Neomatica ADM700
Neomatica ADM700 is an advanced vehicle GPS tracker with CAN data support. The device features 6 analog and 2 digital inputs,  RS-485 and RS-232 interfaces, CAN bus (FMS; J1939), 1-Wire interface, 1000mAh Li-Ion battery, 2 SIM cards, voice support, 3G support (in ADM700 3G model), IP65 casing, and more.
Parameters (44)
Neomatica ADM700
Flespi parses telemetry data from your Neomatica ADM700 into a standardized JSON and lets you send commands to Neomatica ADM700 via API.
    "device.type.id": "Neomatica ADM700",
    "protocol.id": "neomatica"
How to send commands to Neomatica ADM700?
can.tag.number
User defined can tag number
can.tag.value
Can tag value, merge by parameter index
case.status
Case opened status
glonass.position.satellites
Tracking period
period
move_int: In Motion
stop_int: At Stop
Report Message Composition
protocol
Configure additional blocks of the report message.
can: CAN-bus data
fuel: Fuel level sensors
in_a: Analog inputs
in_d: Impulse inputs
outs: Outputs, events on inputs
odometr: Odometer values
parameters: Optional parameters
command_name: Command name
{"command_name":"RESET"}
Set period of tracking to 30 seconds in motion and 300 seconds without motion
{"parameters":"30,300","command_name":"PERIOD"}
Compose report message from the main data only. Do not include additional data
{"parameters":"0","command_name":"PROTOCOL"}
