Galileosky 10 Pro
Galileosky 10 Pro is a GPS/GLONASS terminal for advanced vehicle management with CAN bus data decoding and Easy Logic technology for flexible fleet management settings. It supports dual SIM, Bluetooth interface, multiple sensor and device control via RS 485, RS 232, and 1-Wire protocols. Compact in size with dimensions of 99x66.5x25.5 mm, it can process weak sensor signals and has a built-in accelerometer, 600 mA/h Li-Ion battery, and comes with various configuration options.
Parameters (567)
Commands (3)
Galileosky 10 Pro
Flespi parses telemetry data from your Galileosky 10 Pro into a standardized JSON and lets you send commands to Galileosky 10 Pro via API.
    "device.type.id": "Galileosky 10 Pro",
    "protocol.id": "galileosky"
How to send commands to Galileosky 10 Pro?
Tag 0x47
Tag 0x50...0x57,
Tag 0x78...0x7D
Tag 0x40
Tag 0x40
archive.records.count
Extended Tag 0xB3
archive.records.sent.count
Extended Tag 0xB3
Tag 0x42
before.maintenance.hours
Hours up to next maintenance
Tag 0x5B
beidou.average.snr
Extended Tag 0x90
beidou.max.snr
Extended Tag 0x90
Extended Tag 0x90
beidou.visible.satellites
Extended Tag 0x90
Extended Tag 0xAE
bluetooth.sensor.value
Extended Tag 0x21...0x60
Tag 0x47
brake.status
Brake status
Extended Tag 0x2965
bump.acceleration
Acceleration on bumps
Tag 0x47
can.16bit.value
Custom 16bit CAN value
Tag 0xB0...0xB9,
Tag 0xD6...0xDA
can.32bit.value
Custom 32bit CAN value
Tag 0xDB...0xDF,
Tag 0xF0...0xF9
can.8bit.value
Custom 8bit CAN value
Tag 0xA0...0xAF,
Tag 0xC4...0xD2
can.abs.active
Extended Tag 0x2943
Extended Tag 0x2CAE
can.abs.fully.operational
Extended Tag 0x2BEB
can.abs.offroad.switch
Extended Tag 0x294F
Extended Tag 0x7A36
can.ac.auto.mode.switch
Extended Tag 0x7A33
Extended Tag 0x32B3
Extended Tag 0x2ADC
Extended Tag 0x32AA
Extended Tag 0x293F
Extended Tag 0x293E
Extended Tag 0x272D
Extended Tag 0x3141
can.ac.compressor.status
Extended Tag 0x45BD
Extended Tag 0x7A32
can.ac.evaporator.temperature
Extended Tag 0x2D1B
Extended Tag 0x2AE9
Extended Tag 0x7A34
Extended Tag 0x7A35
Extended Tag 0x2911
Extended Tag 0x374A
can.adblue.consumption.rate
Extended Tag 0x3602
Extended Tag 0x33B8
Extended Tag 0x33B6
Extended Tag 0x33B4
Extended Tag 0x3711
Extended Tag 0x34AA
Extended Tag 0x37DD
Extended Tag 0x34A8
Extended Tag 0x34A7
can.aftertreatment.fuel.rate
Extended Tag 0x34A9
can.aftertreatment.ignition
Extended Tag 0x34AC
Extended Tag 0x34AB
can.air.compressor.status
Extended Tag 0x2C57
Extended Tag 0x277B
Extended Tag 0x2B52
Extended Tag 0x2783
can.alternator.speed
Extended Tag 0x295D
Extended Tag 0x27BB
can.asr.brake.control.active
Extended Tag 0x2942
can.asr.engine.control.active
Extended Tag 0x2941
can.asr.hill.holder.switch
Extended Tag 0x2951
can.asr.offroad.switch
Extended Tag 0x2950
Extended Tag 0x2E11
Extended Tag 0x2B51
can.auxiliary.io.sensor
