Teltonika TFT100
Teltonika TFT100 is a GPS tracker for e-forklifts, e-mopeds, and e-scooters tracking and management. The device features internal high gain GNSS/GSM antennas, Bluetooth 4.0+LE, 1800 mAh internal Li-ion battery, 10-97 V power supply range, and a variety of interfaces (1-Wire, RS232, RS485, CAN).
Settings (81)
Teltonika TFT100
Flespi parses telemetry data from your Teltonika TFT100 into a standardized JSON and lets you send commands to Teltonika TFT100 via API.
    "device.type.id": "Teltonika TFT100",
How to send commands to Teltonika TFT100?
Accelerometer delay
accelerometer_delay
accelerometer_gravity
Analog Input 1 I/O
analog_input1_io
avg: Average
low: Low Level
high: High Level
prio: Priority
Analog Input 2 I/O
analog_input2_io
avg: Average
low: Low Level
high: High Level
prio: Priority
Sounds the horn of the Askoll e-scooter
askoll_horn
Sounds the horn of the Askoll e-scooter. Used to identify the Askoll e-scooter in the street. Note, command works over specific CAN communication protocol and will not work with other vehicles.
Askoll e-scooter's top case opening.
askoll_tc
Top case opening. Used to open the Askoll e-scooters luggage compartment. Note, command works over specific CAN communication protocol and will not work with other vehicles.
Immobilizer. Used to lock/unlock the Askoll e-scooter
askoll_unlock
Immobilizer. Used to lock/unlock the Askoll e-scooter. Note, command works over specific CAN communication protocol and will not work with other vehicles.
lock: Lock/Unlock
Authorized beacons list
auth_beacons
id1: BLE Beacon UID 1
id2: BLE Beacon UID 2
id3: BLE Beacon UID 3
id4: BLE Beacon UID 4
id5: BLE Beacon UID 5
id6: BLE Beacon UID 6
id7: BLE Beacon UID 7
id8: BLE Beacon UID 8
id9: BLE Beacon UID 9
id10: BLE Beacon UID 10
id11: BLE Beacon UID 11
id12: BLE Beacon UID 12
id13: BLE Beacon UID 13
id14: BLE Beacon UID 14
id15: BLE Beacon UID 15
id16: BLE Beacon UID 16
id17: BLE Beacon UID 17
id18: BLE Beacon UID 18
id19: BLE Beacon UID 19
id20: BLE Beacon UID 20
id21: BLE Beacon UID 21
id22: BLE Beacon UID 22
id23: BLE Beacon UID 23
id24: BLE Beacon UID 24
id25: BLE Beacon UID 25
Axis X
axis_x
Axis X parameters settings
avg: Average
low: Low Level
high: High Level
prio: Priority
Axis Y
axis_y
Axis Y parameters settings
avg: Average
low: Low Level
high: High Level
prio: Priority
Axis Z
axis_z
Axis Z parameters settings
avg: Average
low: Low Level
high: High Level
prio: Priority
Secondary GPRS Server Setup
backup_server
Battery charge mode
battery_charge_mode
Battery level
battery_level_io
avg: Average
low: Low Level
high: High Level
prio: Priority
Battery voltage
battery_voltage_io
avg: Average
low: Low Level
high: High Level
prio: Priority
Beacon settings
beacon
record: Beacon Records
detection: Beacon detection
BLE common settings
ble_common
Bluetooth work mode
local_name: Local name
security_mode: Security mode
bluetooth_auto_connect
mode: Connection mode
external_mac: External Mac
external_pin: External PIN
external_name: External name
Restart (reboot) the device
cpureset
data_codec
codec: Data codec
Delete all stored records
deleterecords
External voltage
external_voltage_io
avg: Average
low: Low Level
high: High Level
prio: Priority
fota
web: Enable
getgps
Send getimeiccid command
getimeiccid
getrecord
mac: Bluetooth MAC Address
GNSS Source
gnss_source
gprs
enabled: GPRS Enabled
GPRS Server Setup
gprs_server
protocol: Server protocol
Phone Numbers
gsm_numbers
Predefined GSM phone numbers
phone1: Phone Number 1
phone2: Phone Number 2
phone3: Phone Number 3
phone4: Phone Number 4
phone5: Phone Number 5
