Jimi IoT (Concox) JC371
The JC371 is a robust vehicle monitoring solution with LTE connectivity and support for up to 3 cameras, incorporating visual AI with ADAS and DMS for fleet safety. Features include remote video monitoring, emergency alerts, GPS and BDS positioning, dual-mode vehicle immobilization, and expandable storage up to 256GB. Suitable for commercial fleets across various industries, offering online and in-cab alerts to enhance road safety.
Settings (24)
Commands (8)
Flespi parses telemetry data from your Jimi IoT (Concox) JC371 into a standardized JSON and lets you send commands to Jimi IoT (Concox) JC371 via API.
    "device.type.id": "Jimi IoT (Concox) JC371",
How to send commands to Jimi IoT (Concox) JC371?
KD031 CAN data ID 0x0537
Message ID 0x6006,
Message ID 0x6006,
KD031 CAN data ID 0x0526
KD031 CAN data ID 0x0530
KD031 CAN data ID 0x053B
KD031 CAN data ID 0x010F
KD031 CAN data ID 0xFDB8
KD031 CAN data ID 0xFEE9
KD031 CAN data ID 0x0552
KD031 CAN data ID 0x0111
KD031 CAN data ID 0xEEF6
KD031 CAN data ID 0x053D
KD031 CAN data ID 0xF00A
KD031 CAN data ID 0x0547
Protocol Number 0x39
Message ID 0x6006,
Message ID 0x6006,
Message ID 0x6006,
Message ID 0x6006,
Message ID 0x6006,
Message ID 0x6006,
Message ID 0x6006,
Message ID 0x6006,
Message ID 0x6006,
Message ID 0x6006,
Message ID 0x6006,
Message ID 0x6006,
Message ID 0x6006,
ADAS function switch
adas_switch
Enable or disable the ADAS (Advanced Driver-Assistance Systems) AI function
enable: Enable ADAS
DMS function switch
dms_switch
Enable or disable the DMS (Driver Monitoring System) AI function
enable: Enable DMS
Face recognition failure alert
eventalert_afif
Configure reporting and voice alert for face recognition failure (AFIF)
voice_interval: Voice interval
report_interval: Report interval
Face recognition success alert
eventalert_afis
Configure reporting and voice alert for face recognition success (AFIS)
Face recognition detection
eventset_afif
Configure face recognition detection logic: similarity threshold, failure timeout and recognition interval
interval: Recognition interval
sensitivity: Sensitivity
fail_duration: Failure detection duration
Face library: list entries
face_check
List the current face library entries on the device
Face library: delete entry
face_delete
Delete a face entry from the on-device face library
Face library: download package
face_download
Download a compressed face package (zip of ID-NAME.jpg images) from a URL
url: Package URL
Face library: capture and enroll
face_shot
Capture a selfie via the device camera and enroll it in the on-device face library
FACE recognition function switch
face_switch
Enable or disable the FACE (Face Recognition / FRS) AI function. Requires the optional facial recognition camera.
enable: Enable FACE
Face library: recognition test
face_test
Trigger an immediate face recognition test
Restart Device
reboot2
Recording quality channel 1
recording_quality_ch1
TF card recording resolution, frame rate, bitrate and codec of CH1 (main road-facing camera), applied after device reboot
fps: Frame rate
codec: Video encoding
bitrate: Bitrate
resolution: Resolution
Recording quality channel 2
recording_quality_ch2
TF card recording resolution, frame rate, bitrate and codec of CH2 (inward-facing USB camera), applied after device reboot
fps: Frame rate
bitrate: Bitrate
Recording quality channel 3
recording_quality_ch3
TF card recording resolution, frame rate, bitrate and codec of CH3 (driver-facing DMS camera), applied after device reboot
fps: Frame rate
bitrate: Bitrate
Live and event video quality channel 1
recording_quality_sub_ch1
Live, history and event video resolution, frame rate, bitrate and codec of CH1 (main road-facing camera), applied after device reboot
fps: Frame rate
bitrate: Bitrate
Live and event video quality channel 2
recording_quality_sub_ch2
Live, history and event video resolution, frame rate, bitrate and codec of CH2 (inward-facing USB camera), applied after device reboot
fps: Frame rate
bitrate: Bitrate
Live and event video quality channel 3
recording_quality_sub_ch3
Live, history and event video resolution, frame rate, bitrate and codec of CH3 (driver-facing DMS camera), applied after device reboot
fps: Frame rate
bitrate: Bitrate
Request Log
request_log
Upload device diagnostic logs
Server Setup
server5
port: Server port
address: Server address
backup_port: Backup server port
timezone
Time Zone Setup
HTTP upload type configuration
urltype
upload_type: Upload type
Wakeup query
wakeup2
Wakeup the main module to take action during Sleep mode
type: Media type
alarm_id: Alarm ID
storage_type: Storage type
Start audiostream
start_audiostream
Start audio stream session
type: Audio mode
quality: Quality
