BSJ C02G
BSJ C02G is a compact hardwired 4G GPS tracker for vehicles and fleets. It uses LTE Cat1 and falls back to 2G GSM/GPRS, and it accepts a wide 9-90V DC input with overvoltage protection, so it suits everything from cars to heavy trucks. Positioning comes from multiple satellite systems: GPS, GLONASS, Galileo, BeiDou, QZSS and SBAS, plus AGPS. The GNSS and cellular antennas are high-gain and built in. A 180mAh Li-Polymer backup battery keeps it running if vehicle power is lost. It also has 4 digital inputs, 1 digital output, an SOS panic button, a microphone for listen-in and remote fuel or power cut-off through a relay. Alerts cover ignition, overspeed, collision, geofence, power disconnection and tampering. The slim 86x43x15 mm, 70 g housing is easy to hide, and the device has 8 MB of flash memory and a Micro-SIM slot.
Parameters (188)
Settings (10)
BSJ C02G
Flespi parses telemetry data from your BSJ C02G into a standardized JSON and lets you send commands to BSJ C02G via API.
    "device.type.id": "BSJ C02G",
    "protocol.id": "bsj"
How to send commands to BSJ C02G?
accelerometer.module.status
Additional info ID 0x67
adas.blindspot.side
Additional info ID 0x2B,
Additional info ID 0xA1,
Message ID 0x1212
brake.status
Brake status
driver.card.reading.error
Driver card reading error
Message ID 0x0702
Message ID 0x0702
Message ID 0x0702
driver.registration.status
Driver registration status
Message ID 0x0702
driving.alarm.bitmask
Additional info ID 0x18
Additional info ID 0x65
dsm.device.occlusion.event
Additional info ID 0x18,
dsm.fatigue.degree
Additional info ID 0x04,
Additional info ID 0x65,
Additional info ID 0x66,
Additional info ID 0x67,
Additional info ID 0x70,
Message ID 0x0301,
gps.signal.level
GPS signal level
high.temperature.alarm
High temperature alarm
low.temperature.alarm
Low temperature alarm
media.filename
Multimedia file name
Message ID 0x1211,
Message ID 0x1212
media.filesize
Multimedia file size
Message ID 0x1211,
Message ID 0x1212
Message ID 0x1211,
Message ID 0x1212
memory.fault.status.bitmask
Additional info ID 0x17
Message ID 0x0F00...0x0FFF
position.source
Additional info ID 0x2A,
storage.media.free.size
megabytes
storage.media.malfunction
storage.media.total.size
megabytes
storage.media.type
Storage media type, indexed
storage.media.valid
Message ID 0x0702,
Message ID 0x1212
tire.error.status
Tire status error
tire.leak.status
Tire leak detected
tire.overpressure.status
Tire overpressure
tire.underpressure.status
Tire underpressure
upgrade.status.name
Upgrade status
Message ID 0x0108
upgrade.type
Upgrade type
Message ID 0x0108
video.alarm.bitmask
Video alarm flags bitmask
Additional info ID 0x14
Additional info ID 0x16
Additional info ID 0x15
username: Username
Default report interval
default_interval
Dormancy report interval
dormancy_interval
Terminal factory reset
factory_reset
Heartbeat interval
heartbeat
Highest speed
highest_speed
Overspeed duration
overspeed_duration
Report strategy
report_strategy
Terminal reset
Server
address: Server address
tcp_port: TCP port
Check terminal parameter
{"message_id":"8104"}
