Event 4001,
Event 4001...4005,
Event 4002,
Event 4006,
Event 4012,
Event 6001,
Event 6001...6003,
Event 6002,
Event 6004,
Event 6005...6008,
Event 6005...6010,
Event 6005...6014,
Event 6011,
Event 6012,
Event 6012...6014,
Event 6015,
Event 6016...6018,
Event 6016...6020,
Event 6023...6025,
Event 6027,
Event 6030...6032,
Event 6034,
Event 6035,
Event 6036,
Event 6037...6043,
Event 6044,
Event 6048,
Event 6049,
Event 6070...6076,
Event 6071,
Event 6073,
Event 6076,
Event 6079,
Event 6090...6093,
Event 6092,
Event 6093
absolute.deceleration
Event 4001,
Event 4001...4005,
Event 4002,
Event 4006,
Event 4012,
Event 6001,
Event 6001...6003,
Event 6002,
Event 6004,
Event 6005...6008,
Event 6005...6010,
Event 6005...6014,
Event 6011,
Event 6012,
Event 6012...6014,
Event 6015,
Event 6016...6018,
Event 6016...6020,
Event 6023...6025,
Event 6027,
Event 6030...6032,
Event 6034,
Event 6035,
Event 6036,
Event 6037...6043,
Event 6044,
Event 6048,
Event 6049,
Event 6070...6076,
Event 6071,
Event 6073,
Event 6076,
Event 6079,
Event 6090...6093,
Event 6092,
Event 6093
acceleration.end.direction
Acceleration end direction
Param ID 0x24 (Binary protocol)
acceleration.end.latitude
Latitude point at which the acceleration ended
Param ID 0x21 (Binary protocol)
acceleration.end.longitude
Longitude point at which the acceleration ended
Param ID 0x22 (Binary protocol)
acceleration.end.speed
Acceleration end speed
Param ID 0x23 (Binary protocol)
acceleration.end.timestamp
Acceleration end time
Param ID 0x20 (Binary protocol)
acceleration.start.direction
Acceleration start direction
Param ID 0x1D (Binary protocol)
acceleration.start.latitude
Latitude point from which acceleration began
Param ID 0x1A (Binary protocol)
acceleration.start.longitude
Longitude point from which acceleration began
Param ID 0x1B (Binary protocol)
acceleration.start.speed
Acceleration start speed
Param ID 0x1C (Binary protocol)
acceleration.start.timestamp
Acceleration start time
Param ID 0x19 (Binary protocol)
Event 4001,
Event 4002,
Event 4006,
Event 6001...6003,
Event 6004,
Event 6005...6008,
Event 6011,
Event 6012,
Event 6015,
Event 6016...6018,
Event 6023...6025,
Event 6030...6032,
Event 6037...6043,
Param ID 0x66 (Binary protocol),
Param ID 0xc9 (Binary protocol)
Event 4001,
Event 4001...4005,
Event 4002,
Event 4006,
Event 4012,
Event 6001...6003,
Event 6004,
Event 6005...6008,
Event 6005...6010,
Event 6011,
Event 6012,
Event 6012...6014,
Event 6015,
Event 6016...6018,
Event 6023...6025,
Event 6027,
Event 6030...6032,
Event 6035,
Event 6036,
Event 6037...6043,
Event 6071,
Event 6073,
Event 6076,
Event 6090...6093,
Param ID 0x7D (Binary protocol)
Event 4001,
Event 4001...4005,
Event 4002,
Event 4003,
Event 4004,
Event 4005,
Event 4006,
Event 4012,
Event 6001,
Event 6002,
Event 6004,
Event 6005,
Event 6005...6014,
Event 6009,
Event 6010,
Event 6011,
Event 6012,
Event 6013,
Event 6014,
Event 6015,
Event 6016...6020,
Event 6027,
Event 6030...6032,
Event 6034,
Event 6035,
Event 6044,
Event 6048,
