Teltonika FTM880
Teltonika FTM880 is a next-generation 4G LTE Cat M1 battery-mounted vehicle GPS tracker built on the Fleet Telematics (FT) platform. It connects directly to the vehicle battery (10–30V DC) for primary power and includes a 320 mAh internal backup battery. GNSS support covers GPS, GLONASS, Galileo, and BeiDou with up to 41 visible satellites and position accuracy under 1.8m CEP. Built-in Bluetooth Low Energy enables connectivity with EYE sensors and device configuration. The rugged IP69K-rated enclosure offers maximum resistance to dust, high-pressure water, and steam. Optimised sleep modes significantly reduce vehicle battery drain for extended deployments. Designed for fleet telematics, car sharing, agriculture, construction, and mining applications.
Teltonika FTM880
Flespi parses telemetry data from your Teltonika FTM880 into a standardized JSON and lets you send commands to Teltonika FTM880 via API.
    "device.type.id": "Teltonika FTM880",
How to send commands to Teltonika FTM880?
mac: Bluetooth MAC Address
Permanent Link
permalink
{"text":"getver"}