Extended Tag 0x29CD...0x29DC,
Extended Tag 0x3610...0x366F
Extended Tag 0x2956
Extended Tag 0x277C
can.battery.net.current
Extended Tag 0x2782
can.battery.potential
Extended Tag 0x27B8
Extended Tag 0x2CD9
Extended Tag 0x2919
Extended Tag 0x7998
can.cargo.ambient.temperature
Extended Tag 0x27B9
can.charging.system.voltage
Extended Tag 0x27B7
can.clutch.slip
Extended Tag 0x291A
Extended Tag 0x2780
Extended Tag 0x3CCE
Extended Tag 0x2726
Extended Tag 0x296A
Extended Tag 0x2968
Extended Tag 0x2964
Extended Tag 0x2768
Extended Tag 0x2D71
Extended Tag 0x2969
can.cruise.control.set.switch
Extended Tag 0x2967
can.cruise.control.speed
Extended Tag 0x2766
Extended Tag 0x291F
Extended Tag 0x2963
Extended Tag 0x29C1
Extended Tag 0x29C2
Extended Tag 0x29C3
Extended Tag 0x29BD
Extended Tag 0x29BE
Extended Tag 0x29BF
Extended Tag 0x29C0
Extended Tag 0x3584
can.dpf.ash.load.percent
Extended Tag 0x3598
Extended Tag 0x3596
Extended Tag 0x375F
can.dpf.inlet.pressure
Extended Tag 0x2761,
Extended Tag 0x3529
can.dpf.lamp.command
Extended Tag 0x3581
Extended Tag 0x3583
Extended Tag 0x35B6
Extended Tag 0x358B
Extended Tag 0x3589
Extended Tag 0x3588
Extended Tag 0x3594
Extended Tag 0x358F
Extended Tag 0x358C
Extended Tag 0x358E
Extended Tag 0x3593
Extended Tag 0x358A
Extended Tag 0x358D
Extended Tag 0x3595
Extended Tag 0x3587
Extended Tag 0x3590
Extended Tag 0x3592
Extended Tag 0x4EB9
Extended Tag 0x3591
Extended Tag 0x3D0D
Extended Tag 0x3586
can.dpf.soot.load.percent
Extended Tag 0x3597
Extended Tag 0x3C6A
can.dpf.status
Extended Tag 0x3585
Extended Tag 0x3C27
Extended Tag 0x3599
Extended Tag 0x2953
can.drive.axle.location
Extended Tag 0x2AB2
can.drive.axle.temperature
Extended Tag 0x2952
can.driver.2.card.status
Extended Tag 0x2D60
Extended Tag 0x2D62
can.driver.2.work.state.enum
Extended Tag 0x2D5D
can.driver.card.status
CAN-bus driver card presence
Extended Tag 0x2D5F
Extended Tag 0x2910
Extended Tag 0x2DC3
Extended Tag 0x2D61
can.driver.work.state.enum
Extended Tag 0x2D5C
can.ebs.brake.switch
Extended Tag 0x2B71
can.ebs.red.warning.signal
Extended Tag 0x2CAF
can.ecu.mileage
Extended Tag 0x2B18
can.egr.valve.position
Extended Tag 0x272B,
Extended Tag 0x35FE
Extended Tag 0x6295
Extended Tag 0x320D
can.engine.air.shutoff.status
Extended Tag 0x3563
can.engine.alarm.acknowledge
Extended Tag 0x320F
Extended Tag 0x320E
Extended Tag 0x2BC3
Extended Tag 0x2BCC
Extended Tag 0x2ADA
Extended Tag 0x2CDB
Extended Tag 0x277F
Extended Tag 0x2B4A
Extended Tag 0x34F1
Extended Tag 0x2724
can.engine.coolant.pressure.2
Extended Tag 0x277D,
Extended Tag 0x43A1
Extended Tag 0x4829
Extended Tag 0x277E
Extended Tag 0x2D75
Extended Tag 0x3C54
can.engine.crankcase.pressure
Engine crankcase pressure
Extended Tag 0x2775
Extended Tag 0x3090
can.engine.derate.switch
Extended Tag 0x2ADB
Extended Tag 0x2913
Extended Tag 0x2917
Extended Tag 0x2AD6
