Jimi IoT (Concox) JM-VL162
The JM-VL162 is an advanced 4G LTE electric two-wheeler tracker featuring multi-GNSS positioning (GPS, BDS, GLONASS, Galileo, AGPS, LBS) with <2.5m accuracy and Bluetooth 5.0 connectivity. It offers keyless start/stop functionality, intelligent anti-theft mechanism with automatic wheel lock and audible alarm, and comprehensive driving behavior monitoring including harsh acceleration, braking, and cornering detection. The device operates on a wide 9-90V DC voltage range with IP66 waterproof rating, making it ideal for electric scooter manufacturers, dealerships, and rental services requiring advanced security and precise tracking capabilities.
Settings (31)
Flespi parses telemetry data from your Jimi IoT (Concox) JM-VL162 into a standardized JSON and lets you send commands to Jimi IoT (Concox) JM-VL162 via API.
    "device.type.id": "Jimi IoT (Concox) JM-VL162",
How to send commands to Jimi IoT (Concox) JM-VL162?
KD031 CAN data ID 0x0537
Message ID 0x6006,
Message ID 0x6006,
KD031 CAN data ID 0x0526
KD031 CAN data ID 0x0530
KD031 CAN data ID 0x053B
KD031 CAN data ID 0x010F
KD031 CAN data ID 0xFDB8
KD031 CAN data ID 0xFEE9
KD031 CAN data ID 0x0552
KD031 CAN data ID 0x0111
KD031 CAN data ID 0xEEF6
KD031 CAN data ID 0x053D
KD031 CAN data ID 0xF00A
KD031 CAN data ID 0x0547
Protocol Number 0x39
Message ID 0x6006,
Message ID 0x6006,
Message ID 0x6006,
Message ID 0x6006,
Message ID 0x6006,
Message ID 0x6006,
Message ID 0x6006,
Message ID 0x6006,
Message ID 0x6006,
Message ID 0x6006,
Message ID 0x6006,
Message ID 0x6006,
Message ID 0x6006,
Analog Input Data Interval
analog_interval
Analog Input Data Upload Interval
ad_upload: Enable Upload of Analog Data
Battery Alarm
bat_alarm2
Battery Alarm Setup
battery: Enable Alarm
Check
check
Collision Alarm
collision_alarm_jm_vl162
Once enabled, this alarm is triggered if the device senses a big impact followed by low vehicle speed for a period of time
collide: Enable Alarm
Defence Mode
defence
GPS Tracking Distance
distance
Configure sending of GPS report for fixed distance
distance: Distance
Factory reset
factory
Restore to factory settings (except domain name/APN/locked domain name)
Find
find
Find vehicle by triggering light and buzzer
GPS ON
gps_activate
Activate GPS
ival: Time
GPS
gpsdup
Enable/Disable GPS Data Upload
Heartbeat Interval
hbt_interval
hbt_on: ACC ON Interval
hbt_off: ACC OFF Interval
LED Control
led_switch
LED switch control
Lock/Unlock Vehicle
lock_vehicle
enable: Lock
Displacement Alarm
move_alarm_vl103
Displacement Alarm Setup
move: Enable Alarm
Mileage Statistics
Mileage Statistics Function
odometer: Mileage Statistics
Overspeeding Alarm
overspeed_alarm_jm_vl162
overspeed: Enable Alarm
15km/h Overspeed Alert
ovspeed_alarm_15_jm_vl162
When enabled under the active-low configuration, the buzzer activates only after detecting a transition from high level (5V) to low level.
ovspeed: Enable Alarm
Power Alarm
power_alarm
Power Alarm Setup
power: Enable Alarm
Removal Alarm
pull_alarm_jm_vl162
Once enabled, an alert will be triggered when the device is removed. This is achieved by sensing a combination of g-force and power loss.
enable: Enable Alarm
Query LBS
query_lbs
Query a LBS location point.
Restart Device
Remote Engine Start
remote_engine_start
Remotely activates the vehicle's ignition (ACC power).
Rollover Alarm
rollover_alarm_jm_vl162
If the device had triggered a collision alert and had been rolled over after that, the device will trigger a rollover alert once this alarm is turned on
Server Setup
server4
mode: Host Mode
Harsh Acceleration/Deceleration Alarm
speedcheck_alarm_jm_vl162
speedcheck: Enable Alarm
Speed Limit
speed_limit
speed: Max Speed
Status
status
Update status of the device
Harsh Turning Alarm
swerve_jm_vl162
swerve: Enable Alarm
GPS Tracking Interval
timer3
GPS Data Upload Time Interval
time_on: ACC On Upload Interval
time_off: ACC Off Upload Interval
version: Firmware Version
Vibration Alarm
vibr_alarm_vl103
Vibration Alarm Setup
vibr: Enable Alarm
