KD031 CAN data ID 0x0537
Message ID 0x6006,
Message ID 0x6006,
*major* - iBeacon Major value
*minor* - iBeacon Minor value
KD031 CAN data ID 0x0526
KD031 CAN data ID 0x0530
*code* - Trouble code, e.g. P0100 (OBDII)
*extension* - Failure type byte of the trouble code in hex (OBDII)
*protocol* - Diagnostic protocol the code was read with (OBD, J1939, J1708, UDS, KWP2000)
KD031 CAN data ID 0x053B
KD031 CAN data ID 0x010F
KD031 CAN data ID 0xFDB8
KD031 CAN data ID 0xFEE9
KD031 CAN data ID 0x0552
KD031 CAN data ID 0x0111
KD031 CAN data ID 0xEEF6
KD031 CAN data ID 0x053D
KD031 CAN data ID 0xF00A
KD031 CAN data ID 0x0547
Protocol Number 0x39
Message ID 0x6006,
Message ID 0x6006,
Message ID 0x6006,
Message ID 0x6006,
Message ID 0x6006,
Message ID 0x6006,
Message ID 0x6006,
Message ID 0x6006,
Message ID 0x6006,
Message ID 0x6006,
Message ID 0x6006,
Message ID 0x6006,
Message ID 0x6006,