Event 6049,
Event 6070...6076,
Event 6070...6079,
Event 6079,
Event 6084,
Event 6085,
Event 6092,
Event 6093
Event 4001,
Event 4001...4005,
Event 4002,
Event 4003,
Event 4004,
Event 4005,
Event 4006,
Event 4012,
Event 6001,
Event 6001...6003,
Event 6002,
Event 6004,
Event 6005,
Event 6005...6008,
Event 6005...6010,
Event 6005...6014,
Event 6009,
Event 6010,
Event 6011,
Event 6012,
Event 6012...6014,
Event 6013,
Event 6014,
Event 6015,
Event 6016...6018,
Event 6016...6020,
Event 6023...6025,
Event 6027,
Event 6030...6032,
Event 6034,
Event 6035,
Event 6036,
Event 6037...6043,
Event 6044,
Event 6048,
Event 6049,
Event 6070...6076,
Event 6070...6079,
Event 6071,
Event 6073,
Event 6076,
Event 6079,
Event 6084,
Event 6085,
Event 6090...6093,
Event 6092,
Event 6093,
Param ID 0x16 (Binary protocol),
Param ID 0xc8 (Binary protocol)
Param ID 0x52 (Binary protocol)
Param ID 0x7E (Binary protocol)
Param ID 0x79 (Binary protocol)
*code* - Trouble code, e.g. P0100 (OBDII)
*extension* - Failure type byte of the trouble code in hex (OBDII)
*protocol* - Diagnostic protocol the code was read with (OBD, J1939, J1708, UDS, KWP2000)
Event 6044,
Event 6045
Event 4001,
Event 4002,
Event 4006,
Event 6001...6003,
Event 6004,
Event 6005...6008,
Event 6011,
Event 6012,
Event 6015,
Event 6016...6018,
Event 6023...6025,
Event 6030...6032,
Event 6037...6043,
Param ID 0x86 (Binary protocol)
Event 4001,
Event 4002,
Event 4006,
Event 6001...6003,
Event 6004,
Event 6005...6008,
Event 6011,
Event 6012,
Event 6015,
Event 6016...6018,
Event 6023...6025,
Event 6030...6032,
Event 6037...6043,
Param ID 0x83 (Binary protocol)
Event 4001,
Event 4002,
Event 4006,
Event 6001...6003,
Event 6004,
Event 6005...6008,
Event 6011,
Event 6012,
Event 6015,
Event 6016...6018,
Event 6023...6025,
Event 6030...6032,
Event 6037...6043,
Param ID 0x59 (Binary protocol)
Param ID 0x2C (Binary protocol),
Param ID 0xd7 (Binary protocol)
Event 4001,
Event 4002,
Event 4006,
Event 6001...6003,
Event 6004,
Event 6005...6008,
Event 6011,
Event 6012,
Event 6015,
Event 6016...6018,
Event 6023...6025,
Event 6030...6032,
Event 6037...6043,
Param ID 0x7F (Binary protocol)
Event 4001,
Event 4002,
Event 4006,
Event 6001...6003,
Event 6004,
Event 6005...6008,
Event 6011,
Event 6012,
Event 6015,
Event 6016...6018,
Event 6023...6025,
Event 6030...6032,
Event 6037...6043,
Param ID 0x56 (Binary protocol),
Param ID 0xd6 (Binary protocol)
Event 4001,
Event 4002,
Event 4006,
Event 6001...6003,
Event 6004,
Event 6005...6008,
Event 6011,
Event 6012,
Event 6015,
Event 6016...6018,
Event 6023...6025,
Event 6030...6032,
Event 6037...6043,
Param ID 0x81 (Binary protocol)
Param ID 0x82 (Binary protocol)
Event 4001,
Event 4001...4005,
Event 4002,
Event 4006,
Event 4012,
Event 6001,
Event 6001...6003,
Event 6002,
Event 6004,
Event 6005...6008,
Event 6005...6014,
Event 6011,
Event 6012,
Event 6015,
Event 6016...6018,
Event 6016...6020,
Event 6023...6025,
Event 6027,
Event 6030...6032,
Event 6034,
Event 6035,
Event 6037...6043,
Event 6044,
