Jimi IoT (Concox) JM-VL110C
VL110C is a compact 4G LTE vehicle GNSS terminal for managing all vehicle types. It features a wide 9-90V input voltage, LTE with GSM fallback, IP65 dust and water resistance, and GNSS/LTE jamming detection. It supports fleet management and stolen vehicle recovery, with a 270mAh Li-Polymer battery, internal GNSS antenna, accelerometer, harsh driving analysis, geo-fencing, and remote cut-off capabilities for fuel and power.
Settings (9)
Flespi parses telemetry data from your Jimi IoT (Concox) JM-VL110C into a standardized JSON and lets you send commands to Jimi IoT (Concox) JM-VL110C via API.
    "device.type.id": "Jimi IoT (Concox) JM-VL110C",
How to send commands to Jimi IoT (Concox) JM-VL110C?
KD031 CAN data ID 0x0537
Message ID 0x6006,
Message ID 0x6006,
KD031 CAN data ID 0x0526
KD031 CAN data ID 0x0530
KD031 CAN data ID 0x053B
KD031 CAN data ID 0x010F
KD031 CAN data ID 0xFDB8
KD031 CAN data ID 0xFEE9
KD031 CAN data ID 0x0552
KD031 CAN data ID 0x0111
KD031 CAN data ID 0xEEF6
KD031 CAN data ID 0x053D
KD031 CAN data ID 0xF00A
KD031 CAN data ID 0x0547
Protocol Number 0x39
Message ID 0x6006,
Message ID 0x6006,
Message ID 0x6006,
Message ID 0x6006,
Message ID 0x6006,
Message ID 0x6006,
Message ID 0x6006,
Message ID 0x6006,
Message ID 0x6006,
Message ID 0x6006,
Message ID 0x6006,
Message ID 0x6006,
Message ID 0x6006,
Check
check
GPS
gpsdup
Enable/Disable GPS Data Upload
Petrol/Electricity Control
relay
Petrol/electricity Control with safe speed judgment
safe_speed: Safe Speed
Relay Control by ACC
relay_acc
Cut off fuel supply after ACC OFF, or restore fuel supply
cut_off: Cut Off after ACC OFF
Relay Slow Down
relay_slowdown
Stop the vehicle after slowing it down by toggling the relay
duration: Activation Length
interval: Toggle Interval
Restart
Restart Scooter IoT module. Restart delay is 20 seconds.
Status
status
Update status of the device
GPS Tracking Interval
timer3
GPS Data Upload Time Interval
time_on: ACC On Upload Interval
time_off: ACC Off Upload Interval
Where
where
Obtain real-time position
