Jimi IoT (Concox) JM-LL702
Concox JM-LL702 is a 4G LTE Cat.1 asset GPS tracker with an ultra-long life battery and light sensor. The device features GPS + BDS + LBS + Wi-Fi positioning, multiple working modes, geo-fence entry/exit alert, abnormal vibration alert, low battery alert, device fall/removal alert, 4,200 mAh battery, magnetic mount, and more.
Settings (10)
Flespi parses telemetry data from your Jimi IoT (Concox) JM-LL702 into a standardized JSON and lets you send commands to Jimi IoT (Concox) JM-LL702 via API.
    "device.type.id": "Jimi IoT (Concox) JM-LL702",
How to send commands to Jimi IoT (Concox) JM-LL702?
KD031 CAN data ID 0x0537
Message ID 0x6006,
Message ID 0x6006,
KD031 CAN data ID 0x0526
KD031 CAN data ID 0x0530
KD031 CAN data ID 0x053B
KD031 CAN data ID 0x010F
KD031 CAN data ID 0xFDB8
KD031 CAN data ID 0xFEE9
KD031 CAN data ID 0x0552
KD031 CAN data ID 0x0111
KD031 CAN data ID 0xEEF6
KD031 CAN data ID 0x053D
KD031 CAN data ID 0xF00A
KD031 CAN data ID 0x0547
Protocol Number 0x39
Message ID 0x6006,
Message ID 0x6006,
Message ID 0x6006,
Message ID 0x6006,
Message ID 0x6006,
Message ID 0x6006,
Message ID 0x6006,
Message ID 0x6006,
Message ID 0x6006,
Message ID 0x6006,
Message ID 0x6006,
Message ID 0x6006,
Message ID 0x6006,
Battery Alarm
bat_alarm2
Battery Alarm Setup
battery: Enable Alarm
Check
check
Configure APN parameters
Sensitivity
sens_level
level: Level
Server Setup
comm: Communication Mode
mode: Host Mode
Tamper Alarm
tamper_alarm
Tamper Alarm Setup
tamper: Enable Alarm
Exit Tamper Alarm
tamper_cancel
timezone
Time Zone Setup
Vibration Alarm
vibr_alarm
Vibration Alarm Setup
vibr: Enable Alarm
Where
where
Obtain real-time position
