Astra Telematics AT242
Astra Telematics AT242 is an advanced IP67-rated 4G LTE Cat 1 vehicle tracking device designed for challenging fleet management and vehicle sharing applications. The device features integrated CANBus for OBD2 and FMS data access, multi-constellation GNSS positioning with GLONASS support, and Bluetooth Low Energy connectivity. Built with extensive I/O including multiple digital inputs/outputs, 1-Wire interface for temperature sensors and driver identification, and dual RS-232 serial ports, the AT242 offers comprehensive telematics capabilities. The compact device includes internal backup battery, tamper detection, and waterproof IP67 sealing for reliable operation in harsh environments. Powered by an STM32L4 Cortex M4 processor with Mediatek GNSS chipset and 25mm ceramic patch antenna.
Parameters (99)
Settings (6)
Flespi parses telemetry data from your Astra Telematics AT242 into a standardized JSON and lets you send commands to Astra Telematics AT242 via API.
    "device.type.id": "Astra Telematics AT242",
How to send commands to Astra Telematics AT242?
Module 4: Analogues
Report Reason Flags
axle.weight
Axle weigth
Module 11: FMS Journey Start,
Module 16: FMS Journey Stop
Module 1: Device Power
Report Reason Flags
Module 45: BLE Beacons
ble.uptime
BLE uptime counter
Module 21: Rayvolt E-Bicycle,
Module 46: Generic CAN Data
Module 15: OBD DTCs
Module 13: FMS In-Journey,
Module 14: OBD In-Journey,
Module 17: OBD Journey Stop
can.motor.current
can.motor.rpm
can.motor.temperature
can.motor.voltage
device.tamper.status
Report Reason Flags
Module 3: Digitals
Module 9: Driver ID
Module 9: Driver ID
Report Status Flags
Report Status Flags
Module 12: GNSS Stop Report,
Module 16: FMS Journey Stop,
Module 8: Geofences
Report Status Flags
gnss.position.fixes.time
Module 7: GSM Network Info
Report Status Flags
Module 6: Signal Quality
Module 28: SIM ICCID
Module 27: SIM IMSI
Module 5: Driver Behaviour
Report Status Flags
min.x.acceleration
min.y.acceleration
min.z.acceleration
Report Reason Flags
packets.sent
Module 44: GNSS Extended Data
Module 2: GPS Data,
Module 2: GPS Data,
Module 2: GPS Data,
Module 2: GPS Data,
position.max.speed
Maximum speed value
Module 2: GPS Data,
position.satellites.visible
Module 2: GPS Data,
Report Status Flags
Report Status Flags
Module 33: Sensors
Report Reason Flags
system.uptime
system.wake.count
Module 29: FMS Driver ID
tacho.fms.driver.id
total.fuel.consumed
Report Reason Flags
Module 2: GPS Data,
Report Reason Flags
Report Reason Flags
APN Password
apn_password
Digital Output
digital_output
state: State
output: Output number
set_time: ON time (ms)
pulse_reps: Pulse repetitions
unset_time: OFF time (ms)
Immobilise
immobilise
delay: Delay (seconds)
Server Host
server_host
Server Port
server_port
is added automatically
Read IMEI
{"payload":"$IMEI"}
Read firmware version
{"payload":"$ATSW"}
Force immediate report
{"payload":"$POLL"}
{"payload":"$TEST,1"}
{"payload":"$JSEC,30"}
{"payload":"$DIST,500"}
