Jimi IoT (Concox) JM-LL02
The Concox JM-LL02 is a 4G asset GPS tracker designed for robust applications. It features a substantial 6,000 mAh rechargeable battery and a strong magnetic mount for near-zero installation, making it suitable for various deployments where long standby time and straightforward installation are crucial. The device also houses a light sensor to alert upon removal, adding a layer of security. It supports GPS, WiFi, and LBS positioning for accurate location tracking, and can be conveniently configured via Bluetooth. The rugged design with IP67 dust and water resistance ensures it performs optimally even under harsh conditions. Additional features include magnetic charging, multiple working modes for varying demands, and a tamper alert for added security.
Settings (16)
Flespi parses telemetry data from your Jimi IoT (Concox) JM-LL02 into a standardized JSON and lets you send commands to Jimi IoT (Concox) JM-LL02 via API.
    "device.type.id": "Jimi IoT (Concox) JM-LL02",
How to send commands to Jimi IoT (Concox) JM-LL02?
KD031 CAN data ID 0x0537,
KD031 CAN data ID 0x0526,
KD031 CAN data ID 0x0530,
KD031 CAN data ID 0x053B,
KD031 CAN data ID 0x010F,
KD031 CAN data ID 0xFEE9,
KD031 CAN data ID 0x0552,
KD031 CAN data ID 0x0111,
KD031 CAN data ID 0xEEF6,
KD031 CAN data ID 0x053D,
KD031 CAN data ID 0xF00A,
KD031 CAN data ID 0x0547,
Message ID 0x0800
Battery Alarm
bat_alarm2
Battery Alarm Setup
battery: Enable Alarm
Check
check
Delayed Defense
defense
Delayed Defense Setup
delay: Delayed Defense
G-Sensor sensitivity
g_sens_level
G-Sensor sensitivity level
level: Level
Heartbeat
hrbt_ival
Heartbeat interval
ival: Interval
Configure APN parameters
Overspeeding Alarm
overspeed_alarm
Overspeeding Alarm Setup
overspeed: Enable Alarm
Restart Device
Server Setup
comm: Communication Mode
mode: Host Mode
Status
status
Update status of the device
Tamper Alarm
tamper_alarm
Tamper Alarm Setup
tamper: Enable Alarm
timezone
Time Zone Setup
Vibration Alarm
vibr_alarm
Vibration Alarm Setup
vibr: Enable Alarm
Voice alarm
voice_alarm
Voice Alarm Setup
voice: Enable Alarm
Where
where
Obtain real-time position
Working Mode
working_mode
Device working mode settings
mode: Working Mode