Event 6048,
Event 6049,
Event 6070...6076,
Event 6079,
Event 6092,
Event 6093,
Param ID 0x7B (Binary protocol)
Param ID 0x58 (Binary protocol)
Param ID 0x80 (Binary protocol)
Param ID 0x55 (Binary protocol),
Param ID 0x5E (Binary protocol)
Param ID 0x5A (Binary protocol)
Param ID 0x7A (Binary protocol)
Param ID 0x84 (Binary protocol)
Intake manifold temperature
Param ID 0x85 (Binary protocol)
Event 6045
Param ID 0x71 (Binary protocol)
Param ID 0xc7 (Binary protocol)
Param ID 0x7C (Binary protocol)
Param ID 0x5C (Binary protocol)
Param ID 0x5B (Binary protocol),
Param ID 0xD5 (Binary protocol)
Param ID 0x5D (Binary protocol)
Param ID 0x2E (Binary protocol)
can.vehicle.harsh.acceleration
Read from CAN. Acceleration of a vehicle
Param ID 0x93 (Binary protocol)
can.vehicle.harsh.braking
Read from CAN. Braking of a vehicle
Param ID 0x94 (Binary protocol)
Param ID 0x57 (Binary protocol)
Param ID 0x73 (Binary protocol)
Param ID 0x95 (Binary protocol)
Event 4001,
Event 4001...4005,
Event 4002,
Event 4006,
Event 4012,
Event 6001,
Event 6001...6003,
Event 6002,
Event 6004,
Event 6005...6008,
Event 6005...6014,
Event 6011,
Event 6012,
Event 6015,
Event 6016...6018,
Event 6016...6020,
Event 6023...6025,
Event 6027,
Event 6030...6032,
Event 6034,
Event 6035,
Event 6037...6043,
Event 6044,
Event 6048,
Event 6049,
Event 6070...6076,
Event 6079,
Event 6092,
Event 6093,
Param ID 0x0C (Binary protocol),
Param ID 0x53 (Binary protocol),
Event 4001,
Event 4002,
Event 4006,
Event 6001...6003,
Event 6004,
Event 6005...6008,
Event 6011,
Event 6012,
Event 6015,
Event 6016...6018,
Event 6023...6025,
Event 6030...6032,
Event 6037...6043,
Param ID 0x0D (Binary protocol)
Param ID 0x0E (Binary protocol),
Param ID 0x0F (Binary protocol)
Event 4001...4005,
Event 4006,
Event 4012,
Event 6001,
Event 6002,
Event 6005...6014,
Event 6015,
Event 6016...6020,
Event 6027,
Event 6030...6032,
Event 6034,
Event 6035,
Event 6044,
Event 6048,
Event 6049,
Event 6070...6076,
Event 6079,
Event 6092,
Event 6093
Event 4001,
Event 4002,
Event 4003,
Event 4004,
Event 6011,
Event 6012,
Event 6013,
Event 6014
engine.oil.pressure
Engine oil pressure
Event 4001,
Event 4002,
Event 4006,
Event 6001...6003,
Event 6004,
Event 6005...6008,
Event 6011,
Event 6012,
Event 6015,
Event 6016...6018,
Event 6023...6025,
Event 6030...6032,
Event 6037...6043
Event 4001,
Event 4001...4005,
Event 4002,
Event 4006,
Event 4012,
Event 6001...6003,
Event 6004,
Event 6005...6008,
Event 6005...6010,
Event 6011,
Event 6012,
Event 6012...6014,
Event 6015,
Event 6016...6018,
Event 6023...6025,
Event 6027,
Event 6030...6032,
Event 6035,
Event 6036,
Event 6037...6043,
Event 6071,
Event 6073,
Event 6076,
Event 6090...6093
Param ID 0x04 (Binary protocol)
Event 4001,
Event 4001...4005,
Event 4002,
Event 4003,
Event 4004,
Event 4005,
Event 4006,
Event 4012,
Event 6001,
Event 6002,
Event 6004,
Event 6005,
Event 6005...6014,
Event 6009,
Event 6010,
Event 6011,
Event 6012,
Event 6013,
Event 6014,
Event 6015,
Event 6016...6020,
