Meitrack T32
Meitrack T32 is a vehicle GPS tracker with 3G support. The device features 3 digital inputs, 2 analog inputs, 3 digital outputs, backup battery lasting up to 10 hours, and optional two-way audio.
Parameters (171)
Settings (3)
Meitrack T32
Flespi parses telemetry data from your Meitrack T32 into a standardized JSON and lets you send commands to Meitrack T32 via API.
    "device.type.id": "Meitrack T32",
    "protocol.id": "meitrack"
How to send commands to Meitrack T32?
Command type AAA
adas.blindspot.side
Command type AAA
Command type AAA,
Command type AAA,
Command type AAA
Command type AAA
Command type AAA,
Command type AAA
Command type AAA,
Command type CCC,
Command type AAA,
Command type AAA
Command type AAA,
Command type CCC,
ble.disconnected.alarm
BLE disconnected alert
Command type AAA
call.duration
Call duration
call.timestamp
Call timestamp
call.type
Call type
Command type AAA,
call.type.enum
Call type number
Command type AAA
device.installed.status
Command type AAA
Command type AAA,
Command type CCC,
Command type AAA
Command type AAA,
Command type CCC,
Command type AAA,
Command type AAA,
Command type AAA,
Command type AAA,
dsm.driver.staring.event
Command type AAA
Command type AAA
Command type AAA
Command type AAA
Command type AAA,
Command type AAA,
Command type AAA,
Command type CCE,
Command type AAA,
Command type CCC,
Command type AAA
Command type AAA,
Command type CCC,
Command type CE0
Command type AAA
Command type AAA,
Command type AAA,
Command type CCC,
Command type AAA
Command type AAA
fuel.full.event
Fuel tank full event
Command type AAA
Command type AAA
fuel.refuelling.event
Command type AAA
fuel.theft.alarm
Fuel Theft Alarm
Command type AAA
Command type CCC,
Command type AAA
Command type AAA
Command type AAA
Command type AAA,
Command type CCC,
Command type AAA
Command type AAA,
Command type CCC,
Command type AAA,
Command type CCC,
Command type AAA,
Command type CCC,
Command type AAA,
Command type CCC,
Command type AAA
Command type AAA
Command type AAA
Command type AAA
Command type AAA
Command type AAA
magnetic.card.data
Magnetic card data
maintenance.required.event
Command type AAA
maneuver.average.speed
Maneuver average speed
maneuver.duration
Maneuver duration
maneuver.max.speed
Maneuver max speed
maneuver.overspeeding.event
maneuver.start.latitude
maneuver.start.longitude
maneuver.start.timestamp
maneuver.stop.latitude
maneuver.stop.longitude
maneuver.stop.timestamp
Command type AAA,
network.description
Network description
network.type
Network type
Command type AAA
Command type 110,
Command type CE0
Command type CE0
picture.event
Picture event
Command type AAA
Command type AAA,
Command type CCC,
Command type AAA,
Command type CCC,
Command type AAA,
Command type CCC,
Command type AAA,
Command type CCC,
Command type AAA,
Command type CCC,
Command type AAA,
Command type CCC,
Command type AAA,
Command type CCC,
Command type AAA,
Command type CCC,
Command type AAA
reboot.event
Device reboot event
Command type AAA
Command type AAA,
Command type AAA
Command type AAA,
Command type AAA
speed.data
speed.data.interval
Interval between speed values
storage.full.status
Storage is full, indexed
Command type AAA
storage.media.malfunction
Command type AAA
tacho.performance
Tachograph performance
Command type AAA
Command type AAA
Command type AAA
Command type AAA,
Command type CCC,
Command type AAA
Command type CCE,
Command type CFF
Command type CCE,
Command type CFF
Command type CCE,
Command type CFF
Command type CCE,
Command type CFF
vehicle.battery.voltage
Vehicle battery voltage
Command type AAA,
Command type CCC,
vibration.status
Command type AAA
Generic device information.
serial: Serial Number
firmware: Firmware Version
Server Settings Setup
GPRS Time Zone
timezone
shift: Time Zone
{"command_type":"A10"}
