pet.run.time
Pet running time for the day
pet.sleep.time
Pet sleeping time for the day
pet.walk.time
Pet walking time for the day
report.timestamp
Report timestamp
sensor.temperature.alarm
Sensor temperature value is out of predefined ranges
total.burnt.enery
calories
Accumulated burnt energy in total
total.steps.count
Accumulated steps count in total
total.walk.distance
Accumulated walking distance in total
total.walk.time
Accumulated walking time in total
underspeed.event
Underspeed event
walk.distance
Accumulated walking distance today
walk.time
Accumulated walking time today
wifi.fence.mac.address
MAC address (BSSID) of the Wi-Fi fence access point
wifi.fence.signal.strength
Signal strength (RSSI) of the Wi-Fi fence access point
wifi.fence.ssid
SSID of the Wi-Fi fence access point
wifi.home.status
Home Wi-Fi location flag
Network Setup
apn_password: APN Password
apn_username: APN Username
Location Collection
collect
Time, distance and turn triggers are independent; zero omits a trigger.
turn: Turn
active: Active Interval
distance: Distance
quantity: Batch Size
TCP Heartbeat (HBT)
heartbeat_interval
interval: Heartbeat Interval
Server Setup
uri: Server URI
Sleep Sampling (SLEEP)
sleep_sampling
Temperature and humidity sampling during sleep. Zero disables sampling; this setting does not put the device to sleep.
interval: Sampling Interval
UDP Polling (POLLING)
udp_polling
UDP polling interval and timeout for reading the server response.
timeout: Response Timeout
interval: Polling Interval
Set heartbeat timer to 5 minutes
{"payload":"HBT,5#"}
Change time zone of the device to UTC
{"payload":"GMT,E,0,0,0#"}
