Jimi IoT (Concox) JM-LL705
The LL705 is a 4G wireless GPS asset tracker for monitoring high-value construction and mining equipment. It features a powerful 18,000mAh battery lasting up to 10 years, GPS+Beidou satellite systems, Bluetooth, IP67 dust and water resistance, tamper alerts, and flexible installation options with magnetic and adhesive mounts.
Settings (10)
Flespi parses telemetry data from your Jimi IoT (Concox) JM-LL705 into a standardized JSON and lets you send commands to Jimi IoT (Concox) JM-LL705 via API.
    "device.type.id": "Jimi IoT (Concox) JM-LL705",
How to send commands to Jimi IoT (Concox) JM-LL705?
KD031 CAN data ID 0x0537,
KD031 CAN data ID 0x0526,
KD031 CAN data ID 0x0530,
KD031 CAN data ID 0x053B,
KD031 CAN data ID 0x010F,
KD031 CAN data ID 0xFEE9,
KD031 CAN data ID 0x0552,
KD031 CAN data ID 0x0111,
KD031 CAN data ID 0xEEF6,
KD031 CAN data ID 0x053D,
KD031 CAN data ID 0xF00A,
KD031 CAN data ID 0x0547,
Message ID 0x0800
Battery Alarm
bat_alarm2
Battery Alarm Setup
battery: Enable Alarm
Check
check
Configure APN parameters
Sensitivity
sens_level
level: Level
Server Setup
comm: Communication Mode
mode: Host Mode
Tamper Alarm
tamper_alarm
Tamper Alarm Setup
tamper: Enable Alarm
Exit Tamper Alarm
tamper_cancel
timezone
Time Zone Setup
Vibration Alarm
vibr_alarm
Vibration Alarm Setup
vibr: Enable Alarm
Where
where
Obtain real-time position
