Jimi IoT (Concox) JM-LL302
Concox JM-LL302 is a 4G LTE Cat.1 asset GPS tracker with an ultra-long life battery and light sensor. The device features GPS + BDS + LBS + Wi-Fi positioning, remote listen-in, multiple working modes, multiple alerts, 10,000 mAh battery, Bluetooth, magnetic mount, optional temperature and humidity sensors, optional door status detection, IP65 casing, and more.
Settings (10)
Flespi parses telemetry data from your Jimi IoT (Concox) JM-LL302 into a standardized JSON and lets you send commands to Jimi IoT (Concox) JM-LL302 via API.
    "device.type.id": "Jimi IoT (Concox) JM-LL302",
How to send commands to Jimi IoT (Concox) JM-LL302?
KD031 CAN data ID 0x0537,
KD031 CAN data ID 0x0526,
KD031 CAN data ID 0x0530,
KD031 CAN data ID 0x053B,
KD031 CAN data ID 0x010F,
KD031 CAN data ID 0xFEE9,
KD031 CAN data ID 0x0552,
KD031 CAN data ID 0x0111,
KD031 CAN data ID 0xEEF6,
KD031 CAN data ID 0x053D,
KD031 CAN data ID 0xF00A,
KD031 CAN data ID 0x0547,
Message ID 0x0800
Battery Alarm
bat_alarm2
Battery Alarm Setup
battery: Enable Alarm
Check
check
Configure APN parameters
Sensitivity
sens_level
level: Level
Server Setup
comm: Communication Mode
mode: Host Mode
Tamper Alarm
tamper_alarm
Tamper Alarm Setup
tamper: Enable Alarm
Exit Tamper Alarm
tamper_cancel
timezone
Time Zone Setup
Vibration Alarm
vibr_alarm
Vibration Alarm Setup
vibr: Enable Alarm
Where
where
Obtain real-time position