Event 6027,
Event 6030...6032,
Event 6034,
Event 6035,
Event 6044,
Event 6048,
Event 6049,
Event 6070...6076,
Event 6070...6079,
Event 6079,
Event 6084,
Event 6085,
Event 6092,
Event 6093
Event 4001,
Event 4001...4005,
Event 4002,
Event 4006,
Event 4012,
Event 6001...6003,
Event 6004,
Event 6005...6008,
Event 6005...6010,
Event 6011,
Event 6012,
Event 6012...6014,
Event 6015,
Event 6016...6018,
Event 6023...6025,
Event 6027,
Event 6030...6032,
Event 6035,
Event 6036,
Event 6037...6043,
Event 6071,
Event 6073,
Event 6076,
Event 6090...6093
garmin.status
Garmin FMI module status
Param ID 0xcc (Binary protocol),
Param ID 0xcd (Binary protocol)
Event 4001,
Event 4001...4005,
Event 4002,
Event 4006,
Event 4012,
Event 6001,
Event 6001...6003,
Event 6002,
Event 6004,
Event 6005...6008,
Event 6005...6010,
Event 6005...6014,
Event 6011,
Event 6012,
Event 6012...6014,
Event 6015,
Event 6016...6018,
Event 6016...6020,
Event 6023...6025,
Event 6027,
Event 6030...6032,
Event 6034,
Event 6035,
Event 6036,
Event 6037...6043,
Event 6044,
Event 6048,
Event 6049,
Event 6070...6076,
Event 6071,
Event 6073,
Event 6076,
Event 6079,
Event 6090...6093,
Event 6092,
Event 6093
gps.state.enum
GPS state
Event 4001,
Event 4002,
Event 4003,
Event 4004,
Event 4005,
Event 4006,
Event 6001,
Event 6002,
Event 6004,
Event 6005,
Event 6009,
Event 6010,
Event 6011,
Event 6012,
Event 6013,
Event 6014,
Event 6015,
Event 6016...6020,
Event 6027,
Event 6030...6032,
Event 6035,
Event 6045,
Event 6048,
Event 6049,
Event 6070...6079,
Event 6084,
Event 6085
Param ID 0xd4 (Binary protocol)
Event 4001,
Event 4001...4005,
Event 4002,
Event 4003,
Event 4004,
Event 4005,
Event 4006,
Event 4012,
Event 6001,
Event 6001...6003,
Event 6002,
Event 6004,
Event 6005,
Event 6005...6008,
Event 6005...6010,
Event 6005...6014,
Event 6009,
Event 6010,
Event 6011,
Event 6012,
Event 6012...6014,
Event 6013,
Event 6014,
Event 6015,
Event 6016...6018,
Event 6016...6020,
Event 6023...6025,
Event 6027,
Event 6030...6032,
Event 6034,
Event 6035,
Event 6036,
Event 6037...6043,
Event 6044,
Event 6048,
Event 6049,
Event 6070...6076,
Event 6070...6079,
Event 6071,
Event 6073,
Event 6076,
Event 6079,
Event 6084,
Event 6085,
Event 6090...6093,
Event 6092,
Event 6093
Param ID 0x14 (Binary protocol)
harsh.acceleration.duration
Harsh acceleration event duration
Param ID 0x1F (Binary protocol)
ignition.alarm
Ignition alarm
Param ID 0x52 (Binary protocol),
Param ID 0x1E (Binary protocol)
obd.state.enum
OBD communication status
Param ID 0x2D (Binary protocol)
Event 4001,
Event 4001...4005,
Event 4002,
Event 4003,
Event 4004,
Event 4005,
Event 4006,
Event 4012,
Event 6001,
Event 6001...6003,
Event 6002,
Event 6004,
Event 6005,
Event 6005...6008,
Event 6005...6010,
Event 6005...6014,
Event 6009,
Event 6010,
Event 6011,
Event 6012,
Event 6012...6014,
Event 6013,
Event 6014,
Event 6015,
Event 6016...6018,
Event 6016...6020,
Event 6023...6025,
Event 6027,
Event 6030...6032,
Event 6034,
Event 6035,
Event 6036,
Event 6037...6043,
