Astra-telematics protocol
Parse and decode Astra Telematics MCPX binary messages into JSON. Get parsed data from Astra Telematics devices via REST API and MQTT. Forward normalized data from Astra Telematics trackers to AWS, Azure, etc.
flespi parses the Astra-telematics protocol messages into a JSON object with the fields listed below in the Parameters tab.
Connecting Astra Telematics device to flespi
Astra Telematics devices use the proprietary Modular Communications Protocol X (MCPX) binary protocol for data transmission. flespi fully supports this protocol and can parse over 200 data fields reported by Astra Telematics devices.
To connect your Astra Telematics device to flespi:
  1. Create a channel with astra-telematics protocol in your flespi account.
  2. Configure your Astra Telematics device with the channel IP address and port as the primary server destination.
  3. Register a device in flespi with the correct device type matching your hardware model (e.g. AT110, AT240, AT400, etc.).
  4. Power on or reboot the device to initiate connection to the new server.
Device configuration
Astra Telematics devices can be configured using the Astra Device Manager application or via AT commands. Key configuration areas include:
  • Server settings: configure the primary server address and port to point to your flespi channel.
  • Reporting intervals: set how frequently the device reports its position when moving and when stationary.
  • I/O configuration: enable and configure digital/analog inputs and outputs for ignition detection, external sensors, and alerts.
  • Geofencing: define geographic zones for entry/exit alerts.
It is important to select the correct device type when registering the device in flespi, as different models have different parameter mappings in the MCPX protocol.
Module 4: Analogues
Report Reason Flags
axle.weight
Axle weigth
Module 11: FMS Journey Start,
Module 16: FMS Journey Stop
Module 1: Device Power
Report Reason Flags
Module 45: BLE Beacons
ble.uptime
BLE uptime counter
Module 21: Rayvolt E-Bicycle,
Module 46: Generic CAN Data
Module 15: OBD DTCs
Module 13: FMS In-Journey,
Module 14: OBD In-Journey,
Module 17: OBD Journey Stop
can.motor.current
can.motor.rpm
can.motor.temperature
can.motor.voltage
device.tamper.status
Report Reason Flags
Module 3: Digitals
Module 9: Driver ID
Module 9: Driver ID
Report Status Flags
Report Status Flags
Module 12: GNSS Stop Report,
Module 16: FMS Journey Stop,
Module 8: Geofences
Report Status Flags
gnss.position.fixes.time
Module 7: GSM Network Info
Report Status Flags
Module 6: Signal Quality
Module 28: SIM ICCID
Module 27: SIM IMSI
Module 5: Driver Behaviour
Report Status Flags
min.x.acceleration
min.y.acceleration
min.z.acceleration
Report Reason Flags
packets.sent
Module 44: GNSS Extended Data
Module 2: GPS Data,
Module 2: GPS Data,
Module 2: GPS Data,
Module 2: GPS Data,
position.max.speed
Maximum speed value
Module 2: GPS Data,
position.satellites.visible
Module 2: GPS Data,
Report Status Flags
Report Status Flags
Module 33: Sensors
Report Reason Flags
system.uptime
system.wake.count
Module 29: FMS Driver ID
tacho.fms.driver.id
total.fuel.consumed
Report Reason Flags
Module 2: GPS Data,
Report Reason Flags
Report Reason Flags
is added automatically
Read IMEI
{"payload":"$IMEI"}
Read firmware version
{"payload":"$ATSW"}
Force immediate report
{"payload":"$POLL"}
{"payload":"$TEST,1"}
{"payload":"$JSEC,30"}
{"payload":"$DIST,500"}