Extended Tag 0x33B5
Extended Tag 0x33B7
Extended Tag 0x27BD
can.engine.fan.bypass.switch
Extended Tag 0x7D84
can.engine.fan.reverse.switch
Extended Tag 0x7D83
can.engine.fan.speed.percent
Extended Tag 0x2ADF
Extended Tag 0x27C7
Extended Tag 0x2AD7
Extended Tag 0x2AD8
Extended Tag 0x2962
Extended Tag 0x2961
Extended Tag 0x295F
Extended Tag 0x2960
Extended Tag 0x295E
Extended Tag 0x2744
Extended Tag 0x2B7E
Extended Tag 0x276C
can.engine.max.power.enable
Extended Tag 0x3AA7
Extended Tag 0x3AAD
Extended Tag 0x296E
Extended Tag 0x2807
Extended Tag 0x2773
Extended Tag 0x443F
Extended Tag 0x34ED
Extended Tag 0x2772
Extended Tag 0x2C74
Extended Tag 0x2873
Extended Tag 0x34F0
Extended Tag 0x2774
Extended Tag 0x46EF
Extended Tag 0x34EE
can.engine.oil.priming.state
Extended Tag 0x34EF
Extended Tag 0x27BF
Extended Tag 0x29C7
can.engine.overspeed.test
Extended Tag 0x320C
Extended Tag 0x32B2
Extended Tag 0x2B65
Extended Tag 0x2B67
Extended Tag 0x2B66
Extended Tag 0x2B64
Extended Tag 0x2B63
Extended Tag 0x29C8
Extended Tag 0x376F
Extended Tag 0x2916
can.engine.retarder.selection
Extended Tag 0x2ADD
can.engine.revolutions
Extended Tag 0x2809
Extended Tag 0x27CE,
Tag 0xC1
can.engine.rpm.limit
Extended Tag 0x2A92
Extended Tag 0x2BE5
can.engine.speed
Engine speed read from CAN
Extended Tag 0x2808
can.engine.starter.mode
Extended Tag 0x2D9B
Tag 0xC1
Extended Tag 0x342D
Extended Tag 0x2A93
Extended Tag 0x2BA8
Extended Tag 0x2BA4
Extended Tag 0x27C0
can.engine.turbocharger.speed
Extended Tag 0x2777
can.engine.ventilation.status
Extended Tag 0x34F2
can.engine.wait.to.start.lamp
Extended Tag 0x2B49
Extended Tag 0x34EC
can.estimated.pumping.torque
Extended Tag 0x3C26
Extended Tag 0x3582
can.fan.drive.bypass.command
Extended Tag 0x3784
can.fan.drive.state
Fan drive state read from CAN
Extended Tag 0x2AE1
can.fan.speed
Fan speed read from CAN
Extended Tag 0x2D77
can.front.axle.speed
Extended Tag 0x2A98
Extended Tag 0x280A,
Tag 0xC0
Extended Tag 0x3ACE
can.fuel.delivery.pressure
Extended Tag 0x276E
Extended Tag 0x27C8
can.fuel.economy.average
Extended Tag 0x27C9
Extended Tag 0x276F
Extended Tag 0x2C76
Extended Tag 0x2770,
Tag 0xC1
can.fuel.level.2
Extended Tag 0x2736
can.fuel.pump.primer.status
Extended Tag 0x3703
Extended Tag 0x2C75,
Extended Tag 0x42D0
Extended Tag 0x27BE
Extended Tag 0x291B
can.gear.ratio
Extended Tag 0x2955
can.gear.requested
Extended Tag 0x291D
can.gear.requested.feedback
Extended Tag 0x33E9
Extended Tag 0x291C
can.halt.brake.switch
Extended Tag 0x326F
Extended Tag 0x64B3
Extended Tag 0x3783
Extended Tag 0x3C90
can.idle.fuel.consumed
Extended Tag 0x27FC
can.illumination.brightness
Extended Tag 0x2CDF
Extended Tag 0x27BA
Extended Tag 0x277A
Extended Tag 0x27BC
Extended Tag 0x3BD0
can.intake.manifold.pressure
Extended Tag 0x2776
Intake manifold temperature
Extended Tag 0x2779
can.inverter.rate.limits.crc
