Jimi IoT (Concox) JM-VL103
Concox JM-VL103 is a compact multifunctional 4G LTE vehicle GPS tracker. The device features GPS & BDS & LBS positioning, low voltage alert, remote listen-in, external buzzer, multiple alerts, 270 mAh battery, IP66 casing, and more.
Settings (16)
Flespi parses telemetry data from your Jimi IoT (Concox) JM-VL103 into a standardized JSON and lets you send commands to Jimi IoT (Concox) JM-VL103 via API.
    "device.type.id": "Jimi IoT (Concox) JM-VL103",
How to send commands to Jimi IoT (Concox) JM-VL103?
KD031 CAN data ID 0x0537
Message ID 0x6006,
Message ID 0x6006,
KD031 CAN data ID 0x0526
KD031 CAN data ID 0x0530
KD031 CAN data ID 0x053B
KD031 CAN data ID 0x010F
KD031 CAN data ID 0xFDB8
KD031 CAN data ID 0xFEE9
KD031 CAN data ID 0x0552
KD031 CAN data ID 0x0111
KD031 CAN data ID 0xEEF6
KD031 CAN data ID 0x053D
KD031 CAN data ID 0xF00A
KD031 CAN data ID 0x0547
Protocol Number 0x39
Message ID 0x6006,
Message ID 0x6006,
Message ID 0x6006,
Message ID 0x6006,
Message ID 0x6006,
Message ID 0x6006,
Message ID 0x6006,
Message ID 0x6006,
Message ID 0x6006,
Message ID 0x6006,
Message ID 0x6006,
Message ID 0x6006,
Message ID 0x6006,
Configure APN parameters
auto: Auto APN
Center Number
center_number3
phone: Center Number
Check
check
Clear backup data
clear
Clear the backup data
Defense Timeout
defense3
Defense timeout configuration
timeout: Defense Timeout
dvr_info
imsi: IMSI
iccid: ICCID
Displacement Alarm
move_alarm_vl103
Displacement Alarm Setup
move: Enable Alarm
Petrol/Electricity Control
relay
Petrol/electricity Control with safe speed judgment
safe_speed: Safe Speed
Relay Control by ACC
relay_acc
Cut off fuel supply after ACC OFF, or restore fuel supply
cut_off: Cut Off after ACC OFF
Relay Slow Down
relay_slowdown
Stop the vehicle after slowing it down by toggling the relay
duration: Activation Length
interval: Toggle Interval
Restart
Restart Scooter IoT module. Restart delay is 20 seconds.
Status
status
Update status of the device
GPS Tracking Interval
timer3
GPS Data Upload Time Interval
time_on: ACC On Upload Interval
time_off: ACC Off Upload Interval
timezone
Time Zone Setup
Vibration Alarm
vibr_alarm_vl103
Vibration Alarm Setup
vibr: Enable Alarm
Where
where
Obtain real-time position
