Astra Telematics AT240
Astra Telematics AT240 is a highly featured IP67 waterproof vehicle tracking device housed in a compact plastic enclosure with integrated GPS/GSM antennas. Powered by a Cortex M3 ARM processor, it features a Telit GE865 Quad Band GSM/GPRS modem and SiRFStar IV GPS chipset with high sensitivity and anti-jamming capabilities. The device includes Bluetooth Low Energy, integrated CANBus interface for FMS and OBD-II protocol support, RS-232 serial port, and 1-Wire interface for iButton driver identification and temperature sensors. It operates from 7-36V DC power with an internal backup battery (450-510mAh) providing up to 5 hours continuous operation. The AT240 offers multiple digital and analog I/O, accelerometer for driving behavior monitoring, and comprehensive fleet management features including geo-fencing and immobilization control.
Parameters (98)
Settings (6)
Flespi parses telemetry data from your Astra Telematics AT240 into a standardized JSON and lets you send commands to Astra Telematics AT240 via API.
    "device.type.id": "Astra Telematics AT240",
How to send commands to Astra Telematics AT240?
Module 4: Analogues
Report Reason Flags
axle.weight
Axle weigth
Module 11: FMS Journey Start,
Module 16: FMS Journey Stop
Module 1: Device Power
Report Reason Flags
Module 45: BLE Beacons
ble.uptime
BLE uptime counter
Module 21: Rayvolt E-Bicycle,
Module 46: Generic CAN Data
Module 15: OBD DTCs
Module 13: FMS In-Journey,
Module 14: OBD In-Journey,
Module 17: OBD Journey Stop
can.motor.current
can.motor.rpm
can.motor.temperature
can.motor.voltage
device.tamper.status
Report Reason Flags
Module 3: Digitals
Module 9: Driver ID
Module 9: Driver ID
Report Status Flags
Report Status Flags
Module 12: GNSS Stop Report,
Module 16: FMS Journey Stop,
Module 8: Geofences
Report Status Flags
gnss.position.fixes.time
Module 7: GSM Network Info
Report Status Flags
Module 6: Signal Quality
Module 28: SIM ICCID
Module 27: SIM IMSI
Module 5: Driver Behaviour
Report Status Flags
min.x.acceleration
min.y.acceleration
min.z.acceleration
Report Reason Flags
packets.sent
Module 44: GNSS Extended Data
Module 2: GPS Data,
Module 2: GPS Data,
Module 2: GPS Data,
Module 2: GPS Data,
position.max.speed
Maximum speed value
Module 2: GPS Data,
position.satellites.visible
Module 2: GPS Data,
Report Status Flags
Report Status Flags
Module 33: Sensors
Report Reason Flags
system.uptime
system.wake.count
tacho.fms.driver.id
Module 29: FMS Driver ID
total.fuel.consumed
Report Reason Flags
Module 2: GPS Data,
Report Reason Flags
Report Reason Flags
APN Password
apn_password
Digital Output
digital_output
state: State
output: Output number
set_time: ON time (ms)
pulse_reps: Pulse repetitions
unset_time: OFF time (ms)
Immobilise
immobilise
delay: Delay (seconds)
Server Host
server_host
Server Port
server_port
is added automatically
Read IMEI
{"payload":"$IMEI"}
Read firmware version
{"payload":"$ATSW"}
Force immediate report
{"payload":"$POLL"}
{"payload":"$TEST,1"}
{"payload":"$JSEC,30"}
{"payload":"$DIST,500"}
