Meitrack T333
Meitrack T333 is a 3G vehicle GPS tracker. The device features 3-axis accelerometer, 3 digital inputs, 2 analog detection inputs, 2 outputs, 1 RS232 port, 1 USB port, 1-Wire temperature sensor, 1-Wire iButton, tire pressure monitoring, optional CAN bus interface, multiple alarms and reports, and more.
Parameters (142)
Settings (3)
Meitrack T333
Flespi parses telemetry data from your Meitrack T333 into a standardized JSON and lets you send commands to Meitrack T333 via API.
    "device.type.id": "Meitrack T333",
    "protocol.id": "meitrack"
How to send commands to Meitrack T333?
Command type AAA,
Command type CCC,
Command type AAA,
Command type AAA
Command type AAA,
Command type CCC,
ble.disconnected.alarm
BLE disconnected alert
Command type AAA
call.duration
Call duration
call.timestamp
Call timestamp
call.type
Call type
call.type.enum
Call type number
Command type AAA
device.installed.status
Command type AAA
Command type AAA,
Command type CCC,
Command type AAA
Command type AAA,
Command type CCC,
dsm.driver.staring.event
Command type AAA,
Command type CCE,
Command type AAA,
Command type CCC,
Command type AAA
Command type AAA,
Command type CCC,
Command type AAA
Command type AAA,
Command type AAA,
Command type CCC,
Command type AAA
Command type AAA
fuel.full.event
Fuel tank full event
Command type AAA
Command type AAA
fuel.refuelling.event
Command type AAA
fuel.theft.alarm
Fuel Theft Alarm
Command type AAA
Command type CCC,
Command type AAA
Command type AAA
Command type AAA
Command type AAA,
Command type CCC,
Command type AAA
Command type AAA,
Command type CCC,
Command type AAA,
Command type CCC,
Command type AAA,
Command type CCC,
Command type AAA,
Command type CCC,
Command type AAA
Command type AAA
Command type AAA
Command type AAA
Command type AAA
Command type AAA
magnetic.card.data
Magnetic card data
maintenance.required.event
Command type AAA
Command type AAA,
network.description
Network description
network.type
Network type
Command type AAA
Command type 110
picture.event
Picture event
Command type AAA
Command type AAA,
Command type CCC,
Command type AAA,
Command type CCC,
Command type AAA,
Command type CCC,
Command type AAA,
Command type CCC,
Command type AAA,
Command type CCC,
Command type AAA,
Command type CCC,
Command type AAA,
Command type CCC,
Command type AAA,
Command type CCC,
Command type AAA
reboot.event
Device reboot event
Command type AAA
Command type AAA,
Command type AAA
Command type AAA,
Command type AAA
tacho.performance
Tachograph performance
Command type AAA
Command type AAA
Command type AAA
Command type AAA,
Command type CCC,
Command type AAA
Command type CCE,
Command type CFF
Command type CCE,
Command type CFF
Command type CCE,
Command type CFF
Command type CCE,
Command type CFF
Command type AAA,
Command type CCC,
vibration.status
Generic device information.
serial: Serial Number
firmware: Firmware Version
Server Settings Setup
GPRS Time Zone
timezone
shift: Time Zone
{"command_type":"A10"}