Extended Tag 0x560A
can.lateral.acceleration
Extended Tag 0x2E21
can.longitudinal.acceleration
Extended Tag 0x2E22
Extended Tag 0x7D85
can.message.checksum
CAN message checksum
Extended Tag 0x377F
can.message.counter
CAN message counter
Extended Tag 0x377E
Extended Tag 0x47FC
can.nominal.friction.torque
Extended Tag 0x2912
can.nox.mass.bin
Extended Tag 0x580A
Extended Tag 0x5A27
Extended Tag 0x5A28
Extended Tag 0x2A91
Extended Tag 0x35EF
Extended Tag 0x2756
Extended Tag 0x2B4E
Extended Tag 0x2966
can.pitch.angle
Extended Tag 0x2957
can.position.altitude
Extended Tag 0x2954
can.position.latitude
Extended Tag 0x2958
can.position.longitude
Extended Tag 0x2959
Extended Tag 0x3FB1
can.progressive.shift.disable
Extended Tag 0x296F
Extended Tag 0x2AE4
can.pto.oil.temperature
Extended Tag 0x276A
Extended Tag 0x3C2C
Extended Tag 0x2AE0,
Extended Tag 0x367C
can.railroad.mode.switch
Extended Tag 0x4615
Extended Tag 0x2A9B
Extended Tag 0x296D
Extended Tag 0x2A7B
Extended Tag 0x2AD9
Extended Tag 0x2ADE
can.retarder.actual.torque
Extended Tag 0x2918
Extended Tag 0x2DC5
Extended Tag 0x294B
can.retarder.oil.temperature
Extended Tag 0x2788
Extended Tag 0x2D93
Extended Tag 0x379A
Extended Tag 0x3799
can.retarder.selection
Extended Tag 0x2CD8,
Extended Tag 0x2DC4
Extended Tag 0x294C
can.retarder.torque.intended
Extended Tag 0x2B4D
can.retarder.torque.mode
Extended Tag 0x2A94
Extended Tag 0x2CAD
can.road.surface.temperature
Extended Tag 0x275F
Extended Tag 0x3604
can.scr.conversion.efficiency
Extended Tag 0x381C
Extended Tag 0x3803
Extended Tag 0x3C67
Extended Tag 0x33A0
Extended Tag 0x4460
Extended Tag 0x3C28
Extended Tag 0x3093
Extended Tag 0x596D
can.sensor.value.b
CAN B sensor value
Tag 0xC3
Extended Tag 0x2B4F
Extended Tag 0x2B50
Extended Tag 0x2AA2
can.spn.11732
Extended Tag 0x54E4
can.spn.8857
Extended Tag 0x49A9
Extended Tag 0x2E1F
Extended Tag 0x2E24
can.steering.axle.temperature
Extended Tag 0x275B
Extended Tag 0x2E23
Extended Tag 0x3CAC
Extended Tag 0x41B4
can.tacho.event
Extended Tag 0x2D66
Extended Tag 0x2D65
can.tacho.motion.status
Extended Tag 0x2D5B
can.tacho.overspeeding.event
CAN tacho vehicle overspeed
Extended Tag 0x2D5E
can.tacho.performance.enum
CAN tachograph performance
Extended Tag 0x2D64
Extended Tag 0x2D67,
Extended Tag 0x2D68
CAN tacho direction indicator
Extended Tag 0x2D63
Extended Tag 0x276B
Extended Tag 0x2743
can.throttle.valve.2.position
Extended Tag 0x3569
can.timestamp
Tag 0xFE
Extended Tag 0x27FB
can.total.fuel.used
Extended Tag 0x2806
Extended Tag 0x2BE6
can.trailer.abs.status
Extended Tag 0x2E3C
Extended Tag 0x2E10
Extended Tag 0x3291
Extended Tag 0x291E
Extended Tag 0x40B6
Extended Tag 0x451F
Extended Tag 0x4520
Extended Tag 0x3ACC
Extended Tag 0x278B
Extended Tag 0x54F5
Extended Tag 0x2CDA
Extended Tag 0x27B3
Extended Tag 0x3760
Extended Tag 0x29BB
Extended Tag 0x2940
