Galileosky 10 C
Galileosky 10 C is a GPS/GLONASS terminal designed for vehicle monitoring, featuring Easy Logic technology, CAN bus data analysis, fuel and maintenance cost reduction, and driver error prevention. It includes 10 inputs, 4 outputs, built-in accelerometer, Eco Driving support, RS 485 and 1-Wire protocols for driver and equipment monitoring, and up to 16 fuel level sensors connectivity. The device supports 2G/3G/4G networks, Bluetooth 5.0, and has an internal 600 mAh battery for up to 8 hours of operation.
Parameters (297)
Commands (3)
Galileosky 10 C
Flespi parses telemetry data from your Galileosky 10 C into a standardized JSON and lets you send commands to Galileosky 10 C via API.
    "device.type.id": "Galileosky 10 C",
    "protocol.id": "galileosky"
How to send commands to Galileosky 10 C?
Tag 0x47
Tag 0x50...0x57,
Tag 0x78...0x7D
Tag 0x40
Tag 0x40
archive.records.count
Extended Tag 0xB3
archive.records.sent.count
Extended Tag 0xB3
Tag 0x42
before.maintenance.hours
Hours up to next maintenance
Tag 0x5B
beidou.average.snr
Extended Tag 0x90
beidou.max.snr
Extended Tag 0x90
Extended Tag 0x90
beidou.visible.satellites
Extended Tag 0x90
Extended Tag 0xAE
bluetooth.sensor.value
Extended Tag 0x21...0x60
Tag 0x47
brake.status
Brake status
Extended Tag 0x2965
bump.acceleration
Acceleration on bumps
Tag 0x47
can.16bit.value
Custom 16bit CAN value
Tag 0xB0...0xB9,
Tag 0xD6...0xDA
can.32bit.value
Custom 32bit CAN value
Tag 0xDB...0xDF,
Tag 0xF0...0xF9
can.8bit.value
Custom 8bit CAN value
Tag 0xA0...0xAF,
Tag 0xC4...0xD2
Extended Tag 0x32B3
Extended Tag 0x32AA
Extended Tag 0x293F
Extended Tag 0x293E
Extended Tag 0x272D
Extended Tag 0x2911
Extended Tag 0x374A
can.adblue.consumption.rate
Extended Tag 0x3602
Extended Tag 0x33B6
Extended Tag 0x33B4
Extended Tag 0x37DD
Extended Tag 0x34A8
Extended Tag 0x34A7
can.aftertreatment.fuel.rate
Extended Tag 0x34A9
Extended Tag 0x277B
can.auxiliary.io.sensor
Extended Tag 0x29CD...0x29DC,
Extended Tag 0x3610...0x366F
Extended Tag 0x277C
can.battery.net.current
Extended Tag 0x2782
Extended Tag 0x2919
can.cargo.ambient.temperature
Extended Tag 0x27B9
Extended Tag 0x2780
Extended Tag 0x3CCE
Extended Tag 0x2726
can.cruise.control.speed
Extended Tag 0x2766
Extended Tag 0x291F
Extended Tag 0x2963
Extended Tag 0x3584
Extended Tag 0x375F
can.dpf.inlet.pressure
Extended Tag 0x3529
can.dpf.lamp.command
Extended Tag 0x3581
Extended Tag 0x3583
Extended Tag 0x35B6
Extended Tag 0x3589
Extended Tag 0x3588
Extended Tag 0x3587
Extended Tag 0x3D0D
Extended Tag 0x3586
Extended Tag 0x3C6A
can.dpf.status
Extended Tag 0x3585
Extended Tag 0x3599
can.driver.card.status
CAN-bus driver card presence
Extended Tag 0x2D5F
Extended Tag 0x2910
Extended Tag 0x2DC3
Extended Tag 0x2D61
can.driver.work.state.enum
Extended Tag 0x2D5C
can.egr.valve.position
Extended Tag 0x35FE
Extended Tag 0x6295
Extended Tag 0x2BC3
Extended Tag 0x2BCC
Extended Tag 0x277F
Extended Tag 0x2724
can.engine.coolant.pressure.2
Engine coolant pressure 2 read from CAN
Extended Tag 0x277D
Extended Tag 0x277E
can.engine.crankcase.pressure
Engine crankcase pressure
Extended Tag 0x2775
Extended Tag 0x3090
Extended Tag 0x2913
Extended Tag 0x33B7
Extended Tag 0x27BD
