Teltonika FTC305
Teltonika FTC305 is a new generation e-bikes, e-scooters and e-forklifts tracker featuring CAN interface, 10-97V, LTE CAT-1, GNSS, Bluetooth 5.2, Nano-SIM, accelerometer, internal GNSS and LTE antennas, 380 mAh LiPo backup battery, 2x DOUT, 1x DIN/AIN, 7-pin cable and IP67 casing
Settings (13)
Teltonika FTC305
Flespi parses telemetry data from your Teltonika FTC305 into a standardized JSON and lets you send commands to Teltonika FTC305 via API.
    "device.type.id": "Teltonika FTC305",
How to send commands to Teltonika FTC305?
mac: Bluetooth MAC Address
Manual CAN parameters setup.
manual_can
Command to work with manual CAN I/O parameters. 2 modes: request mode gets specified values from the device, current value mode allows to set up new values. CAN bus selection is not per I/O, it is configured in General CAN settings.
config: Command mode
can_number: CAN number
Manual CAN command parameters setup.
manual_can_command
Command to work with manual CAN command parameters. 2 modes: request mode gets specified values from the device, current value mode allows to set up new values. CAN bus selection is not per command, it is configured in General CAN settings.
Trigger Manual CAN Command
mcan_cmd
Trigger a configured Manual CAN Command slot.
slot_id: Slot ID
mcan_stop
slot_id: Slot ID
Digital Outputs
outputs2
out1: Output 1
out2: Output 2
Permanent Link
permalink
setdigout_2
{"text":"getver"}
