Teltonika FMP100
Teltonika FMP100 is a vehicle GNSS tracker plugged into the cigarette lighter port. The device features a built-in 170 mAh Li-ion battery, Bluetooth 4.0, and supports virtual odometer, jamming detection, SMS configuration, overvoltage protection, and more.
Settings (139)
Teltonika FMP100
Flespi parses telemetry data from your Teltonika FMP100 into a standardized JSON and lets you send commands to Teltonika FMP100 via API.
    "device.type.id": "Teltonika FMP100",
How to send commands to Teltonika FMP100?
Accelerometer delay
accelerometer_delay
accelerometer_gravity
ACK Type
ack_type
mode: ACK Type
Allow AGPS in Home Network
agps_home_network
Allow AGPS in Roaming Network
agps_roaming_network
Allow AGPS in Unknown Network
agps_unknown_network
Analog Input 1 I/O
analog_input1_io
avg: Average
low: Low Level
high: High Level
prio: Priority
Authorized beacons list
auth_beacons
id1: BLE Beacon UID 1
id2: BLE Beacon UID 2
id3: BLE Beacon UID 3
id4: BLE Beacon UID 4
id5: BLE Beacon UID 5
id6: BLE Beacon UID 6
id7: BLE Beacon UID 7
id8: BLE Beacon UID 8
id9: BLE Beacon UID 9
id10: BLE Beacon UID 10
id11: BLE Beacon UID 11
id12: BLE Beacon UID 12
id13: BLE Beacon UID 13
id14: BLE Beacon UID 14
id15: BLE Beacon UID 15
id16: BLE Beacon UID 16
id17: BLE Beacon UID 17
id18: BLE Beacon UID 18
id19: BLE Beacon UID 19
id20: BLE Beacon UID 20
id21: BLE Beacon UID 21
id22: BLE Beacon UID 22
id23: BLE Beacon UID 23
id24: BLE Beacon UID 24
id25: BLE Beacon UID 25
Axis X
axis_x
Axis X parameters settings
avg: Average
low: Low Level
high: High Level
prio: Priority
Axis Y
axis_y
Axis Y parameters settings
avg: Average
low: Low Level
high: High Level
prio: Priority
Axis Z
axis_z
Axis Z parameters settings
avg: Average
low: Low Level
high: High Level
prio: Priority
Secondary GPRS Server Setup
backup_server
Battery charge mode
battery_charge_mode
Battery level
battery_level_io
avg: Average
low: Low Level
high: High Level
prio: Priority
Battery voltage
battery_voltage_io
avg: Average
low: Low Level
high: High Level
prio: Priority
Beacon settings
beacon
record: Beacon Records
detection: Beacon detection
BLE common settings
ble_common
BLE LLS #1
ble_lls1_io
low: Low Level
high: High Level
prio: Priority
BLE LLS #2
ble_lls2_io
low: Low Level
high: High Level
prio: Priority
BLE LLS #3
ble_lls3_io
low: Low Level
high: High Level
prio: Priority
BLE LLS #4
ble_lls4_io
low: Low Level
high: High Level
prio: Priority
Bluetooth work mode
local_name: Local name
security_mode: Security mode
bluetooth_auto_connect
mode: Connection mode
external_mac: External Mac
external_pin: External PIN
external_name: External name
Restart (reboot) the device
cpureset
Crash Detection
crash
prio: Priority
trace: Crash Trace
Crash Counter
crash_counter
gnss_duration: GNSS duration
data_codec
codec: Data codec
Delete all stored records
deleterecords
External voltage
external_voltage_io
avg: Average
low: Low Level
high: High Level
prio: Priority
fota
web: Enable
getgps
Send getimeiccid command
getimeiccid
getrecord
mac: Bluetooth MAC Address
GNSS Source
gnss_source
gprs
enabled: GPRS Enabled
GPRS Server Setup
gprs_server
protocol: Server protocol
Green Driving
green_driving_obd
prio: Priority
source: Source
max_accel: Max Acceleration
max_angle: Max Angle
max_brake: Max Braking
Phone Numbers
gsm_numbers
Predefined GSM phone numbers
phone1: Phone Number 1
phone2: Phone Number 2
phone3: Phone Number 3
phone4: Phone Number 4
phone5: Phone Number 5
phone6: Phone Number 6
phone7: Phone Number 7
phone8: Phone Number 8
phone9: Phone Number 9
phone10: Phone Number 10
Excessive Idling Detection
idling_obd
prio: Priority
record: Eventual Records
move_time: Move Timeout
stop_time: Stop Timeout
Ignition Detection Source
ignition_detection
ign: Ignition Source
Ignition ON Counter
ignition_on_counter
counter_value: Counter value
Incoming call action
incoming_call
Digital Input 1 I/O
inputs1_io
avg: Average
low: Low Level
high: High Level
prio: Priority
jamming_timeout
mode: Scenario priority
LED Indication
led_indication
enabled: Enabled
Limit connection errors
limit_connection_errors
LLS1 Fuel Level
lls1_fuel_level_io
low: Low Level
high: High Level
prio: Priority
LLS2 Fuel Level
lls2_fuel_level_io
low: Low Level
high: High Level
prio: Priority
LLS3 Fuel Level
lls3_fuel_level_io
low: Low Level
high: High Level
prio: Priority
LLS4 Fuel Level
lls4_fuel_level_io
low: Low Level
high: High Level
prio: Priority
LLS5 Fuel Level
lls5_fuel_level_io
low: Low Level
high: High Level
prio: Priority
lvcanblockengine
lvcanclosealldoors
LVCAN setup
lvcan_mode
mode: LVCAN Mode
program: Program number
lvcanopenalldoors
lvcanopentrunk
lvcansetting_engine_work_time
value: Value
lvcanturninglights
lvcanunblockengine
lvcanwindowsclose
time: Closing time
lvcanwindowsopen
time: Opening time
