Teltonika FMB630
Teltonika FMB630 is a leading GLONASS/GPS tracker with dual-SIM, Bluetooth connectivity, remote configuration, microSD card, integrated tachograph solution, RS232/RS485 functionality, and much more.
Parameters (1154)
Settings (21)
Commands (8)
Teltonika FMB630
Flespi parses telemetry data from your Teltonika FMB630 into a standardized JSON and lets you send commands to Teltonika FMB630 via API.
    "device.type.id": "Teltonika FMB630",
How to send commands to Teltonika FMB630?
AVL ID 168
SIM1 APN Password
apn_password_sim1
GPRS APN Password for SIM1.
SIM2 APN Password
apn_password_sim2
GPRS APN Password for SIM2.
SIM1 APN Name
apn_sim1
GPRS APN Name for SIM1.
SIM2 APN Name
apn_sim2
GPRS APN Name for SIM2.
SIM1 APN Username
apn_username_sim1
GPRS APN Username for SIM1.
SIM2 APN Username
apn_username_sim2
GPRS APN Username for SIM2.
Digital Outputs
outputs
out1: Output 1
out2: Output 2
out3: Output 3
out4: Output 4
Format SD card
sdformat
Profile 1: Backend Server 1
server1_profile1
Profile 1: Backend Server 1 Settings
host: Backend server 1 host
mode: Backend server 1 protocol
port: Backend server 1 port
enable: Enable GPRS context for server 1
timeout: Backend server 1 response timeout
Profile 2: Backend Server 1
server1_profile2
Profile 2: Backend Server 1 Settings
Profile 3: Backend Server 1
server1_profile3
Profile 3: Backend Server 1 Settings
Profile 4: Backend Server 1
server1_profile4
Profile 4: Backend Server 1 Settings
Profile 1: Backend Server 2
server2_profile1
Profile 1: Backend Server 2 Settings
host: Backend server 2 host
mode: Backend server 2 protocol
port: Backend server 2 port
enable: Enable GPRS context for server 2
timeout: Backend server 2 response timeout
Profile 2: Backend Server 2
server2_profile2
Profile 2: Backend Server 2 Settings
Profile 3: Backend Server 2
server2_profile3
Profile 3: Backend Server 2 Settings
Profile 4: Backend Server 2
server2_profile4
Profile 4: Backend Server 2 Settings
setdigout_4
tachocheck
addr: Addr
baud: Baud
ignition: Ignition
tacho_download_source
value: Value
Tachograph ignition source
tacho_ignition_source
value: Value
Tacho WEB settings
tacho_web
config: Command mode
{"text":"getrecord"}
Request tachograph file
request_tachograph_file
