Teltonika FMM230
Teltonika FMM230 is a waterproof LTE and NB-IoT GPS tracker with flexible inputs configuration. The device features green driving, overspeeding detection, excessive idling detection, immobilizer, iButton read notification, unplug detection, towing detection, crash detection, auto geofence, manual geofence, and other scenarios, configurable DIN/AIN/NIN for flexible remote monitoring and control, impulse inputs for fuel flow meters data reading, Bluetooth 4.0 + LE, IP67 casing, 170 mAh Li-Ion battery, and more.
Settings (148)
Teltonika FMM230
Flespi parses telemetry data from your Teltonika FMM230 into a standardized JSON and lets you send commands to Teltonika FMM230 via API.
    "device.type.id": "Teltonika FMM230",
How to send commands to Teltonika FMM230?
Accelerometer delay
accelerometer_delay
accelerometer_gravity
ACK Type
ack_type
mode: ACK Type
Allow AGPS in Home Network
agps_home_network
Allow AGPS in Roaming Network
agps_roaming_network
Allow AGPS in Unknown Network
agps_unknown_network
Analog Input 1 I/O
analog_input1_io
avg: Average
low: Low Level
high: High Level
prio: Priority
Analog Input 2 I/O
analog_input2_io
avg: Average
low: Low Level
high: High Level
prio: Priority
Authorized beacons list
auth_beacons
id1: BLE Beacon UID 1
id2: BLE Beacon UID 2
id3: BLE Beacon UID 3
id4: BLE Beacon UID 4
id5: BLE Beacon UID 5
id6: BLE Beacon UID 6
id7: BLE Beacon UID 7
id8: BLE Beacon UID 8
id9: BLE Beacon UID 9
id10: BLE Beacon UID 10
id11: BLE Beacon UID 11
id12: BLE Beacon UID 12
id13: BLE Beacon UID 13
id14: BLE Beacon UID 14
id15: BLE Beacon UID 15
id16: BLE Beacon UID 16
id17: BLE Beacon UID 17
id18: BLE Beacon UID 18
id19: BLE Beacon UID 19
id20: BLE Beacon UID 20
id21: BLE Beacon UID 21
id22: BLE Beacon UID 22
id23: BLE Beacon UID 23
id24: BLE Beacon UID 24
id25: BLE Beacon UID 25
Axis X
axis_x
Axis X parameters settings
avg: Average
low: Low Level
high: High Level
prio: Priority
Axis Y
axis_y
Axis Y parameters settings
avg: Average
low: Low Level
high: High Level
prio: Priority
Axis Z
axis_z
Axis Z parameters settings
avg: Average
low: Low Level
high: High Level
prio: Priority
Secondary GPRS Server Setup
backup_server
Battery charge mode
battery_charge_mode
Battery level
battery_level_io
avg: Average
low: Low Level
high: High Level
prio: Priority
Battery voltage
battery_voltage_io
avg: Average
low: Low Level
high: High Level
prio: Priority
Beacon settings
beacon
record: Beacon Records
detection: Beacon detection
BLE common settings
ble_common
BLE LLS #1
ble_lls1_io
low: Low Level
high: High Level
prio: Priority
BLE LLS #2
ble_lls2_io
low: Low Level
high: High Level
prio: Priority
BLE LLS #3
ble_lls3_io
low: Low Level
high: High Level
prio: Priority
BLE LLS #4
ble_lls4_io
low: Low Level
high: High Level
prio: Priority
Bluetooth work mode
local_name: Local name
security_mode: Security mode
bluetooth_auto_connect
mode: Connection mode
external_mac: External Mac
external_pin: External PIN
external_name: External name
Restart (reboot) the device
cpureset
Crash Detection
crash
prio: Priority
trace: Crash Trace
Crash Counter
crash_counter
gnss_duration: GNSS duration
data_codec
codec: Data codec
Delete all stored records
deleterecords
External voltage
external_voltage_io
avg: Average
low: Low Level
high: High Level
prio: Priority
fota
web: Enable
getgps
Send getimeiccid command
getimeiccid
getrecord
mac: Bluetooth MAC Address
GNSS Source
gnss_source
gprs
enabled: GPRS Enabled
GPRS Server Setup
gprs_server
protocol: Server protocol