Motion Detection Source
motion_detection
can: CAN Speed
gps: GPS
ignition: Ignition
movement: Movement sensor
Network Time Protocol server
ntp_server
ntp_server1: NTP Server 1
ntp_server2: NTP Server 2
low: Low Level
high: High Level
prio: Priority
Absolute load value
obd_absolute_load_value_io
low: Low Level
high: High Level
prio: Priority
Ambient air temperature
low: Low Level
high: High Level
prio: Priority
Barometric pressure
obd_barometric_pressure_io
low: Low Level
high: High Level
prio: Priority
Commanded EGR
obd_commanded_egr_io
low: Low Level
high: High Level
prio: Priority
Command Equivalence Ratio
low: Low Level
high: High Level
prio: Priority
Control module voltage
obd_control_module_voltage_io
low: Low Level
high: High Level
prio: Priority
Coolant Temperature
obd_coolant_temperature_io
low: Low Level
high: High Level
prio: Priority
Direct fuel rail pressure
low: Low Level
high: High Level
prio: Priority
Distance traveled MIL on
low: Low Level
high: High Level
prio: Priority
low: Low Level
high: High Level
prio: Priority
EGR error
obd_egr_error_io
low: Low Level
high: High Level
prio: Priority
Engine Load
obd_engine_load_io
low: Low Level
high: High Level
prio: Priority
Engine oil temperature
obd_engine_oil_temperature_io
low: Low Level
high: High Level
prio: Priority
Engine RPM
obd_engine_rpm_io
low: Low Level
high: High Level
prio: Priority
Fault Codes
obd_fault_codes_io
prio: Priority
Fuel injection timing
obd_fuel_injection_timing_io
low: Low Level
high: High Level
prio: Priority
Fuel level
obd_fuel_level_io
low: Low Level
high: High Level
prio: Priority
Fuel Pressure
obd_fuel_pressure_io
low: Low Level
high: High Level
prio: Priority
Fuel Rate
obd_fuel_rate_io
low: Low Level
high: High Level
prio: Priority
Fuel Type
obd_fuel_type_io
low: Low Level
high: High Level
prio: Priority
low: Low Level
high: High Level
prio: Priority
Hybrid Vehicle System Current
low: Low Level
high: High Level
prio: Priority
Hybrid Vehicle System Voltage
low: Low Level
high: High Level
prio: Priority
obd_intake_air_temperature_io
low: Low Level
high: High Level
prio: Priority
Intake MAP 2b
obd_intake_map_2b_io
low: Low Level
high: High Level
prio: Priority
Intake Map
obd_intake_map_io
low: Low Level
high: High Level
prio: Priority
MAF
obd_maf_io
low: Low Level
high: High Level
prio: Priority
Number Of DTC
obd_number_of_dtc_io
low: Low Level
high: High Level
prio: Priority
OEM Battery Charge Level
low: Low Level
high: High Level
prio: Priority
OEM Battery Charge State
low: Low Level
high: High Level
prio: Priority
OEM Distance Until Service
low: Low Level
high: High Level
prio: Priority
OEM Fuel Level
obd_oem_fuel_level_io
low: Low Level
high: High Level
prio: Priority
OEM Remaining Distance
obd_oem_remaining_distance_io
low: Low Level
high: High Level
prio: Priority
OEM Total Mileage
obd_oem_total_mileage_io
low: Low Level
high: High Level
prio: Priority
Relative fuel rail pressure
low: Low Level
high: High Level
prio: Priority
Run time since engine start
low: Low Level
high: High Level
prio: Priority
Short Fuel Trim
obd_short_fuel_trim_io
low: Low Level
high: High Level
prio: Priority
Throttle position
obd_throttle_position_io
low: Low Level
high: High Level
prio: Priority
Time run with MIL on
obd_time_run_with_mil_on_io
low: Low Level
high: High Level
prio: Priority
low: Low Level
high: High Level
prio: Priority
Timing advance
obd_timing_advance_io
low: Low Level
high: High Level
prio: Priority
Vehicle speed
obd_vehicle_speed_io
low: Low Level
high: High Level
prio: Priority
VIN
obd_vin_io
prio: Priority
odometer_fmb
source: Calculation source
odometer_io
Enable odometer
low: Low Level
high: High Level
prio: Priority
Tracking on demand mode
on_demand_mode
type: On demand tracking mode
Tracking on demand timing
on_demand_params
period: Tracking period
duration: Tracking duration
Overspeeding
overspeeding_obd
prio: Priority
max_speed: Max Speed
Format SD card
sdformat
SMS Event 1
sms_event1
avl_id: SMS Event AVL ID
event_text: SMS Event Text
gsm_number: GSM Number ID
SMS Event 10
sms_event10
SMS Event 2
sms_event2
SMS Event 3
sms_event3
SMS Event 4
sms_event4
SMS Event 5
sms_event5
SMS Event 6
sms_event6
SMS Event 7
sms_event7
SMS Event 8
sms_event8
SMS Event 9
sms_event9
SMS report sending parameters
sms_reports
Static Navigation
static_filter
stat_nav: Static Navigation
SMS event Time Zone
timezone_sms
Enable connection over TLS
tls
enable: TLS enable
Towing Detection
towing
call: Call
prio: Priority
act_time: Activation Timeout
evt_time: Event Timeout
Trip Odometer
trip_odometer_io
low: Low Level
high: High Level
prio: Priority
Trip scenario parameters
trip_scenario
prio: Priority
start_speed: Start speed
Unknown GSM Network Settings
unknown_network
Unplug Detection
unplug
prio: Priority
web_connect
{"text":"getver"}
