Jimi IoT (Concox) JM-LL305
The Jimi IoT LL305 is a portable 4G LTE tracker specially designed for asset and fleet management. Its compact size and weight allow concealed installation. Multiple positioning systems supported provide strong signal acquisition and accurate positioning. Which coupled with multiple working modes, intelligent sound recording, remote listen-in, noise alert and other features makes the device ideal for managing fleet and assets.
Settings (10)
Flespi parses telemetry data from your Jimi IoT (Concox) JM-LL305 into a standardized JSON and lets you send commands to Jimi IoT (Concox) JM-LL305 via API.
    "device.type.id": "Jimi IoT (Concox) JM-LL305",
How to send commands to Jimi IoT (Concox) JM-LL305?
KD031 CAN data ID 0x0537,
KD031 CAN data ID 0x0526,
KD031 CAN data ID 0x0530,
KD031 CAN data ID 0x053B,
KD031 CAN data ID 0x010F,
KD031 CAN data ID 0xFEE9,
KD031 CAN data ID 0x0552,
KD031 CAN data ID 0x0111,
KD031 CAN data ID 0xEEF6,
KD031 CAN data ID 0x053D,
KD031 CAN data ID 0xF00A,
KD031 CAN data ID 0x0547,
Message ID 0x0800
Battery Alarm
bat_alarm2
Battery Alarm Setup
battery: Enable Alarm
Check
check
Configure APN parameters
Sensitivity
sens_level
level: Level
Server Setup
comm: Communication Mode
mode: Host Mode
Tamper Alarm
tamper_alarm
Tamper Alarm Setup
tamper: Enable Alarm
Exit Tamper Alarm
tamper_cancel
timezone
Time Zone Setup
Vibration Alarm
vibr_alarm
Vibration Alarm Setup
vibr: Enable Alarm
Where
where
Obtain real-time position
