Astra Telematics AT241
Astra Telematics AT241 is an advanced IP67-rated vehicle tracking device featuring future-proof LTE-M (Cat M1) and NB-IoT connectivity alongside 2G/GPRS. The device includes a 510mAh internal backup battery, built-in CANBus/FMS 2.0/OBD2 interface, RS232 ports, 1-Wire support, and multi-constellation GNSS (GPS, GLONASS, Galileo, BeiDou) with a Mediatek chipset and ceramic patch antenna. With extensive I/O (6 digital inputs, 5 digital outputs, 2 ADC inputs), MEMS accelerometer, tamper detection, and compact waterproof housing, the AT241 supports fleet management, vehicle sharing, security applications, and heavy equipment monitoring. The device offers FOTA firmware updates and a 5-year warranty.
Parameters (99)
Settings (6)
Flespi parses telemetry data from your Astra Telematics AT241 into a standardized JSON and lets you send commands to Astra Telematics AT241 via API.
    "device.type.id": "Astra Telematics AT241",
How to send commands to Astra Telematics AT241?
Module 4: Analogues
Report Reason Flags
axle.weight
Axle weigth
Module 11: FMS Journey Start,
Module 16: FMS Journey Stop
Module 1: Device Power
Report Reason Flags
Module 45: BLE Beacons
ble.uptime
BLE uptime counter
Module 21: Rayvolt E-Bicycle,
Module 46: Generic CAN Data
Module 15: OBD DTCs
Module 13: FMS In-Journey,
Module 14: OBD In-Journey,
Module 17: OBD Journey Stop
can.motor.current
can.motor.rpm
can.motor.temperature
can.motor.voltage
device.tamper.status
Report Reason Flags
Module 3: Digitals
Module 9: Driver ID
Module 9: Driver ID
Report Status Flags
Report Status Flags
Module 12: GNSS Stop Report,
Module 16: FMS Journey Stop,
Module 8: Geofences
Report Status Flags
gnss.position.fixes.time
Module 7: GSM Network Info
Report Status Flags
Module 6: Signal Quality
Module 28: SIM ICCID
Module 27: SIM IMSI
Module 5: Driver Behaviour
Report Status Flags
min.x.acceleration
min.y.acceleration
min.z.acceleration
Report Reason Flags
packets.sent
Module 44: GNSS Extended Data
Module 2: GPS Data,
Module 2: GPS Data,
Module 2: GPS Data,
Module 2: GPS Data,
position.max.speed
Maximum speed value
Module 2: GPS Data,
position.satellites.visible
Module 2: GPS Data,
Report Status Flags
Report Status Flags
Module 33: Sensors
Report Reason Flags
system.uptime
system.wake.count
Module 29: FMS Driver ID
tacho.fms.driver.id
total.fuel.consumed
Report Reason Flags
Module 2: GPS Data,
Report Reason Flags
Report Reason Flags
APN Password
apn_password
Digital Output
digital_output
state: State
output: Output number
set_time: ON time (ms)
pulse_reps: Pulse repetitions
unset_time: OFF time (ms)
Immobilise
immobilise
delay: Delay (seconds)
Server Host
server_host
Server Port
server_port
is added automatically
Read IMEI
{"payload":"$IMEI"}
Read firmware version
{"payload":"$ATSW"}
Force immediate report
{"payload":"$POLL"}
{"payload":"$TEST,1"}
{"payload":"$JSEC,30"}
{"payload":"$DIST,500"}