Event 6044,
Event 6045,
Event 6048,
Event 6049,
Event 6070...6076,
Event 6070...6079,
Event 6071,
Event 6073,
Event 6076,
Event 6079,
Event 6084,
Event 6085,
Event 6090...6093,
Event 6092,
Event 6093,
Param ID 0x09 (Binary protocol)
Event 4001,
Event 4001...4005,
Event 4002,
Event 4003,
Event 4004,
Event 4005,
Event 4006,
Event 4012,
Event 6001,
Event 6001...6003,
Event 6002,
Event 6004,
Event 6005,
Event 6005...6008,
Event 6005...6010,
Event 6005...6014,
Event 6009,
Event 6010,
Event 6011,
Event 6012,
Event 6012...6014,
Event 6013,
Event 6014,
Event 6015,
Event 6016...6018,
Event 6016...6020,
Event 6023...6025,
Event 6027,
Event 6030...6032,
Event 6034,
Event 6035,
Event 6036,
Event 6037...6043,
Event 6044,
Event 6048,
Event 6049,
Event 6070...6076,
Event 6070...6079,
Event 6071,
Event 6073,
Event 6076,
Event 6079,
Event 6084,
Event 6085,
Event 6090...6093,
Event 6092,
Event 6093,
Param ID 0x0A (Binary protocol)
Event 4001,
Event 4001...4005,
Event 4002,
Event 4006,
Event 4012,
Event 6001,
Event 6001...6003,
Event 6002,
Event 6004,
Event 6005...6008,
Event 6005...6010,
Event 6005...6014,
Event 6011,
Event 6012,
Event 6012...6014,
Event 6015,
Event 6016...6018,
Event 6016...6020,
Event 6027,
Event 6030...6032,
Event 6034,
Event 6035,
Event 6036,
Event 6044,
Event 6045,
Event 6048,
Event 6049,
Event 6070...6076,
Event 6071,
Event 6073,
Event 6076,
Event 6079,
Event 6090...6093,
Event 6092,
Event 6093
Event 4001,
Event 4001...4005,
Event 4002,
Event 4003,
Event 4004,
Event 4005,
Event 4006,
Event 4012,
Event 6001,
Event 6001...6003,
Event 6002,
Event 6004,
Event 6005,
Event 6005...6008,
Event 6005...6010,
Event 6005...6014,
Event 6009,
Event 6010,
Event 6011,
Event 6012,
Event 6012...6014,
Event 6013,
Event 6014,
Event 6015,
Event 6016...6018,
Event 6016...6020,
Event 6023...6025,
Event 6027,
Event 6030...6032,
Event 6034,
Event 6035,
Event 6036,
Event 6037...6043,
Event 6044,
Event 6045,
Event 6048,
Event 6049,
Event 6070...6076,
Event 6070...6079,
Event 6071,
Event 6073,
Event 6076,
Event 6079,
Event 6084,
Event 6085,
Event 6090...6093,
Event 6092,
Event 6093,
Param ID 0x12 (Binary protocol)
Event 4001,
Event 4001...4005,
Event 4002,
Event 4003,
Event 4004,
Event 4005,
Event 4006,
Event 4012,
Event 6001,
Event 6001...6003,
Event 6002,
Event 6004,
Event 6005,
Event 6005...6008,
Event 6005...6010,
Event 6005...6014,
Event 6009,
Event 6010,
Event 6011,
Event 6012,
Event 6012...6014,
Event 6013,
Event 6014,
Event 6015,
Event 6016...6018,
Event 6016...6020,
Event 6023...6025,
Event 6027,
Event 6030...6032,
Event 6034,
Event 6035,
Event 6036,
Event 6037...6043,
Event 6044,
Event 6045,
Event 6048,
Event 6049,
Event 6070...6076,
Event 6070...6079,
Event 6071,
Event 6073,
Event 6076,
Event 6079,
Event 6084,
Event 6085,
Event 6090...6093,
Event 6092,
Event 6093,
Param ID 0x07 (Binary protocol)
Event 4001,
Event 4001...4005,
Event 4002,
Event 4003,
Event 4004,
Event 4005,
Event 4006,
Event 4012,
Event 6001,
Event 6001...6003,
Event 6002,
Event 6004,