Green Driving
green_driving_dout3
prio: Priority
output: Output Control
source: Source
max_accel: Max Acceleration
max_angle: Max Angle
max_brake: Max Braking
Phone Numbers
gsm_numbers
Predefined GSM phone numbers
phone1: Phone Number 1
phone2: Phone Number 2
phone3: Phone Number 3
phone4: Phone Number 4
phone5: Phone Number 5
phone6: Phone Number 6
phone7: Phone Number 7
phone8: Phone Number 8
phone9: Phone Number 9
phone10: Phone Number 10
Excessive Idling Detection
idling_dout3
prio: Priority
record: Eventual Records
move_time: Move Timeout
stop_time: Stop Timeout
Dout control via ignition
ignition_controls_dout3
control: DOUT control
timeout: Ignition OFF timeout
Ignition Detection Source
ignition_detection
ign: Ignition Source
Ignition ON Counter
ignition_on_counter
counter_value: Counter value
immobilizer_dout3
output: Output control
priority: Scenario priority
Incoming call action
incoming_call
Digital Input 1 I/O
inputs1_io
avg: Average
low: Low Level
high: High Level
prio: Priority
Digital Input 2
inputs2_io
avg: Average
low: Low Level
high: High Level
prio: Priority
Digital Input 3
inputs3_io
avg: Average
low: Low Level
high: High Level
prio: Priority
jamming_timeout
mode: Scenario priority
LED Indication
led_indication
enabled: Enabled
Limit connection errors
limit_connection_errors
LLS1 Fuel Level
lls1_fuel_level_io
low: Low Level
high: High Level
prio: Priority
LLS2 Fuel Level
lls2_fuel_level_io
low: Low Level
high: High Level
prio: Priority
LLS3 Fuel Level
lls3_fuel_level_io
low: Low Level
high: High Level
prio: Priority
LLS4 Fuel Level
lls4_fuel_level_io
low: Low Level
high: High Level
prio: Priority
LLS5 Fuel Level
lls5_fuel_level_io
low: Low Level
high: High Level
prio: Priority
lvcanblockengine
lvcanclosealldoors
LVCAN setup
lvcan_mode
mode: LVCAN Mode
program: Program number
lvcanopenalldoors
lvcanopentrunk
lvcansetting_engine_work_time
value: Value
lvcanturninglights
lvcanunblockengine
lvcanwindowsclose
time: Closing time
lvcanwindowsopen
time: Opening time
Motion Detection Source
motion_detection
can: CAN Speed
gps: GPS
ignition: Ignition
movement: Movement sensor
Network Time Protocol server
ntp_server
ntp_server1: NTP Server 1
ntp_server2: NTP Server 2
low: Low Level
high: High Level
prio: Priority
Absolute load value
obd_absolute_load_value_io
low: Low Level
high: High Level
prio: Priority
Ambient air temperature
low: Low Level
high: High Level
prio: Priority
Barometric pressure
obd_barometric_pressure_io
low: Low Level
high: High Level
prio: Priority
Commanded EGR
obd_commanded_egr_io
low: Low Level
high: High Level
prio: Priority
Command Equivalence Ratio
low: Low Level
high: High Level
prio: Priority
Control module voltage
obd_control_module_voltage_io
low: Low Level
high: High Level
prio: Priority
Coolant Temperature
obd_coolant_temperature_io
low: Low Level
high: High Level
prio: Priority
Direct fuel rail pressure
low: Low Level
high: High Level
prio: Priority
Distance traveled MIL on
low: Low Level
high: High Level
prio: Priority
low: Low Level
high: High Level
prio: Priority
EGR error
obd_egr_error_io
low: Low Level
high: High Level
prio: Priority
Engine Load
obd_engine_load_io
low: Low Level
high: High Level
prio: Priority
Engine oil temperature
obd_engine_oil_temperature_io
low: Low Level
high: High Level
prio: Priority
Engine RPM
obd_engine_rpm_io
low: Low Level
high: High Level
prio: Priority
Fault Codes
obd_fault_codes_io
prio: Priority
Fuel injection timing
obd_fuel_injection_timing_io
low: Low Level