phone6: Phone Number 6
phone7: Phone Number 7
phone8: Phone Number 8
phone9: Phone Number 9
phone10: Phone Number 10
Ignition Detection Source
ignition_detection
ign: Ignition Source
Incoming call action
incoming_call
Digital Input 1 I/O
inputs1_io
avg: Average
low: Low Level
high: High Level
prio: Priority
Digital Input 2
inputs2_io
avg: Average
low: Low Level
high: High Level
prio: Priority
Digital Input 3
inputs3_io
avg: Average
low: Low Level
high: High Level
prio: Priority
jamming_timeout
mode: Scenario priority
LED Indication
led_indication
enabled: Enabled
Manual CAN Command 0
manual_can_0
Configure Manual CAN Command 0 parameters for sending custom CAN messages
data: Data Payload
can_id: CAN ID
can_type: CAN Type
send_type: Send Type
send_count: Send Count
data_length: Data Length
send_period: Send Period (ms)
run_on_startup: Run On Startup
response_trigger: Response Trigger
Manual CAN Command 1
manual_can_1
Configure Manual CAN Command 1 parameters for sending custom CAN messages
data: Data Payload
can_id: CAN ID
can_type: CAN Type
Manual CAN Command 2
manual_can_2
Configure Manual CAN Command 2 parameters for sending custom CAN messages
data: Data Payload
can_id: CAN ID
can_type: CAN Type
Manual CAN Command 3
manual_can_3
Configure Manual CAN Command 3 parameters for sending custom CAN messages
data: Data Payload
can_id: CAN ID
can_type: CAN Type
Manual CAN Command 4
manual_can_4
Configure Manual CAN Command 4 parameters for sending custom CAN messages
data: Data Payload
can_id: CAN ID
can_type: CAN Type
Manual CAN Command 5
manual_can_5
Configure Manual CAN Command 5 parameters for sending custom CAN messages
data: Data Payload
can_id: CAN ID
can_type: CAN Type
Manual CAN Command 6
manual_can_6
Configure Manual CAN Command 6 parameters for sending custom CAN messages
data: Data Payload
can_id: CAN ID
can_type: CAN Type
Manual CAN Command 7
manual_can_7
Configure Manual CAN Command 7 parameters for sending custom CAN messages
data: Data Payload
can_id: CAN ID
can_type: CAN Type
Manual CAN Command 8
manual_can_8
Configure Manual CAN Command 8 parameters for sending custom CAN messages
data: Data Payload
can_id: CAN ID
can_type: CAN Type
Manual CAN Command 9
manual_can_9
Configure Manual CAN Command 9 parameters for sending custom CAN messages
data: Data Payload
can_id: CAN ID
can_type: CAN Type
Motion Detection Source
motion_detection
can: CAN Speed
gps: GPS
ignition: Ignition
movement: Movement sensor
Network Time Protocol server
ntp_server
ntp_server1: NTP Server 1
ntp_server2: NTP Server 2
odometer_fmb
source: Calculation source
odometer_io
Enable odometer
low: Low Level
high: High Level
prio: Priority
ain1: AIN 1
ain2: AIN 2
din1: DIN 1
din2: DIN 2
din3: DIN 3
Digital Outputs
outputs2
out1: Output 1
out2: Output 2
Permanent Link
permalink
Permanent Link
Format SD card
sdformat
setdigout_2
SMS Event 1
sms_event1
avl_id: SMS Event AVL ID
event_text: SMS Event Text
gsm_number: GSM Number ID
SMS Event 10
sms_event10
SMS Event 2
sms_event2
SMS Event 3
sms_event3
SMS Event 4
sms_event4
SMS Event 5
sms_event5
SMS Event 6
sms_event6
SMS Event 7
sms_event7
SMS Event 8
sms_event8
SMS Event 9
sms_event9
SMS report sending parameters
sms_reports
Static Navigation
static_filter
stat_nav: Static Navigation
SMS event Time Zone
timezone_sms
Enable connection over TLS
tls
enable: TLS enable
Trip Odometer
trip_odometer_io
low: Low Level
high: High Level
prio: Priority
Trip scenario parameters
trip_scenario
prio: Priority
record: Eventual Records
start_speed: Start speed
Unknown GSM Network Settings
unknown_network
web_connect
{"text":"getrecord"}