can.engine.fan.bypass.switch
Extended Tag 0x7D84
can.engine.fan.reverse.switch
Extended Tag 0x7D83
can.engine.fan.speed.percent
Extended Tag 0x2ADF
Extended Tag 0x27C7
Extended Tag 0x295E
Extended Tag 0x2744
Extended Tag 0x2B7E
Extended Tag 0x276C
Extended Tag 0x2807
Extended Tag 0x443F
Extended Tag 0x34ED
Extended Tag 0x2772
Extended Tag 0x2C74
Extended Tag 0x2774
can.engine.oil.priming.state
Extended Tag 0x34EF
Extended Tag 0x27BF
Extended Tag 0x32B2
Extended Tag 0x2B63
Extended Tag 0x376F
Extended Tag 0x2916
can.engine.revolutions
Extended Tag 0x2809
Extended Tag 0x27CE,
Tag 0xC1
can.engine.rpm.limit
Extended Tag 0x2A92
Tag 0xC1
Extended Tag 0x342D
Extended Tag 0x2A93
Extended Tag 0x27C0
can.engine.ventilation.status
Extended Tag 0x34F2
can.engine.wait.to.start.lamp
Extended Tag 0x2B49
Extended Tag 0x34EC
can.estimated.pumping.torque
Extended Tag 0x3C26
Extended Tag 0x3582
can.fan.drive.bypass.command
Extended Tag 0x3784
can.fan.drive.state
Fan drive state read from CAN
Extended Tag 0x2AE1
Extended Tag 0x280A,
Tag 0xC0
Extended Tag 0x3ACE
can.fuel.delivery.pressure
Extended Tag 0x276E
Extended Tag 0x27C8
Extended Tag 0x276F
Extended Tag 0x2C76
Extended Tag 0x2770,
Tag 0xC1
can.fuel.level.2
Extended Tag 0x2736
Extended Tag 0x2C75,
Extended Tag 0x42D0
Extended Tag 0x27BE
Extended Tag 0x291B
Extended Tag 0x291C
Extended Tag 0x3783
Extended Tag 0x27BA
Extended Tag 0x277A
Extended Tag 0x27BC
Extended Tag 0x3BD0
Intake manifold temperature
Extended Tag 0x2779
can.message.checksum
CAN message checksum
Extended Tag 0x377F
can.message.counter
CAN message counter
Extended Tag 0x377E
Extended Tag 0x47FC
can.nominal.friction.torque
Extended Tag 0x2912
Extended Tag 0x2756
Extended Tag 0x2966
Extended Tag 0x2AE0,
Extended Tag 0x367C
Extended Tag 0x2ADE
can.retarder.selection
Extended Tag 0x2CD8,
Extended Tag 0x2DC4
can.retarder.torque.intended
Extended Tag 0x2B4D
can.retarder.torque.mode
Extended Tag 0x2A94
Extended Tag 0x2CAD
can.road.surface.temperature
Extended Tag 0x275F
can.scr.conversion.efficiency
Extended Tag 0x381C
Extended Tag 0x3803
Extended Tag 0x3093
Extended Tag 0x596D
can.sensor.value.b
CAN B sensor value
Tag 0xC3
Extended Tag 0x2AA2
can.steering.axle.temperature
Extended Tag 0x275B
can.tacho.overspeeding.event
CAN tacho vehicle overspeed
Extended Tag 0x2D5E
Extended Tag 0x2D67,
Extended Tag 0x2D68
CAN tacho direction indicator
Extended Tag 0x2D63
Extended Tag 0x276B
Extended Tag 0x2743
can.throttle.valve.2.position
Extended Tag 0x3569
can.transmission.input.speed
Extended Tag 0x27B1
Extended Tag 0x27C6
Extended Tag 0x3ACD
Extended Tag 0x2AA6
can.tsc1.control.purpose
Extended Tag 0x3426
can.tsc1.transmission.rate
Extended Tag 0x3425
can.utility.ac.frequency
Extended Tag 0x30B9
Extended Tag 0x27AE
Extended Tag 0x2805,
Tag 0xC2
Extended Tag 0x2AA5
can.washer.fluid.level
Extended Tag 0x2760
Extended Tag 0x2764
cell.location.error.meters
Tag 0x35
connection.state
Connection state
Tag 0x48
datacold500.engine.motorhours
DataCOLD500 engine motorhours
Tag 0x5B
Tag 0x5B
datacold500.total.motorhours
Tag 0x5B
Tag 0x43
device.wifi.mac.address
Extended Tag 0xAD
Tag 0x46
dosimeter.dbgc11d.ader
sv/h
DBG-C11D dosimeter ADER value
Tag 0x5D
Tag 0x5D
Tag 0x5D