high: High Level
prio: Priority
Fuel level
obd_fuel_level_io
low: Low Level
high: High Level
prio: Priority
Fuel Pressure
obd_fuel_pressure_io
low: Low Level
high: High Level
prio: Priority
Fuel Rate
obd_fuel_rate_io
low: Low Level
high: High Level
prio: Priority
Fuel Type
obd_fuel_type_io
low: Low Level
high: High Level
prio: Priority
low: Low Level
high: High Level
prio: Priority
Hybrid Vehicle System Current
low: Low Level
high: High Level
prio: Priority
Hybrid Vehicle System Voltage
low: Low Level
high: High Level
prio: Priority
obd_intake_air_temperature_io
low: Low Level
high: High Level
prio: Priority
Intake MAP 2b
obd_intake_map_2b_io
low: Low Level
high: High Level
prio: Priority
Intake Map
obd_intake_map_io
low: Low Level
high: High Level
prio: Priority
MAF
obd_maf_io
low: Low Level
high: High Level
prio: Priority
Number Of DTC
obd_number_of_dtc_io
low: Low Level
high: High Level
prio: Priority
OEM Battery Charge Level
low: Low Level
high: High Level
prio: Priority
OEM Battery Charge State
low: Low Level
high: High Level
prio: Priority
OEM Distance Until Service
low: Low Level
high: High Level
prio: Priority
OEM Fuel Level
obd_oem_fuel_level_io
low: Low Level
high: High Level
prio: Priority
OEM Remaining Distance
obd_oem_remaining_distance_io
low: Low Level
high: High Level
prio: Priority
OEM Total Mileage
obd_oem_total_mileage_io
low: Low Level
high: High Level
prio: Priority
Relative fuel rail pressure
low: Low Level
high: High Level
prio: Priority
Run time since engine start
low: Low Level
high: High Level
prio: Priority
Short Fuel Trim
obd_short_fuel_trim_io
low: Low Level
high: High Level
prio: Priority
Throttle position
obd_throttle_position_io
low: Low Level
high: High Level
prio: Priority
Time run with MIL on
obd_time_run_with_mil_on_io
low: Low Level
high: High Level
prio: Priority
low: Low Level
high: High Level
prio: Priority
Timing advance
obd_timing_advance_io
low: Low Level
high: High Level
prio: Priority
Vehicle speed
obd_vehicle_speed_io
low: Low Level
high: High Level
prio: Priority
VIN
obd_vin_io
prio: Priority
odometer_fmb
source: Calculation source
odometer_io
Enable odometer
low: Low Level
high: High Level
prio: Priority
ain1: AIN 1
ain2: AIN 2
din1: DIN 1
din2: DIN 2
din3: DIN 3
Tracking on demand mode
on_demand_mode
type: On demand tracking mode
Tracking on demand timing
on_demand_params
period: Tracking period
duration: Tracking duration
Digital Outputs
outputs3
out1: Output 1
out2: Output 2
out3: Output 3
Overspeeding
overspeeding_dout3
prio: Priority
max_speed: Max Speed
Format SD card
sdformat
SECO - secure engine cut-off
seco_dout3
pulse: Output Pulse
setdigout_3
SMS Event 1
sms_event1
avl_id: SMS Event AVL ID
event_text: SMS Event Text
gsm_number: GSM Number ID
SMS Event 10
sms_event10
SMS Event 2
sms_event2
SMS Event 3
sms_event3
SMS Event 4
sms_event4
SMS Event 5
sms_event5
SMS Event 6
sms_event6
SMS Event 7
sms_event7
SMS Event 8
sms_event8
SMS Event 9
sms_event9
SMS report sending parameters
sms_reports
Static Navigation
static_filter
stat_nav: Static Navigation
SMS event Time Zone
timezone_sms
Enable connection over TLS
tls
enable: TLS enable
Towing Detection
towing
call: Call
prio: Priority
act_time: Activation Timeout
evt_time: Event Timeout
Trip Odometer
trip_odometer_io
low: Low Level
high: High Level
prio: Priority
Trip scenario parameters
trip_scenario
prio: Priority
start_speed: Start speed
Unknown GSM Network Settings
unknown_network
Unplug Detection
unplug
prio: Priority
web_connect
{"text":"getver"}
