Astra Telematics AT110
Astra Telematics AT110 is an advanced vehicle tracking device featuring a Cortex M3 ARM processor and ublox EVA-M8M GNSS receiver supporting GPS, GALILEO, GLONASS, and BeiDou navigation systems. The device operates on 3G UMTS/HSPA and GSM/GPRS networks with penta-band coverage. It includes an integrated CANBus interface with FMS and OBD2 support, two RS232 serial ports, 1-wire Dallas interface for temperature sensors and iButton driver ID, and a 950mAh internal backup battery providing 10 hours of continuous operation. The compact matchbox-sized unit (85x47x15mm) features an aluminum enclosure, 3-axis accelerometer, 6 digital inputs, 5 digital outputs, 2 ADC inputs, and operates from 5-50V DC for flexible installation in fleet management and telematics applications.
Parameters (99)
Settings (6)
Flespi parses telemetry data from your Astra Telematics AT110 into a standardized JSON and lets you send commands to Astra Telematics AT110 via API.
    "device.type.id": "Astra Telematics AT110",
How to send commands to Astra Telematics AT110?
Module 4: Analogues
Report Reason Flags
axle.weight
Axle weigth
Module 11: FMS Journey Start,
Module 16: FMS Journey Stop
Module 1: Device Power
Report Reason Flags
Module 45: BLE Beacons
ble.uptime
BLE uptime counter
Module 21: Rayvolt E-Bicycle,
Module 46: Generic CAN Data
Module 15: OBD DTCs
Module 13: FMS In-Journey,
Module 14: OBD In-Journey,
Module 17: OBD Journey Stop
can.motor.current
can.motor.rpm
can.motor.temperature
can.motor.voltage
device.tamper.status
Report Reason Flags
Module 3: Digitals
Module 9: Driver ID
Module 9: Driver ID
Report Status Flags
Report Status Flags
Module 12: GNSS Stop Report,
Module 16: FMS Journey Stop,
Module 8: Geofences
Report Status Flags
gnss.position.fixes.time
Module 7: GSM Network Info
Report Status Flags
Module 6: Signal Quality
Module 28: SIM ICCID
Module 27: SIM IMSI
Module 5: Driver Behaviour
Report Status Flags
min.x.acceleration
min.y.acceleration
min.z.acceleration
Report Reason Flags
packets.sent
Module 44: GNSS Extended Data
Module 2: GPS Data,
Module 2: GPS Data,
Module 2: GPS Data,
Module 2: GPS Data,
position.max.speed
Maximum speed value
Module 2: GPS Data,
position.satellites.visible
Module 2: GPS Data,
Report Status Flags
Report Status Flags
Module 33: Sensors
Report Reason Flags
system.uptime
system.wake.count
Module 29: FMS Driver ID
tacho.fms.driver.id
total.fuel.consumed
Report Reason Flags
Module 2: GPS Data,
Report Reason Flags
Report Reason Flags
APN Password
apn_password
Digital Output
digital_output
state: State
output: Output number
set_time: ON time (ms)
pulse_reps: Pulse repetitions
unset_time: OFF time (ms)
Immobilise
immobilise
delay: Delay (seconds)
Server Host
server_host
Server Port
server_port
is added automatically
Read IMEI
{"payload":"$IMEI"}
Read firmware version
{"payload":"$ATSW"}
Force immediate report
{"payload":"$POLL"}
{"payload":"$TEST,1"}
{"payload":"$JSEC,30"}
{"payload":"$DIST,500"}
