Meitrack TC68S
Meitrack TC68S is a Plug & Play vehicle GPS tracker without wiring. The device features a standard OBD II plug for easy installation, 3-axis accelerometer,  disconnect alert, multiple alarms and reports, and more.
Parameters (174)
Settings (3)
Meitrack TC68S
Flespi parses telemetry data from your Meitrack TC68S into a standardized JSON and lets you send commands to Meitrack TC68S via API.
    "device.type.id": "Meitrack TC68S",
    "protocol.id": "meitrack"
How to send commands to Meitrack TC68S?
Command type AAA,
adas.blindspot.side
Command type AAA,
Command type AAA,
Command type AAA,
Command type AAA,
Command type AAA,
Command type AAA,
Command type AAA,
Command type AAA,
Command type CCC,
alarm.camera.type
alarm.camera.type.enum
alarm.files
Command type AAA,
Command type AAA,
Command type AAA,
Command type CCC,
ble.disconnected.alarm
BLE disconnected alert
Command type AAA,
call.duration
Call duration
call.timestamp
Call timestamp
call.type
Call type
Command type AAA,
call.type.enum
Call type number
Command type AAA,
device.installed.status
Command type AAA,
Command type AAA,
Command type CCC,
Command type AAA,
Command type AAA,
Command type CCC,
Command type AAA,
Command type AAA,
Command type AAA,
Command type AAA,
dsm.driver.staring.event
Command type AAA,
Command type AAA,
Command type AAA,
Command type AAA,
Command type AAA,
Command type AAA,
Command type AAA,
Command type CCE,
Command type CFF,
Command type AAA,
Command type CCC,
Command type AAA,
Command type AAA,
Command type CCC,
Command type CE0
Command type AAA,
Command type AAA,
Command type AAA,
Command type CCC,
Command type AAA,
Command type AAA,
fuel.full.event
Fuel tank full event
Command type AAA,
Command type AAA,
fuel.refuelling.event
Command type AAA,
fuel.theft.alarm
Fuel Theft Alarm
Command type AAA,
Command type CCC,
Command type AAA,
Command type AAA,
Command type AAA,
Command type AAA,
Command type CCC,
Command type AAA,
Command type AAA,
Command type CCC,
Command type AAA,
Command type CCC,
Command type AAA,
Command type CCC,
Command type AAA,
Command type CCC,
Command type AAA,
Command type AAA,
Command type AAA,
Command type AAA,
Command type AAA,
Command type AAA,
magnetic.card.data
Magnetic card data
maintenance.required.event
Command type AAA,
maneuver.average.speed
Maneuver average speed
maneuver.duration
Maneuver duration
maneuver.max.speed
Maneuver max speed
maneuver.overspeeding.event
maneuver.start.latitude
maneuver.start.longitude
maneuver.start.timestamp
maneuver.stop.latitude
maneuver.stop.longitude
maneuver.stop.timestamp
Command type AAA,
network.description
Network description
network.type
Network type
Command type AAA,
Command type 110,
Command type CE0
Command type CE0
picture.event
Picture event
Command type AAA,
Command type AAA,
Command type CCC,
Command type AAA,
Command type CCC,
Command type AAA,
Command type CCC,
Command type AAA,
Command type CCC,
Command type AAA,
Command type CCC,
Command type AAA,
Command type CCC,
Command type AAA,
Command type CCC,
Command type AAA,
Command type CCC,
Command type AAA,
reboot.event
Device reboot event
Command type AAA,
Command type CCC,
Command type CCE,
Command type CFF
Command type AAA,
Command type AAA,
Command type AAA,
Command type AAA,
speed.data
speed.data.interval
Interval between speed values
storage.full.status
Storage is full, indexed
Command type AAA,
storage.media.malfunction
Command type AAA,
tacho.performance
Tachograph performance
Command type AAA,
Command type AAA,
Command type AAA,
Command type AAA,
Command type CCC,
Command type AAA,
vehicle.battery.voltage
Vehicle battery voltage
Command type AAA,
Command type CCC,
vibration.status
Command type AAA,
Generic device information.
serial: Serial Number
firmware: Firmware Version
Server Settings Setup
GPRS Time Zone
timezone
shift: Time Zone
{"command_type":"A10"}