Event 6005,
Event 6005...6008,
Event 6005...6010,
Event 6005...6014,
Event 6009,
Event 6010,
Event 6011,
Event 6012,
Event 6012...6014,
Event 6013,
Event 6014,
Event 6015,
Event 6016...6018,
Event 6016...6020,
Event 6023...6025,
Event 6027,
Event 6030...6032,
Event 6034,
Event 6035,
Event 6036,
Event 6037...6043,
Event 6044,
Event 6045,
Event 6048,
Event 6049,
Event 6070...6076,
Event 6070...6079,
Event 6071,
Event 6073,
Event 6076,
Event 6079,
Event 6084,
Event 6085,
Event 6090...6093,
Event 6092,
Event 6093,
Param ID 0x08 (Binary protocol)
Event 4001,
Event 4001...4005,
Event 4002,
Event 4003,
Event 4004,
Event 4005,
Event 4006,
Event 4012,
Event 6001,
Event 6001...6003,
Event 6002,
Event 6004,
Event 6005,
Event 6005...6008,
Event 6005...6010,
Event 6005...6014,
Event 6009,
Event 6010,
Event 6011,
Event 6012,
Event 6012...6014,
Event 6013,
Event 6014,
Event 6015,
Event 6016...6018,
Event 6016...6020,
Event 6023...6025,
Event 6027,
Event 6030...6032,
Event 6034,
Event 6035,
Event 6036,
Event 6037...6043,
Event 6044,
Event 6045,
Event 6048,
Event 6049,
Event 6070...6076,
Event 6070...6079,
Event 6071,
Event 6073,
Event 6076,
Event 6079,
Event 6084,
Event 6085,
Event 6090...6093,
Event 6092,
Event 6093,
Param ID 0x13 (Binary protocol)
Event 4001,
Event 4001...4005,
Event 4002,
Event 4003,
Event 4004,
Event 4005,
Event 4006,
Event 4012,
Event 6001,
Event 6001...6003,
Event 6002,
Event 6004,
Event 6005,
Event 6005...6008,
Event 6005...6010,
Event 6005...6014,
Event 6009,
Event 6010,
Event 6011,
Event 6012,
Event 6012...6014,
Event 6013,
Event 6014,
Event 6015,
Event 6016...6018,
Event 6016...6020,
Event 6023...6025,
Event 6027,
Event 6030...6032,
Event 6034,
Event 6035,
Event 6036,
Event 6037...6043,
Event 6044,
Event 6048,
Event 6049,
Event 6070...6076,
Event 6070...6079,
Event 6071,
Event 6073,
Event 6076,
Event 6079,
Event 6084,
Event 6085,
Event 6090...6093,
Event 6092,
Event 6093,
Param ID 0x0B (Binary protocol)
Param ID 0x05 (Binary protocol)
sensor.int16.value
User-defined 2 bytes sensor signed value stored as int16, indexed parameter
Param ID 0x42...0x49 (Binary protocol),
Param ID 0xB3...0xBA (Binary protocol)
sensor.int32.value
User-defined 4 bytes sensor signed value stored as int32, indexed parameter
Param ID 0x4A...0x51 (Binary protocol),
Param ID 0xBB...0xC2 (Binary protocol)
sensor.int8.value
User-defined 1 byte sensor signed value stored as int8, indexed parameter
Param ID 0x32...0x41 (Binary protocol),
Param ID 0xA3...0xB2 (Binary protocol)
Param ID 0x30 (Binary protocol),
Param ID 0x31 (Binary protocol)
Event 4001,
Event 4001...4005,
Event 4002,
Event 4003,
Event 4004,
Event 4005,
Event 4006,
Event 4012,
Event 6001,
Event 6001...6003,
Event 6002,
Event 6004,
Event 6005,
Event 6005...6008,
Event 6005...6010,
Event 6005...6014,
Event 6009,
Event 6010,
Event 6011,
Event 6012,
Event 6012...6014,
Event 6013,
Event 6014,
Event 6015,
Event 6016...6018,
Event 6016...6020,
Event 6023...6025,
Event 6027,
Event 6030...6032,
Event 6034,
