Eelink GPT60
Eelink GPT60 is a compact 4G LTE wearable personal GPS tracker designed for seniors, children and personal safety tracking. It supports global LTE Cat1 FDD/TDD with GSM fallback and positions itself using GPS, BeiDou and GLONASS, with Wi-Fi positioning and LBS as backup. Accuracy is 5-15 m. A built-in microphone and speaker allow two-way calling, and an SOS button sends emergency alerts. Other alarms cover low battery, vibration, collision, falls, geo-fences and speeding. The tracker has a 600mAh rechargeable lithium battery, a magnetic USB charging connector, a Nano-SIM slot and an IP65 waterproof housing. It measures 60 x 45 x 19 mm and weighs 40 g. Other features include a whitelist, pedometer, remote monitoring and OTA firmware updates. It uses the Eelink 2.0 protocol and works with web platforms, mobile apps and SMS commands.
Parameters (79)
Settings (4)
Eelink GPT60
Flespi parses telemetry data from your Eelink GPT60 into a standardized JSON and lets you send commands to Eelink GPT60 via API.
    "device.type.id": "Eelink GPT60",
    "protocol.id": "eelink"
How to send commands to Eelink GPT60?
burnt.enery
calories
Accumulated burnt energy today
carbon.dioxide.alarm
CO2 concentration if out of predefined range
carbon.dioxide.ppm
Carbon dioxide concentration
gnss.antenna.open.circuit.status
GNSS antenna open-circuit status
illuminance.alarm
Illuminance if out of predefined range
message.content
Message content
pet.activity.duration
Duration of the pet activity state segment
pet.activity.state
Pet activity state (sleep, rest, walk, run)
pet.activity.state.enum
Pet activity state code
pet.rest.time
Pet resting time for the day
pet.run.time
Pet running time for the day
pet.sleep.time
Pet sleeping time for the day
pet.walk.time
Pet walking time for the day
report.timestamp
Report timestamp
sensor.temperature.alarm
Sensor temperature value is out of predefined ranges
total.burnt.enery
calories
Accumulated burnt energy in total
total.steps.count
Accumulated steps count in total
total.walk.distance
Accumulated walking distance in total
total.walk.time
Accumulated walking time in total
underspeed.event
Underspeed event
walk.distance
Accumulated walking distance today
walk.time
Accumulated walking time today
wifi.fence.mac.address
MAC address (BSSID) of the Wi-Fi fence access point
wifi.fence.signal.strength
Signal strength (RSSI) of the Wi-Fi fence access point
wifi.fence.ssid
SSID of the Wi-Fi fence access point
wifi.home.status
Home Wi-Fi location flag
Network Setup
apn_password: APN Password
apn_username: APN Username
Location Collection
collect
Time, distance and turn triggers are independent; zero omits a trigger.
turn: Turn
active: Active Interval
distance: Distance
quantity: Batch Size
TCP Heartbeat (HBT)
heartbeat_interval
interval: Heartbeat Interval
Server Setup
uri: Server URI
Set heartbeat timer to 5 minutes
{"payload":"HBT,5#"}
Change time zone of the device to UTC
{"payload":"GMT,E,0,0,0#"}
