Teltonika FMM640
Teltonika FMM640 is a leading GNSS/LTE CAT-M1/NB-IoT/GSM GPS tracker designed for advanced applications with high capacity backup battery and external antennas. The device features FMS CAN data (J1939), fuel CAN data (J1708), tachograph live data (K-line), remote tachograph file download, RS232/RS485 serial communication interfaces, 550 mAh Ni-Mh battery, Dual-SIM, Bluetooth for external devices and Low Energy sensors, and more.
Settings (52)
Commands (8)
Teltonika FMM640
Flespi parses telemetry data from your Teltonika FMM640 into a standardized JSON and lets you send commands to Teltonika FMM640 via API.
    "device.type.id": "Teltonika FMM640",
How to send commands to Teltonika FMM640?
Accelerometer auto calibration
accelerometer_calibration
Analog Input 1 I/O
analog_input1_io
avg: Average
low: Low Level
high: High Level
prio: Priority
Axis X
axis_x
Axis X parameters settings
avg: Average
low: Low Level
high: High Level
prio: Priority
Axis Y
axis_y
Axis Y parameters settings
avg: Average
low: Low Level
high: High Level
prio: Priority
Axis Z
axis_z
Axis Z parameters settings
avg: Average
low: Low Level
high: High Level
prio: Priority
Secondary GPRS Server Setup
backup_server_fmb640
mode: Secondary GPRS server mode
Battery charge mode
battery_charge_mode
Battery level
battery_level_io
avg: Average
low: Low Level
high: High Level
prio: Priority
Battery voltage
battery_voltage_io
avg: Average
low: Low Level
high: High Level
prio: Priority
Restart (reboot) the device
cpureset
data_codec
codec: Data codec
Delete all stored records
deleterecords
External voltage
external_voltage_io
avg: Average
low: Low Level
high: High Level
prio: Priority
getgps
Send getimeiccid command
getimeiccid
getrecord
id: Device configuration ID
modem: Modem version
bootloader_version: Bootloader version
GNSS Source
gnss_source
gprs
enabled: GPRS Enabled
GPRS Server Setup
gprs_server
protocol: Server protocol
Excessive Idling Detection
idling_dout3
prio: Priority
output: Output Control
record: Eventual Records
move_time: Move Timeout
stop_time: Stop Timeout
Ignition Detection Source
ignition_detection
Ignition source is configurable and used to determine vehicle ignition status. Ignition status is used in power management and the following functionalities: eco driving, excessive idling, fuel consumption, over speeding, towing and trip. If multiple sources are needed - enable desired combination of sources.
din1: DIN1
din2: DIN2
din3: DIN3
din4: DIN4
ign_mov: Movement
ign_volt: Power Voltage
Digital Input 1 I/O
inputs1_io
avg: Average
low: Low Level
high: High Level
prio: Priority
Digital Input 2
inputs2_io
avg: Average
low: Low Level
high: High Level
prio: Priority
Digital Input 3
inputs3_io
avg: Average
low: Low Level
high: High Level
prio: Priority
Digital Input 4
inputs4_io
Digital input 4 parameters settings
avg: Average
low: Low Level
high: High Level
prio: Priority
IO Global Send Mode
io_global_send_mode
In IO Global settings a user can set IO value if I/O is not present for 30 seconds. Note: This setting only affects CAN/FMS IO IDs.
Experimental. Manual CAN parameters setup.
manual_can
Experimental command to work with manual CAN parameters. 2 modes: request mode gets specified values from the device, current value mode allows to set up new values.
config: Command mode
can_number: CAN number
Experimental. Manual CAN command parameters setup.
manual_can_command
Experimental command to work with manual CAN command parameters. 2 modes: request mode gets specified values from the device, current value mode allows to set up new values.
Manual CAN Request parameters setup.
manual_can_request
Manual CAN Request parameters setup. 2 modes: request mode gets specified values from the device, current value mode allows to set up new values.
Trigger Manual CAN Command
mcan_cmd
Trigger a configured Manual CAN Command slot. Optionally override CAN ID and data payload.
data: Data override
can_id: CAN ID override
slot_id: Slot ID
mcan_stop
slot_id: Slot ID
network_ping_640
odometer_io
Enable odometer
low: Low Level
high: High Level
prio: Priority
Set total odometer value
odoset
Send odoset/odoget commands
value: Odometer value
Digital Outputs
outputs
out1: Output 1
out2: Output 2
out3: Output 3
out4: Output 4
Overspeeding
overspeeding_dout4
prio: Priority
max_speed: Max Speed
Format SD card
sdformat
setdigout_4
Static Navigation
static_filter
stat_nav: Static Navigation
tachocheck
addr: Addr
baud: Baud
ignition: Ignition
tacho_download_source
value: Value
Tachograph ignition source
tacho_ignition_source
value: Value
Tacho WEB settings
tacho_web
Enable connection over TLS
tls
enable: TLS enable
Trip Odometer
trip_odometer_io
low: Low Level
high: High Level
prio: Priority
Unknown GSM Network Settings
unknown_network
web_connect
{"text":"getrecord"}
Request tachograph file
request_tachograph_file