Event 6035,
Event 6036,
Event 6037...6043,
Event 6044,
Event 6045,
Event 6048,
Event 6049,
Event 6070...6076,
Event 6070...6079,
Event 6071,
Event 6073,
Event 6076,
Event 6079,
Event 6084,
Event 6085,
Event 6090...6093,
Event 6092,
Event 6093,
Param ID 0x06 (Binary protocol)
Param ID 0x54 (Binary protocol)
Param ID 0x10 (Binary protocol),
Param ID 0x88 (Binary protocol)
vehicle.battery.voltage
Vehicle battery voltage
Param ID 0x17 (Binary protocol)
Event 4001,
Event 4001...4005,
Event 4002,
Event 4003,
Event 4004,
Event 4005,
Event 4006,
Event 4012,
Event 6001,
Event 6001...6003,
Event 6002,
Event 6004,
Event 6005,
Event 6005...6008,
Event 6005...6010,
Event 6005...6014,
Event 6009,
Event 6010,
Event 6011,
Event 6012,
Event 6012...6014,
Event 6013,
Event 6014,
Event 6015,
Event 6016...6018,
Event 6016...6020,
Event 6023...6025,
Event 6027,
Event 6030...6032,
Event 6034,
Event 6035,
Event 6036,
Event 6037...6043,
Event 6044,
Event 6048,
Event 6049,
Event 6070...6076,
Event 6070...6079,
Event 6071,
Event 6073,
Event 6076,
Event 6079,
Event 6084,
Event 6085,
Event 6090...6093,
Event 6092,
Event 6093,
Param ID 0x18 (Binary protocol)
Event 4006,
Event 6015,
Param ID 0x65 (Binary protocol)
wake.reason
Wake reason
Event 4001,
Event 4001...4005,
Event 4002,
Event 4003,
Event 4004,
Event 4005,
Event 4006,
Event 4012,
Event 6001,
Event 6001...6003,
Event 6002,
Event 6004,
Event 6005,
Event 6005...6010,
Event 6005...6014,
Event 6009,
Event 6010,
Event 6011,
Event 6012,
Event 6012...6014,
Event 6013,
Event 6014,
Event 6015,
Event 6016...6018,
Event 6016...6020,
Event 6027,
Event 6030...6032,
Event 6035,
Event 6036,
Event 6044,
Event 6048,
Event 6049,
Event 6070...6076,
Event 6070...6079,
Event 6071,
Event 6073,
Event 6076,
Event 6079,
Event 6084,
Event 6085,
Event 6090...6093,
Event 6092,
Event 6093
Event 4001,
Event 4001...4005,
Event 4002,
Event 4003,
Event 4004,
Event 4005,
Event 4006,
Event 4012,
Event 6001,
Event 6001...6003,
Event 6002,
Event 6004,
Event 6005,
Event 6005...6010,
Event 6005...6014,
Event 6009,
Event 6010,
Event 6011,
Event 6012,
Event 6012...6014,
Event 6013,
Event 6014,
Event 6015,
Event 6016...6018,
Event 6016...6020,
Event 6027,
Event 6030...6032,
Event 6035,
Event 6036,
Event 6044,
Event 6048,
Event 6049,
Event 6070...6076,
Event 6070...6079,
Event 6071,
Event 6073,
Event 6076,
Event 6079,
Event 6084,
Event 6085,
Event 6090...6093,
Event 6092,
Event 6093
Event 4001,
Event 4001...4005,
Event 4002,
Event 4003,
Event 4004,
Event 4005,
Event 4006,
Event 4012,
Event 6001,
Event 6001...6003,
Event 6002,
Event 6004,
Event 6005,
Event 6005...6010,
Event 6005...6014,
Event 6009,
Event 6010,
Event 6011,
Event 6012,
Event 6012...6014,
Event 6013,
Event 6014,
Event 6015,
Event 6016...6018,
Event 6016...6020,
Event 6027,
Event 6030...6032,
Event 6035,
Event 6036,
Event 6044,
Event 6048,
Event 6049,
Event 6070...6076,
Event 6070...6079,
Event 6071,
Event 6073,
Event 6076,
Event 6079,
Event 6084,
Event 6085,
Event 6090...6093,
Event 6092,
Event 6093
