Jimi IoT (Concox) JM-LL01
Concox JM-LL01 is an asset GPS tracker with LTE support, up to 3 years of battery life, and a magnetic mount. The device features a 10,000 mAh Li-Pol backup battery, tamper alert, IP65 dust & water-resistant casing, and more.
Settings (16)
Flespi parses telemetry data from your Jimi IoT (Concox) JM-LL01 into a standardized JSON and lets you send commands to Jimi IoT (Concox) JM-LL01 via API.
    "device.type.id": "Jimi IoT (Concox) JM-LL01",
How to send commands to Jimi IoT (Concox) JM-LL01?
KD031 CAN data ID 0x0537
Message ID 0x6006,
Message ID 0x6006,
KD031 CAN data ID 0x0526
KD031 CAN data ID 0x0530
KD031 CAN data ID 0x053B
KD031 CAN data ID 0x010F
KD031 CAN data ID 0xFDB8
KD031 CAN data ID 0xFEE9
KD031 CAN data ID 0x0552
KD031 CAN data ID 0x0111
KD031 CAN data ID 0xEEF6
KD031 CAN data ID 0x053D
KD031 CAN data ID 0xF00A
KD031 CAN data ID 0x0547
Protocol Number 0x39
Message ID 0x6006,
Message ID 0x6006,
Message ID 0x6006,
Message ID 0x6006,
Message ID 0x6006,
Message ID 0x6006,
Message ID 0x6006,
Message ID 0x6006,
Message ID 0x6006,
Message ID 0x6006,
Message ID 0x6006,
Message ID 0x6006,
Message ID 0x6006,
Battery Alarm
bat_alarm2
Battery Alarm Setup
battery: Enable Alarm
Check
check
Delayed Defense
defense
Delayed Defense Setup
delay: Delayed Defense
G-Sensor sensitivity
g_sens_level
G-Sensor sensitivity level
level: Level
Heartbeat
hrbt_ival
Heartbeat interval
ival: Interval
Configure APN parameters
Overspeeding Alarm
overspeed_alarm
Overspeeding Alarm Setup
overspeed: Enable Alarm
Restart Device
Server Setup
comm: Communication Mode
mode: Host Mode
Status
status
Update status of the device
Tamper Alarm
tamper_alarm
Tamper Alarm Setup
tamper: Enable Alarm
timezone
Time Zone Setup
Vibration Alarm
vibr_alarm
Vibration Alarm Setup
vibr: Enable Alarm
Voice alarm
voice_alarm
Voice Alarm Setup
voice: Enable Alarm
Where
where
Obtain real-time position
Working Mode
working_mode
Device working mode settings
mode: Working Mode