Extended Tag 0x3264
Extended Tag 0x278E
Extended Tag 0x29B9
can.transmission.input.speed
Extended Tag 0x27B1
Extended Tag 0x54F3
Extended Tag 0x3D92
Extended Tag 0x79F7
Extended Tag 0x4773
can.transmission.mode.1
Extended Tag 0x2E4C
Extended Tag 0x40B8
Extended Tag 0x30F8
can.transmission.mode.2
Extended Tag 0x2E4D
Extended Tag 0x30F9
can.transmission.mode.3
Extended Tag 0x2E4E
Extended Tag 0x30FA
can.transmission.mode.4
Extended Tag 0x2E4F
Extended Tag 0x30FB
can.transmission.mode.5
Extended Tag 0x37A6
Extended Tag 0x37AA
can.transmission.mode.6
Extended Tag 0x37A7
Extended Tag 0x37AB
can.transmission.mode.7
Extended Tag 0x37A8
Extended Tag 0x37AC
can.transmission.mode.8
Extended Tag 0x37A9
Extended Tag 0x37AD
Extended Tag 0x40B7
Extended Tag 0x342F
can.transmission.oil.level
Extended Tag 0x278C
Extended Tag 0x3E2B
Extended Tag 0x3E2A
Extended Tag 0x3E2C
Extended Tag 0x32E4
Extended Tag 0x32E3
Extended Tag 0x32E2
Extended Tag 0x34DD
can.transmission.oil.life
Extended Tag 0x3761
can.transmission.oil.pressure
Extended Tag 0x278F
Extended Tag 0x27C1
Extended Tag 0x3E29
Extended Tag 0x27CF
Extended Tag 0x3BF1
Extended Tag 0x54F4
Extended Tag 0x331E
Extended Tag 0x29BC
Extended Tag 0x37AF
Extended Tag 0x27B2
Extended Tag 0x2E4A
Extended Tag 0x2E49
Extended Tag 0x37A2
Extended Tag 0x37B5
Extended Tag 0x3762
Extended Tag 0x2E4B
Extended Tag 0x4EB8
Extended Tag 0x294E
Extended Tag 0x32B9
Extended Tag 0x294D
Extended Tag 0x4EB6
Extended Tag 0x4EB7
Extended Tag 0x29BA
Extended Tag 0x39E0
Extended Tag 0x35FF
Extended Tag 0x32E6
Extended Tag 0x3BF0
Extended Tag 0x27C6
Extended Tag 0x3ACD
Extended Tag 0x2804,
Extended Tag 0x2AA6
can.tsc1.control.purpose
Extended Tag 0x3426
can.tsc1.transmission.rate
Extended Tag 0x3425
can.utility.ac.frequency
Extended Tag 0x30B9
Extended Tag 0x27AE
can.vehicle.make
Extended Tag 0x295A
Extended Tag 0x2805,
Tag 0xC2
Extended Tag 0x2AA5
can.vehicle.model
Extended Tag 0x295B
can.vehicle.serial.number
Extended Tag 0x295C
can.washer.fluid.level
Extended Tag 0x2760
Extended Tag 0x2771
Extended Tag 0x2764
Extended Tag 0x2E20
cell.location.error.meters
Tag 0x35
connection.state
Connection state
Tag 0x48
datacold500.engine.motorhours
DataCOLD500 engine motorhours
Tag 0x5B
Tag 0x5B
datacold500.total.motorhours
Tag 0x5B
Tag 0x43
device.wifi.mac.address
Extended Tag 0xAD
Tag 0x46
dosimeter.dbgc11d.ader
sv/h
DBG-C11D dosimeter ADER value
Tag 0x5D
Tag 0x5D
Tag 0x5D
Tag 0x5D
Tag 0x5D
Tag 0x45
Extended Tag 0x275A
Tag 0x40
euroscan.diesel.motorhours
EuroScan diesel motorhours
Tag 0x5B
euroscan.electric.motorhours
EuroScan electric motorhours
Tag 0x5B
euroscan.standby.motorhours
EuroScan standby motorhours
Tag 0x5B
Tag 0x41
Tag 0x40
galileo.average.snr
Extended Tag 0x91
galileo.max.snr
Extended Tag 0x91
galileo.position.satellites
Extended Tag 0x91
galileo.visible.satellites
