Micodus MV810G
MiCODUS MV810G is a compact 4G LTE in-vehicle GNSS tracker designed for private cars, motorcycles, and fleet management. It operates on a wide 9–95V DC voltage range and connects via 4G LTE CAT1 with 2G GSM fallback. The device supports GPS+BDS+GLONASS multi-constellation positioning for accurate real-time tracking and historical route playback. A built-in 280 mAh backup battery maintains operation after external power loss. Key features include remote fuel cut-off, ACC/ignition detection, door open alarm, vibration alarm, overspeed alert, geo-fence, and power disconnect alarm. It uses a single Micro SIM card and weighs just 40g.
Parameters (143)
Settings (15)
Micodus MV810G
Flespi parses telemetry data from your Micodus MV810G into a standardized JSON and lets you send commands to Micodus MV810G via API.
    "device.type.id": "Micodus MV810G",
    "protocol.id": "micodus"
How to send commands to Micodus MV810G?
Protocol Number 0x27
Location report supplementary item 0x57
armed.status
Armed/disarmed status
Message ID 0x0202,
Message ID 0x0203
Location report supplementary item 0xE1,
NBR Command,
V1 Command
Message ID 0x0202,
Message ID 0x0203,
Location report supplementary item 0x82,
Location report supplementary item 0x33
Message ID 0x0202,
Message ID 0x0203
Message ID 0x0202,
Message ID 0x0203
Location report supplementary item 0xA0
Location report supplementary item 0x84
Location report supplementary item 0x83
Location report supplementary item 0x8E
Location report supplementary item 0x81
Location report supplementary item 0x85
Message ID 0x0202,
Message ID 0x0203
Location report supplementary item 0x86
Location report supplementary item 0x88
Location report supplementary item 0x87
can.recharge.mileage
Location report supplementary item 0x8D
Location report supplementary item 0x89
Location report supplementary item 0x8C
Message ID 0x0202,
Message ID 0x0203
Location report supplementary item 0x80
city.id
ID of device's home city"
V1 Command
Location report supplementary item 0x51
Location report supplementary item 0x57,
Message ID 0x0202,
Message ID 0x0203,
Message ID 0x0202,
Message ID 0x0203,
V1 Command
Message ID 0x0202,
Message ID 0x0203
glonass.position.satellites
Location report supplementary item 0x34
Message ID 0x0202,
Message ID 0x0203
Location report supplementary item 0x32
Message ID 0x0202,
Message ID 0x0203
Location report supplementary item 0x9F,
NBR Command,
V1 Command
NBR Command,
V1 Command
NBR Command,
V1 Command
NBR Command,
V1 Command
NBR Command,
Protocol Number 0x28
Location report supplementary item 0x30,
Location report supplementary item 0xCC,
V19 Command
main.power.low.status
Main power low status
Message ID 0x0202,
Message ID 0x0203
manufacturer.code
Device manufacturer code"
manufacturer.device.code
V1 Command
Message ID 0x0202,
Message ID 0x0203
network.type.enum
Transmission channel
Location report supplementary item 0xE2
Message ID 0x0202,
Message ID 0x0203,
V1 Command
Message ID 0x0202,
Message ID 0x0203
Message ID 0x0202,
Message ID 0x0203,
V1 Command
Message ID 0x0202,
Message ID 0x0203,
V1 Command
Message ID 0x0202,
Message ID 0x0203,
V1 Command
Location report supplementary item 0x31
Message ID 0x0202,
Message ID 0x0203,
V1 Command
Message ID 0x0202,
Message ID 0x0203,
V1 Command
V1 Command
Message ID 0x0202,
Message ID 0x0203
province.id
ID of device's home province"
V1 Command
Message ID 0x0202,
Message ID 0x0203
Message ID 0x0202,
Message ID 0x0203,
NBR Command,
V1 Command
Message ID 0x0202,
Message ID 0x0203
Location report supplementary item 0x94
Location report supplementary item 0x93
Location report supplementary item 0x8F
trip.harsh.braking.number
Location report supplementary item 0x90
trip.harsh.cornering.number
Location report supplementary item 0x91
Location report supplementary item 0x97
Location report supplementary item 0x95
Location report supplementary item 0x92
trip.overspeeding.number
Location report supplementary item 0x96
Message ID 0x0202,
Message ID 0x0203
vehicle.load.state
Vehicle load state
Message ID 0x0202,
Message ID 0x0203
Location report supplementary item 0x01,
NBR Command,
V1 Command,
V19 Command
NBR Command,
V1 Command,
V19 Command
Location report supplementary item 0x8B,
Message ID 0x0202,
Message ID 0x0203,
V1 Command
ACC Alarm
acc_alarm
type: Alarm type
selection: ACC alarm selection
Report Interval when ACC OFF
acc_off_v2
interval: Time interval when ACC OFF
ARM/DISARM device
arm_v2
switch: Switch
Center Phone Number
center_number
number: Phone number
Displacement Alarm
displacement_alarm
type: Alarm type
distance: Alarm distance
Factory Reset
factory_reset
confirm: Confirm factory reset
Heartbeat Interval
heartbeat_v2
Inflection Point Angle
inflection_angle
Location Report Interval
location_report_v2
interval: Time interval to report location data
Low Voltage Alarm Threshold
low_voltage_threshold
Restart Device
restart
confirm: Confirm restart
SOS Alarm
sos_alarm_setting
type: Alarm type
SOS Numbers
sos_numbers
numbers: SOS numbers separated by comma
Total Mileage Setting
total_mileage
mileage: Mileage
Vehicle Control
vehicle_control
action: Control action
