Teltonika FM6320
Teltonika FM6320 is a heavy transport 3G GPS tracker with dual-SIM, microSD card, integrated tachograph solution, RS232/RS485 functionality, GNSS antenna disconnection detection, MVC300 online photo solution, J1708 CAN support, and much more.
Settings (10)
Teltonika FM6320
Flespi parses telemetry data from your Teltonika FM6320 into a standardized JSON and lets you send commands to Teltonika FM6320 via API.
    "device.type.id": "Teltonika FM6320",
How to send commands to Teltonika FM6320?
SIM1 APN Password
apn_password_sim1
GPRS APN Password for SIM1.
SIM1 APN Name
apn_sim1
GPRS APN Name for SIM1.
SIM1 APN Username
apn_username_sim1
GPRS APN Username for SIM1.
Digital Outputs
outputs
out1: Output 1
out2: Output 2
out3: Output 3
out4: Output 4
Backend Server
server_fm6320
Backend Server Settings
host: Server host
mode: Protocol
port: Server port
enable: Enable GPRS
timeout: Server response timeout
setdigout_4
tachocheck
addr: Addr
baud: Baud
ignition: Ignition
tacho_download_source
value: Value
Tachograph ignition source
tacho_ignition_source
value: Value
Tacho WEB settings
tacho_web
config: Command mode
{"text":"getrecord"}
Request tachograph file
request_tachograph_file
