Lantrix TH100
Lantrix TH100 4G is a professional cellular alarm communicator for security panels, transmitting events to monitoring centers via 4G/3G/2G. It connects to the panel data bus, supports Contact-ID and SIA-IP over TCP/IP or UDP using GPRS, and offers dual SIM with automatic failover for higher reliability. The device integrates an internal GSM antenna, optional backup battery, event queuing with automatic retry, SMS configuration, and remote arm/disarm through the Lantrix Remote mobile app. Compact DIN-rail or wall mounting design ensures straightforward installation with major alarm panel brands.
Parameters (38)
Settings (5)
Lantrix TH100
Flespi parses telemetry data from your Lantrix TH100 into a standardized JSON and lets you send commands to Lantrix TH100 via API.
    "device.type.id": "Lantrix TH100",
    "protocol.id": "lantrix"
How to send commands to Lantrix TH100?
Report RTH
Report RTH
armed.status
Armed/disarmed status
Report RTH
Report RTH
Report RTH,
Report RTT
Report RTH,
Report RTT
Report RTT
Report RTT
Report RTT
Report RTT
Report RTH,
Report RTT
Report RTH,
Report RTT
Report RTT
Report RTT
Report RTH,
Report RTT
intrusion.alarm
Intrusion detected by alarm panel
Report RTH
Report RTH
panel.bus.status
Alarm panel data bus connection status
Report RTH
Report RTT
Report RTT
Report RTT
Report RTT
Report RTT
Report RTT
position.satellites.visible
Report RTT
Report RTT
Report RTH,
Report RTT
siren.status
Siren activation status
Report RTH
Report RTH,
Report RTT
Delete All Remotes
delete_remotes
Delete all paired remote controls from device memory
Learn Remote
learn_remote
Put device into LEARN mode for 1 minute to pair a new key fob remote
Panel Control
panel_control
Arm or disarm the alarm panel using GT1000 key
key: GT1000 Key
Query Status
query_status
Request current panel status (QTH command). Device responds with RTH data packet.
Set Device Time
set_time
Set the device date and time to current UTC time
text: Command payload
Activate motor (T1700)
{"text":"!L0S341"}
Query position (T1700)
{"text":"QPF"}
Query status (TH100/TH200)
{"text":"QTH"}
Query extended status (T1700)
{"text":"QTT"}
