Teltonika FTC965
Teltonika FTC965 is a next-generation high-voltage 4G LTE Cat 1 vehicle GPS tracker with enhanced GNSS accuracy and IP69K waterproof protection. It supports GPS, GLONASS, Galileo, and BeiDou satellite systems for precise positioning. Designed for fleet telematics, logistics, agriculture, and e-mobility management, the device operates on a wide voltage input range of 10–90V DC and includes a 320 mAh internal Li-Ion backup battery. Bluetooth 5.4 LE connectivity enables wireless integration of external sensors and beacons for monitoring temperature, humidity, and movement. Optimized sleep modes reduce vehicle battery drainage while maintaining reliable tracking across diverse vehicle types.
Settings (9)
Teltonika FTC965
Flespi parses telemetry data from your Teltonika FTC965 into a standardized JSON and lets you send commands to Teltonika FTC965 via API.
    "device.type.id": "Teltonika FTC965",
How to send commands to Teltonika FTC965?
mac: Bluetooth MAC Address
Digital Output
outputs1
out1: Output
Permanent Link
permalink
setdigout_1
{"text":"getrecord"}