Extended Tag 0x91
Tag 0x40
glonass.average.snr
Extended Tag 0x8F
glonass.max.snr
Extended Tag 0x8F
glonass.position.satellites
Extended Tag 0x8F
glonass.visible.satellites
Extended Tag 0x8F
Tag 0x40
gnss.type
Tag 0x40
gps.average.snr
Extended Tag 0x8E
gps.max.snr
Extended Tag 0x8E
Extended Tag 0x8E
gps.visible.satellites
Extended Tag 0x8E
Extended Tag 0x81
Tag 0x48
Extended Tag 0x82
Extended Tag 0x83
Extended Tag 0x84
Tag 0x48
Extended Tag 0x85
Tag 0x40
Extended Tag 0x94
Extended Tag 0x92
Tag 0x40
hardware.version.enum
Hardware version enum
Tag 0x01
Extended Tag 0xFD,
Extended Tag 0xFE,
Tag 0x90,
Tag 0xD3
Tag 0x40
ibutton.connection.status
iButton key connected status
Tag 0xD5
incline.event
Incline exceeds allowed level
Tag 0x40
Tag 0x40
Tag 0x40
modbus.sensor.value
Extended Tag 0x01...0x20,
Extended Tag 0x61...0x80
modem.state.enum
Extended Tag 0xA6
Tag 0x40
network.type.enum
Transmission channel
Tag 0x49
Tag 0x80...0x87
Tag 0x80...0x87
Tag 0x34
Tag 0x33
Tag 0x35
Tag 0x30
Tag 0x30
Tag 0x36
Tag 0x33
Tag 0x30
Tag 0x10
refrigerator.alarm.enum
Refrigerator alarm code
Tag 0x5B
refrigerator.alarm.type.enum
Tag 0x5B
Tag 0x5B
Tag 0x5B
refrigerator.din
Tag 0x5B
Tag 0x5B
refrigerator.emergency.status
Refrigerator emergency status
Tag 0x5B
refrigerator.engine.mode
Tag 0x5B
refrigerator.engine.mode.enum
Tag 0x5B
refrigerator.engine.rpm
Refrigerator engine RPM
Tag 0x5B
Tag 0x5B
Tag 0x5B
refrigerator.operate.mode
Tag 0x5B
Tag 0x5B
Tag 0x5B
Tag 0x5B
Tag 0x5B
refrigerator.set.temperature
Tag 0x5B
refrigerator.troublecode.enum
Tag 0x5B
rep500.counter.value
Tag 0x5A
Extended Tag 0xFC
rs232.sensor.value
Custom RS232 sensor value
Tag 0x58,
Tag 0x59
Tag 0x63...0x6F,
Tag 0x8A...0x8C
Tag 0x60...0x62,
Tag 0x63...0x6F
Extended Tag 0x86...0x8D,
Tag 0x70...0x77
sensor.temperature.id
ID of temperature sensor
Tag 0x40
sim.card.slot
Currently used SIM card slot
Extended Tag 0x93
software.version.enum
Software version enum
Tag 0x02
Extended Tag 0x2D5C,
Extended Tag 0x2D5D
Extended Tag 0x2D5D
Extended Tag 0x2D69
thermoking.accident.enum
ThermoKing accident enum
Tag 0x5B
Tag 0x5B
thermoking.engine.motorhours
ThermoKing engine motorhours
Tag 0x5B
thermoking.total.motorhours
Tag 0x5B
Tag 0x20,
Tag 0x21
Tag 0x5C
Tag 0x5C
tire.sensor.connection.status
Tire sensor connection status
Tag 0x5C
tire.sensor.reason
Tag 0x5C
Tag 0x5C
Extended Tag 0xD9...0xFA
Extended Tag 0x273E
Tag 0x47
user.data.hex
User data array in HEX
Tag 0xEA
user.data.value
User data value
Tag 0xE2...0xE9
Tag 0xD4
wifi.error.enum
Extended Tag 0xA5
wifi.module.status.enum
Extended Tag 0xA4
Tag 0x44
Tag 0x44
Tag 0x44
Authorize phone number
add_number
Reboot Device
CLEARSCRIPT command
clear_script
username: EasyLogic Username
scriptname: Script name
Track parameters setup
Activate digital output 3
{"payload":"Out 2,1"}
{"payload":"SCRIPT"}
Set SCRIPT command
set_script