Tag 0x5D
Tag 0x5D
Tag 0x45
Extended Tag 0x275A
Tag 0x40
euroscan.diesel.motorhours
EuroScan diesel motorhours
Tag 0x5B
euroscan.electric.motorhours
EuroScan electric motorhours
Tag 0x5B
euroscan.standby.motorhours
EuroScan standby motorhours
Tag 0x5B
Tag 0x41
Tag 0x40
galileo.average.snr
Extended Tag 0x91
galileo.max.snr
Extended Tag 0x91
galileo.position.satellites
Extended Tag 0x91
galileo.visible.satellites
Extended Tag 0x91
Tag 0x40
glonass.average.snr
Extended Tag 0x8F
glonass.max.snr
Extended Tag 0x8F
glonass.position.satellites
Extended Tag 0x8F
glonass.visible.satellites
Extended Tag 0x8F
Tag 0x40
gnss.type
Tag 0x40
gps.average.snr
Extended Tag 0x8E
gps.max.snr
Extended Tag 0x8E
Extended Tag 0x8E
gps.visible.satellites
Extended Tag 0x8E
Extended Tag 0x81
Tag 0x48
Extended Tag 0x82
Extended Tag 0x83
Extended Tag 0x84
Tag 0x48
Extended Tag 0x85
Tag 0x40
Extended Tag 0x94
Extended Tag 0x92
Tag 0x40
hardware.version.enum
Hardware version enum
Tag 0x01
Extended Tag 0xFD,
Extended Tag 0xFE,
Tag 0x90,
Tag 0xD3
Tag 0x40
ibutton.connection.status
iButton key connected status
Tag 0xD5
incline.event
Incline exceeds allowed level
Tag 0x40
Tag 0x40
Tag 0x40
modbus.sensor.value
Extended Tag 0x01...0x20,
Extended Tag 0x61...0x80
modem.state.enum
Extended Tag 0xA6
Tag 0x40
network.type.enum
Transmission channel
Tag 0x49
Tag 0x80...0x87
Tag 0x80...0x87
Tag 0x34
Tag 0x33
Tag 0x35
Tag 0x30
Tag 0x30
Tag 0x36
Tag 0x33
Tag 0x30
Tag 0x10
refrigerator.alarm.enum
Refrigerator alarm code
Tag 0x5B
refrigerator.alarm.type.enum
Tag 0x5B
Tag 0x5B
Tag 0x5B
refrigerator.din
Tag 0x5B
Tag 0x5B
refrigerator.emergency.status
Refrigerator emergency status
Tag 0x5B
refrigerator.engine.mode
Tag 0x5B
refrigerator.engine.mode.enum
Tag 0x5B
refrigerator.engine.rpm
Refrigerator engine RPM
Tag 0x5B
Tag 0x5B
Tag 0x5B
refrigerator.operate.mode
Tag 0x5B
Tag 0x5B
Tag 0x5B
Tag 0x5B
Tag 0x5B
refrigerator.set.temperature
Tag 0x5B
refrigerator.troublecode.enum
Tag 0x5B
rep500.counter.value
Tag 0x5A
Extended Tag 0xFC
rs232.sensor.value
Custom RS232 sensor value
Tag 0x58,
Tag 0x59
Tag 0x63...0x6F,
Tag 0x8A...0x8C
Tag 0x60...0x62,
Tag 0x63...0x6F
Extended Tag 0x86...0x8D,
Tag 0x70...0x77
sensor.temperature.id
ID of temperature sensor
Tag 0x40
sim.card.slot
Currently used SIM card slot
Extended Tag 0x93
software.version.enum
Software version enum
Tag 0x02
Extended Tag 0x2D69
thermoking.accident.enum
ThermoKing accident enum
Tag 0x5B
Tag 0x5B
thermoking.engine.motorhours
ThermoKing engine motorhours
Tag 0x5B
thermoking.total.motorhours
Tag 0x5B
Tag 0x20,
Tag 0x21
Tag 0x5C
Tag 0x5C
tire.sensor.connection.status
Tire sensor connection status
Tag 0x5C
tire.sensor.reason
Tag 0x5C
Tag 0x5C
Extended Tag 0xD9...0xFA
Extended Tag 0x273E
Tag 0x47
user.data.hex
User data array in HEX
Tag 0xEA
user.data.value
User data value
Tag 0xE2...0xE9
Tag 0xD4
wifi.error.enum
Extended Tag 0xA5
wifi.module.status.enum
Extended Tag 0xA4
Tag 0x44
Tag 0x44
Tag 0x44
Authorize phone number
add_number
Reboot Device
CLEARSCRIPT command
clear_script
username: EasyLogic Username
scriptname: Script name
Track parameters setup
Activate digital output 3
{"payload":"Out 2,1"}
{"payload":"SCRIPT"}
Set SCRIPT command
set_script
