Teltonika TAT100
Teltonika TAT100 is a robust, small, and easy-to-install asset tracker with up to 3 years of battery life. The device features enhanced tamper detection, accelerometer wake-up, GNSS and LBS, indoor tracking, recovery mode, movement detection, scheduler with time zones, tracking on stop / on move, backup tracking, static navigation, BLE 5.0, IP68 casing, 2200 mAh Li-SOCl2 battery, 4 mounting options, and more.
Parameters (1157)
Settings (12)
Teltonika TAT100
Flespi parses telemetry data from your Teltonika TAT100 into a standardized JSON and lets you send commands to Teltonika TAT100 via API.
    "device.type.id": "Teltonika TAT100",
How to send commands to Teltonika TAT100?
AVL ID 168
Restart (reboot) the device
cpureset
Delete all stored records
deleterecords
getgps
Send getimeiccid command
getimeiccid
getrecord
mac: Bluetooth MAC Address
GNSS Source
gnss_source
gprs
enabled: GPRS Enabled
GPRS Server Setup
gprs_server
protocol: Server protocol
Format SD card
sdformat
SMS event Time Zone
timezone_sms
web_connect
{"text":"getrecord"}
